![]() Чёрт ![]() Группа: Пользователь Сообщений: 2462 Регистрация: 17.1.2006 Из: Voodoo Пользователь №: 50 Авто: Авто Репутация: ![]() ![]() ![]() |
Привет друзья админы (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif)
Два провайдера, два юзера в сети, один сервер в ДМЗ. У каждого юзера должен быть свой канал. До сервака с двух внешних айпи проброс по одинаковым портам. Как сейчас работает: interface FastEthernet1/0 description LAN ip address 192.168.0.254 255.255.255.0 ip nat inside ip policy route-map lan_map ! interface FastEthernet1/0 description DMZ ip address 172.16.0.254 255.255.255.0 ip nat inside ip policy route-map dmz_map interface FastEthernet0/0 description ISP2 ip address 200.1.1.229 255.255.255.252 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip nat enable ip virtual-reassembly duplex full speed 100 no keepalive no cdp enable ! interface FastEthernet0/1 description ISP1 ip address 194.1.1.229 255.255.255.252 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip nat enable ip virtual-reassembly duplex full speed 100 no keepalive no cdp enable ! ip route 0.0.0.0 0.0.0.0 200.1.1.230 ip route 0.0.0.0 0.0.0.0 194.1.1.230 ! ip access-list extended vasya_nat permit ip host 192.168.0.1 any ! ip access-list extended petya_nat permit ip host 192.168.0.10 any ! access-list 108 permit ip host 200.1.1.229 any access-list 110 permit ip host 194.1.1.229 any ! route-map lan_map permit 10 match ip address vasya_nat set ip next-hop 200.1.1.230 ! route-map lan_map permit 20 match ip address petya_nat set ip next-hop 194.1.1.230 ! route-map vasya_map permit 10 match ip address vasya_nat ! route-map petya_map permit 10 match ip address petya_nat ! route-map dmz_map permit 20 match ip address dmz_nat set ip next-hop 194.1.1.230 ! ip local policy route-map LOCAL_MAP ! route-map LOCAL_MAP permit 10 match ip address 108 set ip next-hop 200.1.1.229 ! route-map LOCAL_MAP permit 20 match ip address 110 set ip next-hop 194.1.1.230 ! ip nat inside source route-map vasya_map interface Fa0/0 overload ip nat inside source route-map petya_map interface Fa0/1 overload ! ip nat inside source static tcp 172.16.0.1 3000 194.1.1.229 3000 extendable ip nat inside source static tcp 172.16.0.1 3000 200.1.1.229 3000 extendable ! если в LOCAL_POLICY не указать айпи интерфейсов, то снаружи один из них не пингуется, а именно тот, чья сеть не в 0.0.0.0 не знает куда слать отклик Всё работает при выключеном ip cef. Если включаю ip cef - входящий проброс со второго прова не работает. С включеным ip cef невозможно подключиться к пробросу который ISP2. Не работает проброс если по умолчанию не шлюз второго прова или если он не забит первым для 0.0.0.0 Когда делаю traceroute от Пети, то ухожу по второму прову, т.к. он по дефолту, хотя прописано в route-map lan_map - match ip address petya_nat - set ip next-hop 194.1.1.230 Еще прикол в том, что хоть трейс и идёт не-туда - айпи в интернете светятся правильные для Пети иВаси, т.е. те которые я им назначаю натом. Помогите разобраться в такой сложной схеме (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif) Голова кругом уже идёт (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif) Хочется чтобы Вася ходил через второго прова, Петя через первого и при этом сервак был виден снаружи с двух интерфейсов. -------------------- heartless just pain coming... from deep inside
Автобот |
Текстовая версия | Сейчас: 17th April 2025 - 03:29 |
