74 страниц V  « < 10 11 12 13 14 > »
> Схемы наших аудиосистем
kem
сообщение Mar 26 2009, 19:08
Сообщение #221
Пользователь №: 4041
Авто: nexia
Pure digital.
Used by Team PioneerWith its powerful 32-bit floating-point SHARC Digital Signal Processors equaliser and network control functions, our RS-A9 ODR amplifier features high-performance functions that put you in total control of your sound stage.
An optical digital input allows the amp to connect digitally to the RS-D7R11, preserving the highest quality of the audio signal and forming a pure digital system.
The unit also [ (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif) ]s 3 digital outputs so that you can easily combine it with one or more RS-A7 amplifiers to drive your speakers with the utmost sonic purity.
It is suited especially for tweeters and midrange speakers, bringing out the clear and smooth tone of delicate strings.
This amplifier’s design and specialised parts further ensure high-quality sound and a true digital signal.
Specifications
Main Features RS-A9
Maximum Output Power 4 x 100W, 2 x 300W
Continuous power output (RMS) • 50W x 4 / 150W x 2 (20 - 20kHz, 0.02/0.02%, 4Ω)
• 75W x 4 (20 - 20kHz, 0.02%, 2Ω)
Load impedance capability 2 - 8Ω
Frequency response 10 - 100,000 Hz
Distortion < 0,002 %
S/N ratio 105 dB
LPF Integrated DSP
Max. current consumption (A/4Ω) • 31A (Rated power)
• 5A (No signal)
Chassis size (W x H x D) 330 x 71 x 585 mm
Unit weight 13 kg
ODR Features RS-A9
Optical Digital input/output 1/3
IP Bus input/output 1/1
32-Bit Floating SHARC DSPs 3
FIR Filter Yes
Digital Crossover Network 4-way, L/R independent
Graphic Equalisers • 31-band
• 3-band for L/R segmentation
Time Alignment Yes
Listening Position Selector Yes
DA Converters Burr-Brown 24-bit Advanced Segment
Additional ODR Features • L/R independent power supply
• High performance 8 x oversampling digital filter
• Ultra precise sound master clock circuit
• Upsampling (44.1kHz - 192 kHz) by Sampling Rate Converter)
• Parametric bass / treble
• Electronic DAC volume in 60 steps
• Non-magnetic power terminal
• Copper-plated chassis
Т.е. это цифровой интегрированный усилитель ,которым можно управлять только с помощью цифрового головного модуля RS-D7R и тем самым управлять цифровой обработкой звука.Так,что усь,в связьке с модулем, можно назвать цифровым.Надеюсь, люди нам ничего плохого не сделают.
Сообщение отредактировал kem - Mar 26 2009, 20:37
сообщение Mar 27 2009, 00:35
Сообщение #222
Цитата(kem @ Mar 18 2009, 10:41) *
Вобще, я Вам советую не покупать отдельно процессор (не все модели согласованы друг с другом), а по менять голову ,например ,pioner 88 или alpine 9887 -очень серьезные аппараты.У них есть почти все для "счастливой" жизни.М. б. когда нибудь поставлю себе.
Р88
хороший майфун друг юзает.
покупал в москве за 430.
сообщение Mar 27 2009, 10:13
Сообщение #223
Цитата(kajama @ Mar 26 2009, 16:00) *
=) ага. еще один АВТО усилитель класса А =) просто авто стоит в гараже и питается от 220 в. да? =) ВРАНЬЕ!
а по поводу самого этого усилителя так ты Костя помоему зря. Он же АБ класса, просто со встроенным процом SHARC!!!! 32 bit как мне известно, то есть самый самый =) правда стоит этот зверь 5000 =) но одно время сильно хотелось. Хорошо перехотелось ;-)
Паш... Этот усь я не слышал, а след-но ниче про него сказать не могу... просто Кем сказал что он цифровой... я и вздрогнул (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif) ... не более того (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif)
Цитата(kem @ Mar 26 2009, 19:53) *
Pure digital.
Кем, еще раз... ничего про этот усь сказать не могу, ни плохого ни хорошего... просто видимо недопонимание произошло у нас из за того, что термин "то цифровой интегрированный усилитель" мы с вам понимаем по разному... я к примеру под цифровым усем понимаю уси класса Д , ну а не цифровой - классы АБ ну и закос под класс А... А прочитав, что ток покоя у указанного Вами уся есть 5А почти (ну и L/R independent power supply), сильно удивился... ибо одним из достоинств класса Д является его достаточно высокий по сравнению с АБ КПД...
Лана не вижу смысла больше тереть на тему этого уся... То что в его корпус поместили DSP видимо вынув его из ГУ - есть гуд... в таком корпусе есть где развернуться в сравнении с ГУ...
kem
сообщение Mar 27 2009, 15:02
Сообщение #224
Авто: nexia
Да интересный усь.Без модуля аналог,c модулем цифра,т.к. идет обработка цифрового сигнала.Ну а класс А ,т.к. ,как правильно Вы заметили, КПД у него маленький-все сделано для качества звучания,HI-END.
P.S. Костик, спасибо за сылку.Мужик этот сильно продвинутый,явно со спецподготовкой,знает о музыке почти все.На звуке явно повернутый,да и твикать сильно любит,наверное с паяльником спит.Кстати ,любит 3-х полоску.
сообщение Mar 27 2009, 16:09
Сообщение #225
У него на сайте много чего есть... один кросс из лампочки Ильича чего стоит (IMG:http://autocenter.uz/forum/style_emoticons/default/smile.gif)
kajama
сообщение Mar 27 2009, 19:42
Сообщение #226
Пользователь №: 205
Авто: lacetti hatch
в описании нет ни слова про то что он импульсный, класса Д.
Этот усилитель не А класса. Могу тоже сказать про свой хюман-рейн, мол А КЛАСС епрст =)
p.s. вот он же, только без ШАРКОВ, то есть а900 для европы и США
http://www.pioneerelectronics.com/PUSA/Pro.../PRS-A900?tab=B
посмотрите мо имеджес, там есть его НУТРО. там все ясно.
Сообщение отредактировал kajama - Mar 27 2009, 19:44
kem
сообщение Mar 27 2009, 21:25
Сообщение #227
Авто: nexia
Было сказано,что он "интегрированный цифровой усилитель".Вполне возможно ,что Вы правы насчет класса AB.Но согласитесь ,что отождествлять усилитель RS-A9 профессиональной серии с аудиофильским классом ниже - PRS A900 не совсем корректно. "Шарков" -имелся ввиду встроенный чип?
Да они даже внешне не похожи:
http://www.pioneer.co.uk/uk/products/25/29...S-A9/index.html
Сообщение отредактировал kem - Mar 28 2009, 00:59
kem
сообщение Mar 28 2009, 13:40
Сообщение #228
Авто: nexia
Цитата(TANK @ Mar 27 2009, 00:20) *
Р88
Конечно есть и другие хорошие головы,просто советовал именно эти модели,т.к. их можно достать в Ташкенте.
Если Вас интересует именно Sony-у них есть бескомпромисная серия "XES" с головой Sony XES-Z50 ,стоила раньше 8000 бакинских.Есть ли ей альтернатива, и по стоимости и по качеству ,не знаю.
Сообщение отредактировал kem - Mar 28 2009, 13:47
kajama
сообщение Mar 28 2009, 13:58
Сообщение #229
Пользователь №: 205
Авто: lacetti hatch
Это, rs-a9x и а900, одно и тоже за исключением процессора который есть только в японской одр серии, т.е. Rs-a9x
Уточнял я это у знакомого в тим пионер россия.
kem
сообщение Mar 30 2009, 11:57
Сообщение #230
Авто: nexia
Кстати,один "сумашедший" чувак на этой башке, домашней акустике Scanspeak,усилках Audison Venti построил в машине мультимедию на сумму более 100 килобаксов...
kem
сообщение Mar 31 2009, 11:52
Сообщение #231
Авто: nexia
Цитата(kajama @ Mar 24 2009, 10:15) *
Eclipse cd7300mkII
Интенресно,какой чипсет и какая разрядность ЦАПа ?
Сообщение отредактировал kem - Mar 31 2009, 12:05
kajama
сообщение Mar 31 2009, 16:14
Сообщение #232
Пользователь №: 205
Авто: lacetti hatch
описание
Advanced 24-bit delta sigma DAC
сообщение Mar 31 2009, 16:26
Сообщение #233
Цитата(kajama @ Mar 31 2009, 16:59) *
описание
Паш, а чего с Ф1? Эклипс те по звуку чтоли больше понравился? Эклипс ведь дельта сигма... а Ф1 он настоящий был...
Сообщение отредактировал Kostik - Mar 31 2009, 16:39
kem
сообщение Mar 31 2009, 16:52
Сообщение #234
Авто: nexia
Цитата(kajama @ Mar 31 2009, 15:59) *
описание
Да,очень серьезно! Интересно ,а что тогда стоит в Sound Monitor ах - Barr brown ?
Сообщение отредактировал kem - Mar 31 2009, 16:56
сообщение Mar 31 2009, 17:03
Сообщение #235
дельты стоят в промежутке между однобитниками и мультибитниками (реальными),.. что меня и смутило в выборе Паши... наверное звук больше статусного понравился?
kem
сообщение Mar 31 2009, 17:15
Сообщение #236
Авто: nexia
Да,и опять мы вернулись к подходу этих самураев.Все лучшее (Sound Monitor) только для gapana.Кстати,интересно ,почему не купили Моник,если у Вас был уже F1?
Сообщение отредактировал kem - Mar 31 2009, 17:37
kem
сообщение Mar 31 2009, 19:46
Сообщение #237
Авто: nexia
Костик,не давите интеллектом,а то нас опять подрежут...
Сообщение отредактировал kem - Mar 31 2009, 19:50
kajama
сообщение Mar 31 2009, 21:59
Сообщение #238
Пользователь №: 205
Авто: lacetti hatch
Костя, привет. Тут такое дело, 21 век понимаешь -) мп3 + вма почти не жатые, да и привозить фирменные диски долго и дорого, ах да, еще и айфон с айподом и .... Ну вот я и решил что ну за 2к для этих целей - кощунство -) качать мп3 и слушать на статусе, как ты говоришь, не кошерно -) короче вот. А про дельту и берр спортить не стану, но вот в деноне з1, который тоже 2.5к стоит -) стоит именно эта адвансед дельтасигма, ну а то что многие послушавшие денон, продали статус, ты наверное сам знаешь. -)
Теперь привет Кем! В мониторах 18 бит, не помню какой из берров стоит, но не 1704. 1702 может, а может и вообще ad микруха какая не из браунов, какаято модель была точно с этой микрухой, щас посмотрю. А про то почему не купил монитор я написал в начале -) кстати оооочень хотелось купить и послушать, хорошо денег не было свободных.
kajama
сообщение Mar 31 2009, 22:05
Сообщение #239
Пользователь №: 205
Авто: lacetti hatch
Кстати играет фуджик отлично! Фильтра понравились ну а встроенный блютус так вообще работает превосходно -)
kem
сообщение Apr 1 2009, 00:15
Сообщение #240
Авто: nexia
Приветствую,Kajama!Ответ убедительный,все ясно.Да ,в Мониках какой-то 18 бит гибрид BB PCM 69U стоит,а в Denone DCT-Z1 ,по-моемому, 20 бит настоящий ВВ PMC 1702.
30 чел. читают эту тему (гостей: 30, скрытых пользователей: 0)
Текстовая версия Сейчас: 30th July 2026 - 11:56
