Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(AkaBob @ Apr 24 2013, 12:21) *
Я в прошлом году не глядя взял самый распространенный на Сергилях китайский насос. Подключил. Ну и через минуту выгорел предохранитель. Выяснилось, что насос кушает ток до 16А! А прикуриватель рассчитан на нагрузку до 15А. Обращайте внимание на это при выборе.
приличный компрессор обязан прилично кушать.
включать его в штатное гнездо прикуривателя не стоит. даже если производителем предусмотрен на конце провода соответствующий разъем. если компресор и будет работать, то в силу малого сечения проводов это будет происходить не на полную мощность(а провода будут греться). тот же Беркут комплектует свою продукцию специальными розетками("прикуривателями") с зажимами типа "крокодил" на проводах "правильного" сечения. типа такого:
я себе прикупил вот такой силовой разъем(прикуриватель), хочу поставить в багажник.
Высококачетвенное гнездо прикуривателя фирмы "PRO-CAR" (Ведущего немецкого производителя автомобильных разъемов) для подключения нагрузки на максимальный ток 20 ампер. Крепится двумя саморезами или винтами к любой плоской поверхности.
специально для включения компрессора- у меня провода не дотягиваются до левого колеса прицепа(когда дышло уже застегнуто на фаркоп).
Цитата(krokus @ Apr 24 2013, 11:02) *
Нужен планшет, работающий с симкой. Наворотов сильно не надо, просто форумы читать в основном. Какой посоветуете? Заказал бы с амазона или ибея..
И ещё где найти жесткие (с жестким ворсом) щетки для наружных (уличных) работ, шириной 50-60 см? Должен быть хороший крепёж с ручкой, чтобы сразу не сломались.
Планшет лучше покупать на Малике.
Как говорится, пощупать посмотреть...
Сейчас купите планшет китайский, потом плеватся будете... Там резистивный тачскрин, чуть ли не продавливать экран нужно чтоб чтото сдвинуть)
Советую купить тут, нормальный планшетник. Из недорогих это Хуавей - 180$ на малике...
Я себе взял Ipad 4 wifi, т.к. у меня есть телефон с вайфай раздачей и дома вайфай.
Вобщем, берите сразу хороший планшет, чтоб не жалеть о потраченных 100-200$ в пустую.
Я себе купил на сергелях, компрессор двух-камерный(вроде так). (около 60 бачей)
В комплекте идет шланг около 5м (скрученный как на шиномонтажках) и крокодилы...
похож на этот
Так же на базаре купил "клей" для шин, для проколов. Уже два раза помогло ))
DenDiesel
Цитата(zoet @ Apr 24 2013, 21:17) *
Ребят, а не охренели ли вы о таких вещах тут писать? Вы с головой хоть иногда дружите?
да, думал про такой шланг. пользую на работе)
но решил, что лишняя розетка мне не помешает в любом случае. так будет меньше отдельно валяющихся предметов в багажнике)))
То что сейчас идет проверка это никому не секрет. Я ничего не предлагал!
DenDiesel
Как-то задавала этот вопрос, но ответа в жизни не найду. Откуда качать книги для ридера? Scarlett.
Scarlett
У меня этот насос идет в комплекте с сумкой.
cleo
Цитата(Scarlett @ Apr 24 2013, 23:17) *
Хоть вопрос снят, но мож тут библиотека получше будет и для яблокоманов удобно в формате ePub книги можно скачать сразу в айбукс reeed.ru=>книги=>библиотека
kama
flibusta.net. *.mobi на киндл качаю только там.
sik
Цитата(ГОГИ @ Apr 24 2013, 19:07) *
гофру на провода где купить можно? сказали не продаётся, чо правдо?
В любом хозмаге!
lib.rus.ec
нужно 50 метров оптического кабеля для внутренней прокладки. гдеб купить? 4-6 жил одномодовый
4 волоконный кабель на стальной проволке км 620
Кабель оптический самонесущий 4 волоконный SM км 900
Кабель оптический 8 волоконный SM 9/125 LSZH км 1000
Кабель оптический 12 волоконный SM 9/125 LSZH км 2000
Кабель оптический 12 волоконный SM 9/125 км 1250
Кабель оптический 6 волоконный MM 62,5/125 км 1200
Каб оптит 8 волок SM, FP Mark 9/125 км 950
Каб оптич16 волок SM, FP Mark 9/125 км 1500
Каб оптич 24 волок SM, FP Mark км 1700
Каб оптич самонес 8 волокSM, FP Mark 9/125 км 1200
Каб оптичес самонес 16 волокSM, FP Mark 9/125 км 1700
Каб оптич самонес 24 волоконный SM, FP Mark км 2150
Патч-кордовый кабель Single-Mode, simplex 2x3 мм м 0,3
Патч-кордовый кабель Multi-Mode, simplex м 0,65
DenDiesel
Цитата(sik @ Apr 25 2013, 09:30) *
В любом хозмаге!
Если ему эта гофра нужна для подкапотной проводки, то строительная не подойдёт... Рассыпется со временем. Туарег где то достаёт!
_HaMMeR_
Последняя цифра в каждой строке - цена в у.е.?
sik
Термо нужна?
надо 2 симплекс патчкорда длиной 30 метров FC-LC или один такой же дуплекс. я так понял что 1 метр стоит 30 центов за симплекс. собссно, где можно на них приварить коннекторы и скока это будет стоить?
да, для подкапотки. да,строительная не вареант.
qwerpo
Тут
Где можно найти квартиру в Бухаре на месяц?
В любом хозмаге!
удачи!
да лан...пусть люди на свои грабли наступают, раз слушать не хотят уже наступавших))) это нормально)))
bogdan0209
Посоветуйте пожалуйста ,где в Сеуле можно купить спутниковое оборудованние????
Ну и заодно подскажите где в Сиднее можно купить факсовую бумагу????
sik
В факсовом магазине! Не?
Enigma
Блин, а тема то называется "Простенькие вопросы"!!!
Цитата(qwerpo @ Apr 25 2013, 18:42) *
спасибо, но за нал они не продают!!! sad.gif ни в какую!
kama
кто знает где продают маленькие канистры для бензина? литров на 5 нужно.
верно
коннекторы тоже приварят и протестят, более точную цену смогу дать в понедельник, так же можно по без налу smile.gif
Цитата(qwerpo @ Apr 25 2013, 19:42) *
тоже вариант, но я с ними работать не могу, очень у них всё сложно, если надо сегодня или завтра фиг чё сделают, сначала контракт и т.д., вообщем перестал с ними иметь какие либо связи
баклажка от воды чем плоха?))
behruz
в канистровом магазине
B@hus
В хозяйственных магазинах, только пластиковые с дурацкими крышками, при плотном закручивании крышки лопаются.
Если для временного хранения (до месяца) лучше 5л из под воды использовать.
я так понимаю что 1 дуплекс что 2 симплекса - это одно и то же? просто дуплес это 2 склеенных симплекса? smile.gif
kama
обычная для воды, думаю, не подойдет. пары и все такое....
пойдет. это лучше, чем пластик из хоз.магазина.
если подойдет стальная на 10л, дам на прокат. самовывоз с Паркентского или м.Чиланзар.
sik
Поле Чудес - Новыйабад! Яндекс найдется всё!
B@hus
Я периодически и длительное время вожу с собой в багажнике, в вертикальном положении, запаха не чувствуется. О степени опасности не говорю, само собой понятно.
kama
да я хочу в багажник закинуть. и он у меня маленький) чет не хочет с баклашкой ездить )
верно, и дуплекс всегда стоит как два симплекса
kama
вот потому ищу канистру. наверняка есть специальные.
behruz
в сети магазинов экспедиция есть канистры для бензина, очень симпотичные.
Авто: КАМАз
может солярочки?)
для разового употребления вполне можно воспользоваться баклажкой. это гениальная штука)
тем более, что сейчас не жарко...
kama
спасибо за наводку. яндекс говорит, что в цуме на первом этаже он. заеду посмотрю.
Koshak
Подскажите, где в Ташкенте поодаются швейные машинки зингер?
behruz
швейномашинном магазине
AkaBob
Зингер в Ташкенте вы может быть и не найдете. А вот японский Janome есть в ассортименте. По качеству не хуже Зингера - проверено!
На "Чинни базар". Это напротив Абу-Сахий.
Очень много выбора, не наших канистр.
Enigma
Плюс еще раньше на Навои в одном магазине продавали AstasJuki - скорее всего они и на Малике должны быть!
Koshak
Всем спасибо!)
