Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(OTASH @ Feb 5 2014, 14:47) *
Аккумулятор родной 2010г октябрь на зарядку ставлю на 3-4 чеса вот и крутит примерно 5 секунд знаю что аккумулятор дохлый, после завтра новый куплю, а вот проблема в чем, вед аккумулятор крутит
а кстати эта на холодном моторе не заводится после прогрева авто легко заводится
OTASH меняй аккум и всё тут! я тоже распинался в теме про аккум, в итоге FAYZ прав оказался, надо было просто поменять его...
behruz
Пешеходные переходы и остановки маршрутных транспортных средств
16.1. Водитель транспортного средства обязан уступить дорогу пешеходам, переходящим проезжую часть по нерегулируемому пешеходному переходу.
значит ли это, что если на переходе стоит только 1 пешеход (не пешеходЫ) то можно его и не пропускать
Не значит. один или несколько без разницы, должен пропустить
Говорят, что в салонах дают договора на спарки и кобы на перечёс. Кто может подтвердить или опровергнуть?
behruz
да я тож так думаю, но мне с пеной у рта пытаются доказать обратное
Кто? сотрудник по работе или гаишник на дороге при исполнении?
behruz
сотрудник в офисе
Штатная магнитола Спарка вместе с рамкой сколько стоит?
в драйверс виллажд дают договора на кобальты, сумовые позиции.
Цитата(Темур @ Feb 5 2014, 14:55) *
Масло загустевшее, мой акумм. 2013 г тоже не хотел заводится.
масло люки моли залито
да с удовольствием поменял бы с деньгами сейчас проблемы(((( (в торге новый аккумулятор от кобальта за 70000 сум продавали а я не купил((( вот сейчас сижу и жалею 4 или 5 дней мучаюсь с этим аккумулятором)
один пешеход или несколько без разницы, водитель обязан пропустить
а что стало с Вашей штатной?
Dicota
Цитата(krokus @ Feb 5 2014, 12:49) *
249-67-67, 249-68-68. У них чинил блендер пару месяцев назад. Девятиэтажка напротив мардикер-базар на Чорсу..
Спасибо smile.gif Нашли проблему, нужна одна запчасть от него теперь.
Поэтому, мож у кого есть сгоревший брауновский блендер, нужен пластиковый переходник, к которому насадки цепляются (с крестовиной, который крутится).
у меня все в порядке там пионер стоит и вполне устраивает, друг просил узнать он в сток приводит машину. Вобщем то вопрос остается актуальным пока еще.
Цитата(behruz @ Feb 5 2014, 18:08) *
сотрудник в офисе
он права купил что ли?
он пионер не продает?
Форумчани если у кого то есть фото аккумулятора делкор оригинал загрузите плиз чтоб знать какой он а то мне сейчас новый с гарантией пол года предлагают за 200000 сум
Enigma
Чисто гипотетически: может ли вода через трубку идущую от бака в адсорбер попадать в бак? Машина ласетти.
cduz
По этой же логике можно продать любого человека в рабство, потому что в УК предусмотрена ответственность за торговлю людьми (во множественном числе), а одного - можно.
Точно также можно не уступать дорогу встречной машине при повороте налево, потому что сказано, что нужно уступать "автомобилям", а не "автомобилю"
Цитата(Иван @ Feb 5 2014, 10:55) *
добрый день, у меня на работе у одного сотрудника вопрос, он женат на гражданке казахстана, брак заключался там, может ли он у нас в ташкенте ездить на ихнем авто с казахскими номерами? машина оформлена на жену
Может ввозить и ездить только гражданин Казахстана.
Временный ввоз авто до 30 дней... обычно дают на 3 дня, тем у кого нет регистрации в Ташкенте.
Поверьте мне, это не лучшее впечатление стоять на границе по 3-4 часа, чтоб получить этот долбанный лист временного ввоза...
И делают они это ооооочень медленно...
Лучше не заезжать на авто.
на кз авто... каждый гаец ваш. все кому не лень, будут просить паспорт, регистрацию, страховку.. показать огнетушитель, запаску.. посидеть в авто погреться, послушать музыку, проехаться ))) smile.gif
насчет пионера спрошу там модель толи 5150 толи 5050, оригинал но замученный, без юсб порта.
оташ нафига тебе делкор если варту тут продавали за 200000? я хотел себе купить его но изза нг праздников отказался.
Edgar
Потому как Варта та б/у, осенью брал на нексию, так же предлагали Варту и Делкор, цена одинаковая была, но Варта была годовалая, сделал выбор в пользу свежего Делкора.
А так на базаре ловкачи есть, которые берут акум Медалист, клеют на него наклейку ЖМ мейд ин Корея, ламинирут и по 270 ксум пихают.
2 Оташ, с учетом погодных условий, отличная цена.
Перечисление?
Цитата(Che Guevara @ Feb 6 2014, 10:19) *
Перечисление?
да, 2 недели назад были перечислением.
Ок, спасибо, заеду туда.
Темур
Отабек не парься, езжай на Сайрам ю.абад 19 кв. Там гарантией на год продают. На прошлой неделе на ксюху делкор 13 года, мейд ин корея ориджинал за 225 тыщ приобрел. 2 магазин от стоянки.
Вазгенжан, на учкахрамоне вчера скопление людей наблюдалось, слушок был что выдают договора, на какие точно не знаю.
был у меня опыт с такой гарантией! магазин на куйлюке мир запчастей если не ошибаюсь
напротив областного пятака не доезжая базара
купил у них батарею сказали год гарантия все такое
уже расплатился поставил и только потом они мне начали условия ставить мол каждую неделю будешь приезжать мы тебе отметку будем ставить что акум нормально работает
ладно приехал через неделю он мне мерит напрягу и говорит у тебя гена перезаряд дает,мол нужно исправить иначе акум сдохнет и гарантии не будет
дал мне адрес электрика поехал у того времени нет, забито все
поехал к своему электрику он мне сказал что у тебя все нормально, просто эти уроды хотят отлынить от гарантии и поэтому находят разные причины
а самое главное к ним надо ездить каждую неделю
выпей рюмочку какао оно мне сдалось такое счастье
кстати уже катаюсь 4 зимы на этом акуме! и все ништяк не взорвался не разряжался
зовут акум Центра
зачем ездить если можно позвонить?))) 2007070
Цитата(behruz @ Feb 5 2014, 17:08) *
сотрудник в офисе
Он полагает, что пешеходам для перехода дороги теперь нужно собираться небольшими группами )
Цитата(REDLINE @ Feb 6 2014, 11:17) *
был у меня опыт с такой гарантией! магазин на куйлюке мир запчастей если не ошибаюсь. напротив областного пятака не доезжая базара. купил у них батарею сказали год гарантия все такое. уже расплатился поставил и только потом они мне начали условия ставить мол каждую неделю будешь приезжать мы тебе отметку будем ставить что акум нормально работает.
У меня тоже был опыт покупки в этом магазине. Они предупредили, что гарантия сохраняется если заезжать регулярно к ним на контроль. Но не каждую неделю это точно. Интервал был поболее. И я у них нормально пару раз контрольные замеры проходил. Потом надоело ездить - перестал.
В Колесе аналогичная история но интервалы меньше - неделя потом месяц, потом два потом полгода. и Один фиг не ездил к ним smile.gif
Темур
4 раза приобретал акумм. с гарантией на базарах (не у сайгаков) и ни разу не подводил сам акумм. и ни замолвили, чтобы переодически проверять электролит у них.
Паспорт в москву как отправить? EMS возьмется??
Однажды была такая надобность в 2011 году - FeDex, DHL и EMS отказались, Aramex взялись и доставили, правда отправку делал в Грецию. Aramex на Сев вокзале, там оформлял.
ЛУчше подъедьте туда там на месте предметно разговаривайте.
B@hus
Летом отправлял через EMS пакет документов, паспорта в том числе. Отправлял чужие документы, на адрес третьего лица в РФ. Дополнительно к пакету писал заявление на имя начальника таможни, с просьбой пропустить документы для таких-то целей.
Спасибо!
ну значит исправился EMS.
имею аналогичный опыт(не один), от этого же магазина. периодичность "проверок"- раз в три месяца. не припомню случая, чтобы мне предъявили необоснованные претензии к работе генератора моего авто wink.gif
______________________________________________
имхо, все эти гарантии на любой аккум- от лукавого...
из личного опыта- если я купил новый аккум, и он без нареканий отработал один месяц- я могу с уверенностью утверждать, что этот акуум нормально отработает не менее двух лет. далее, при появлении первых "симптомчиков", я его просто сменю на новый...не парясь smile.gif
Где купить часовую линзу?
Сколько стоит паста ГОИ.
slako
в Микроэлектронике на Ганге видел. Позвони спроси.
Becho
Кто поможет купить и привезти 2 чехла с амазона?
http://www.amazon.com/Design-Collection-Ph...=HTC+Evo+4G+LTE
http://www.amazon.com/Importer520-Silicone...alaxy+S2+sprint
Timur1980
кстати картой Капиталбанка не получатся оплатить на амазоне.
Сотрудники банка ничего вразумительного не говорят(((
МЛЯ!!! и appstore только что прислал такое письмо:
the billing of a previous apurrchase has failed because yor payment card was declined. Please provide valid payment card information and click done to pay your outstanding balance and continue using the store
Международные валютные пластиковые карты Limited Edition. Нечего валюту за границу тратить)
Tae
прикольно, смысла теперь в этих картах, что-то не понял))
Timur1980
последнее успешное снятие было 02.02.2014 (appstore)
в это воскр они уж не смогли списать с моей карты 10у.е.
сегодня звонил друг, сказал что не может купить на Амазоне, вроде такие траблы пока только с КапиталБанком...
вот теперь сижу гадаю, накуя мне VISA GOLD, которая толком НЕ работает?!
Koshak
мне сегодня эппл такую же херню прислал, что возникли проблемы с предыдущим платежом . Я аж испугался, что деньги с карты спиздили. Вбил данные повторно и платеж прошел
Koshak
Кто знает намер телефона и какие команды отправлять для смс банкинга в промстройбанке?
slako
+998909686868
знаю только запрос $ баланса:
Раскрывающийся спойлер
Balance p:4*XXX c:840
где XXX - последние три цифры карты
нужен новый перечислением SATA ноутбучный винчестер (2,5") объемом от 80 до 250 Гб, кто знает где есть? Либо на пластик если есть варианты приобретения...
Koshak
Цитата(slako @ Feb 11 2014, 03:55) *
+998909686868
Спасибо, а что именно надо отправить на этот номер, чтоб баланс узнать?
_HaMMeR_
slako
только вместо XXX поставь три последние цифры этой карты
PS Услуга SMS банкинг должна быть подключена, если не подключал (при открытии карты), то работать не будет, надо будет топать в банк и просить включить.
