Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(OTASH @ Jul 9 2012, 21:26) *
инжектор лучше или dellorto dhla40 ?
инжектор. конечно же имхо
Цитата(dyo999 @ Jul 9 2012, 19:48) *
а что за бесконтактный датчик, можно поподробнее?
для каждого "копейка" понятие растяжимое smile.gif, родной датчик стоит 50-60 килосум.
вот: http://www.vtnauto.com/ru/assort_dat.html
вроде и на Нексию есть - нужно у производителя уточнить
стоит по моему около 10 баксов там - или покопайся на каком нибудь Нексия форуме - я точно не знаю - говорят и на Лосей есть - пока курю форум.
Цитата(V@ldemario @ Jul 9 2012, 15:55) *
Где находится разъем я в курсе smile.gif. Просто нужно было подключить дополнительно контакт с БК на K-LINE (OBD 1), чтобы считывать ошибки с ЭБУ, подключили но, БК так ничего не отобразил. Теперь выясняется что для того чтобы с K-LINE cчитывать диагностическую инфу, нужно заранее замкнуть 9 и 18 контакт на иммобилайзере. Вот и задался вопросом, может кто то это уже делал. На Калине видимо такая проблема не возникает.
Я на 15-ке ничего не замыкал. Воткнул колодку и один провод подключил к диагностической колодке. БК "Мультитроникс" .
Цитата(dyo999 @ Jul 9 2012, 18:22) *
авто нексия 1,6, гонит датчик холостого хода.
новый датчик стоит порядка 50-60 килосум.
что делать менять на новый или можно починить старый?
это трабла всех 1.6 ксю и только летом.
обороты зависают или играют... чистка дс тут не причем.
там датчик "пельмень" мозг е-т. заедь к Скуллу, он чето там делает, потом норм будет )
_D_i_m_k_a_
Всем привет!!! Кто знает тел зоны отдыха Бельдерсай, затерялся контакт не могу найти((
qwerpo
Тап
основной минус карбюраторных систем трамблерное зажигание которое дает нужный нам результат в лучшем случае в 2хточках. инжектор же этого лишен. лишь за это его ставить нужно
AndreVla
Нужен хороший мастер по ремонту ВАЗ.
Что нужно:
1. Провести осмотр авто
2. Составиться список того, что необходимо сделать.
3. Расставить по возможности поэтапно (по приоритетам) список необходимых работ.
Ну и главное, чтобы мастер был понимающим и адекватным, а не тупо желающим срубить бабла заменяя то, что ещё может прослужить N-ое кол-во времени.
Уважаемые пользователи!
Данная тема не предназначена для обсуждения автомобильных простеньких вопросов! Просим авто вопросы завадать в соответствующих разделах не в Беседке! Спасибо.
qwerpo
ВАЗ - классика или переднеприводный?
AndreVla
ВАЗ 2121. Недополноприводный. Раздатка временно снята. Поставлен жигулёвский кардан.
Lawyer
По чем нынче можно продать Мотю годовалую? Кто в курсе рыночных цен?
Камол
от 7000 и выше
_HaMMeR_
У меня дома кошка Мотя (Матильда) годовалая, вот ее вечером спрошу, почем готова продаться. rofl.gif
Подскажите какой выбрать ADSL модем с wifi (оператор Sharq Stream). TP-LINK, D-LINK?
AndreVla
Это одно и тоже. Выбирайте то что больше нравиться
Что нужно:
за оптовкой катартал, есть Автосалон, возле него сервис... там есть мастер Саид, золотые руки!
Nikifan
Для шарка советую Tp-link 8960 или 8961. На них корректно одновременно будут работать и ресурсы и внешка.
взял неделю назад тп-линк 8901 с 4 портами, адсл и 54мб сек вай фай за 42$))) рад как слон)
slako
Цитата(V@ldemario @ Jul 9 2012, 22:31) *
...а если он отключен или его нет, то уже нужна так получается? )))
Ага.
Даже если не отключен, то для проверки можно все равно поставить, чтобы не гадать на кофейной гуще. Если не заработает значит дело в другом.
Цитата(slako @ Jul 10 2012, 18:29) *
Ага.
Спасибо за инфу, он естественно отключен )) так как если бы был включен мне нужно было бы какой то там брелок к нему прислонять и т.д.
Уже месяца три пользуюсь Cisco Linksys WAG54G2.
Работает просто супер, за все время зависал один раз.
Подключал одновременно до 5 девайсов - стационарный комп по Ethernet, Киндл, нетбук и пара телефонов по WiFi - глюков незамечено.
Из недостатков могу отметить отсутствие внешней антенны, поэтому если помещение (квартира, офис) большое - то наверное будут наблюдаться проблемы в покрытии. На квартиру хватает с лихвой.
В комплекте софт - Lynksys Advisor - графическое отображение всех подключенных девайсов.
Рекомендую...
dyo999
можно ли пейджеровый пульт magic car от одной машины настроить на другую?
на обеих машинах одинаковые сигналки.
можно.
chiller
Виталик, который работает сбоку от ВАЗ центра на собирке. Огромный спец по Нивам и Калинам. На вашем месте я бы просто съездил познакомиться и посмотреть на его Нивы.
dyo999
Цитата(Alexan_Der @ Jul 10 2012, 22:18) *
можно.
Спасибо понял.
А можно провести самим манипуляцию переключения брелока или лучше к спецам?
Необязательно. Иммо может быть подключен, но не активирован. Тогда ничего подносить не надо. У меня например так.
ну у меня скорее всего так и есть, так как лампочка или мигает или горит...
Цитата(dyo999 @ Jul 10 2012, 22:26) *
Спасибо понял.
очень просто. Надо в брелке нажимать цифру один, потом надо ключ в замок вставить и поставить ключ положение 3. потом 2 потом снова 3 потом 2. И так 3 раза, и таким образом устанавливается код.
dyo999
спасибо, будем пробовать.
Провайдер Uzonline, скорость Tas-ix 2 мб, но уже месяц тасикс больше 512кб не качает,что делать,обзвонил их техподдержку,толка мало! Админы и спецы по сетями помогите??
PilotUTTT
Тоже жду улучшении
AndreVla
dyo999
Меняйте провайдера
INTELigent
Цитата(AndreVla @ Jul 10 2012, 23:01) *
Cisco зависать вообще не должен, а вот Linksys может)
Dan_19
Цитата(dyo999 @ Jul 11 2012, 00:36) *
Меняйте провайдера
Та же самая ситуация. Обидное то что, кроме узонлайна никакой провайдер не может подключить. Якобы до нашего дома проведена линия по особой как то технологии. а звонки в тех.поддержку никакого толку не дают, т.к. порой вообще не отвечают на звонки.
Dan_19
есть ли у нас мастера которые ремонтируют цифровый фотоаппараты SONY? перестала работать вспышка.
Рекомендую...
О, видел такой на ярмарке, но подумал, что у нас может работать не корректно. У однокурсницы в Казани этой марки модем стоит, пашет круглосуточно.
Пойду присмотрюсь, поторгуюсь. Надежды на 3G что то нет в связи с последними новостями. Спасибо за совет.
нужен на 2-3 дня съемник для 30-40 мм. подшипников. Может у кого есть?
У мастера их куча, но толку с них не было))) так и не смогли вытащить подшипник с генератора, скорее уже съемник можно было сломать, пришлось тупо пилить болгаркой.
CarGraphicSpecial
Напротив остановки "Аския базар" магазин цветочный, справа от него в подвальчике сидел мастер хороший по цифровикам.
Как раз там мне и чинили Sony, упал с открытым объективом ))) . офиц. СЦ сказали что ремонт будет стоит 100 баксов)) запчасть (пластмаска) ждать 3 месяца)). А этот мастер на Аские сделал за пару дней и взял копейки smile.gif.
Тоже чинил у него!
Форумчани срочно подскажите пожалуйста, я хочу купить коленвал как можна узнать сколки ходный он ? заранее благодарю
только измерением хода или наличием бирки типа 2101-хххххх или 2103=ххххххх, но я что то не помню чтобы она на них была, бери полнопротивовесный он точно минимум 213 - 80 мм
по маркировке:
2103 - большой ход 80 мм.
2101 - меньше ход 66 мм.
2121 (нива) большой ход 80 мм и вал полновесный
ЗЫ. Смайлер опередил ))
LADA-FAVORIT
Помогите вспомнить название фильма. Фильм 80х-90х годов. Сюжет: группа школьников или студентов сделали машину на солнечной батарее, машина была в форме таракана и они принимали участие в гонках с этим автомобилем.
Спасибо.
Спасибо.
HRT чтоли? biggrin.gifb:
