Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Enigma
Скажу так: фальшивок у нас больше чем многие думают. В том числе встречались и т.н. "суперфальшивки". Погуглите если интересно.
Цитата(alileo @ Aug 1 2014, 21:58) *
А как это можно почистить? И можно ли поставить фильтр, если да, то к кому лучше обратиться?
Цитата(puzo @ Aug 2 2014, 12:42) *
Помыть можно, есть пера специальная. Если уже завоняло, то чистить надо раза 3, и снизу через испаритель, и сверху через вентилятор. Фильтры вроде как есть на нексию самодельные
Цитата(cduz @ Aug 2 2014, 14:07) *
пузо, подскажите, где качественно можно проделать эту операцию
Цитата(puzo @ Aug 2 2014, 21:58) *
В кастроле продают эту пену, там же и почистить наверное могут. Баллончик тысяч 30 стоит, хватает на две чистки.
Хотя самому почистить не сложно, надо открутить вентилятор печки, засунуть руку в дырку, офигеть от количества листьев и мусора) сколько получится вытащить рукой, потом засунуть шланг пылесоса и почистить все внутри. После этого вдувать пену в дырку от вентилятора и снизу в дренажную трубку конденсатора.
сегодня как раз занимался чисткой печки, вобщем гемор это знатный. со стороны салона чтобы до радиатора добраться нужно разобрать всю центральную консоль(магнитола, кармашек под ней, блок управления печкой), включая металлический каркас и откручивание центрального тоннеля (обод ручки кпп, ручник и тд), особенно впечатлил "потайной" болт крышки за которой находится кожух радиатора. добраться до него не то что сложно, имхо нереально его выкрутить без какой-нибудь специальной хреновины, которая именно для этого и предназначена, хотя как по мне, единственная функция, которую он несет - это просто поднаcрать владельцем нексий) тот, кто его придумал, точно за что-то недолюбливал все человечество. crazy.gif
до чистки вентиляции из подкапотного так и не дошли руки, выгреб большущую кучу листьев со стороны салона и решил что на сегодня этого предостаточно.
не знаю сколько денег возьмут за полную чистку в каком-нибудь сервисе, но работы там дофига
VoV
Цитата(sparkv @ Aug 10 2014, 08:55) *
У кого-нить есть вот этот мультсериал:
Даша-Путешественница / Даша-Следопыт / Сезон: 1-6 + Доп.Эпизоды / Серии: 136 / Dora the Explorer [2000-2012, Обучающий мультфильм, SATRip, RUS/ENG]
нашел торрент чтобы залить через тасикс, но почти 45Гб качать - на моей скорости это проьянется до конца года)))
Буквально в конце той недели просил друга с этого форума скачать все 6 сезонов (Сергей привет!). Сошлись на том что скачает пока 3 и 4 сезоны. Когда будет готово можете скопировать у него или у меня. У меня также есть только первые два сезона. Поэтому и просил все остальные. Также есть из этой же серии мультфильм Диего вперёд.
Цитата(dimanich77 @ Aug 10 2014, 09:28) *
У меня дочка эту Дашу смотрела, я брал на дисках DVDШных, диски уже давно в хлам превратились (исцарапанные). Купите за 5-6 тыш диск двусторонний, ребенок только рад будет. Видел диски с Дашей буквально пару дней назад в магазинах по продаже дисков где магазин Светлана (м. Горького)
Ходил, спрашивал, смотрел, у всех только первые два сезона. Поэтому и попросил друга скачать.
Цитата(sparkv @ Aug 10 2014, 09:45) *
спсбо за наводочку!) если не найду на хард, загляну туды
да, мы тоже несколько магазов обошли в своем районе - нету. а одни вообще под видом 6 сезонов продавали первый и второй только(
просто дочка на "винчестеропроигрывателе" смотрит, и с двд перекатывать на хард 6 сезонов возицца надо)
Если вдруг всё же найдёте, возьмите в двух экземлярах, один перекуплю) Или скажите, пожалуйста, где нашли, съезжу возьму себе тоже)
Если кто захочет сам скачать .... (TasIX)
http://torrent.dchub.ws/viewtopic.php?t=8470371 BDRip
http://torrent.dchub.ws/viewtopic.php?t=8469748 DVDRip
У нас значит никто не заморачивается с ними, так как ходят из рук в руки. Так случайно можно попасть в другой стране в отпуске/командировке. У нас то просто не примут, а там и задержать могут.
Сколько может стоит экран и стекло сенсор с заменой на Samsung s4. На малике оценили в 180 уе. Это нормальная цена?
Подскажите пожалуйста, в том году в
октябре было лишение прав на год, сейчас взял
разрешение из суда о возвращении прав
файзиобад приехал и мне сказали придти
в четверг потому у меня есть категория Д, я буду
сдавать экзамен на компьютере или мне надо будет отдельно сдавать на автобусе еще ?
VoV
Спасибо! Там 6 сезонов?
как там зарегатся ?
будешь сдавать по любому!
с автобусами строго!, если легковушек нет в наличие, то автобус всегда стоит в файзабаде
Кто в курсе засчет плавания для маленьких детей (до года)? Куда идти, к кому, че почем и т.п.
1-42 серии . 2009 -2014г
forzeц
где у нас есть более или менее приличные нулевики кроме SCT - на фархадском нифига нет
Solnce продавал, а так конечно лучше заказать... У меня кстати где валяется Prosport б.у. )).
TATARIN
Ни кто случаем не работал в ДЕПО трамваев или троллейбусов ?
Ломка у меня ,хочу на память пофоткать старый транспорт
может хоть один остался на память ?
VoV
Увы... Но это всего 2, а может и 3 сезона. Т.к. общее количество серий 127. biggrin.gif
мож тут помогут
http://uztransport.uz/
sparkv
У мню есть торрент на тасиксе на все сезоны.
Проблема в скорости (
sparkv
Нашел того кто скачает с мира всю Дашу.
Там получаецца порядка 45 гб по 1500 сум за 1гб.
Может вскладчину закажем ему закачать?
ni1812
Ну зайди со сторожем договорись и всё какие проблемы, пустит вместе с кем нибудь точно.
Friday
City fitness на Ойбеке. Сказали что с 6 мес принимают. Сыну 4 года - начал туда ходить. Ему нравится, мне кажется слишком много детей в группе для одного тренера. Тел 150 17 17
так это...в Ургенч езжай...там до Хивы до сих пор курсирует троллейбус... good.gif
Тренер там не Валерия случаем?
Friday
ЕМНИП- Таня
Не пойдет, там более менее новые и крашеные, а ему хочется старины, именно снять с эффектом старения в нужных цветах и т.д.
+ Хорезм
ты когда их видел в крайний раз?
M@RS
я в теме, если надумаете пишите в ЛС.
Valerka
Я, конечно, педагогического образования не имею, но данный мульт совсем не впечатляет, скорее раздражает. Российские "Фиксики" интереснее и познавательнее - проверено (сыну 4.5).С другой стороны, пол и возраст имеют значение, понимаю.
TATARIN
прам в точку
Поддерживаю, но вставлю свои 5 копеек, Даша и Диего мульты для детей от 2 до 4 лет, Фиксики все таки на более старшую аудиторию расчитаны, так же как и Маша с Мишей.
p.s.
Конкретным косяком Даши и Диего считаю неправильную озвучку дубляжную, многое идет на русском тут вдруг проскакивают английские слова типа Yellow, Click, Blue, Jump. Изза того у моей дочи путаница была в голове в 2.5 - 3 года, например когда называла цвета перечисляла (интонацию постараюсь передать словами):
Кассный (красный),
Казамавый (оранжевый)
Елов (желтый) и тут было трудно переобучить
Буу (Blue Синий) тут тоже трудно было
вместо прыгай говорила Джамп и т.д..
несколько лет назад кто-то из форумчан предлагал шторку от солнца на лобовое стекло, она еще сворачивалась гармошкой по разные стороны от стекла, к стойкам.
если кто помнит где был этот пост или как найти такую штуку на али или амазоне, подскажите плиз.
уже как только не писал запрос, выдает только простые, которые надо самому расправлять и к стеклу прикладывать на присоски или петли..
p.s.
Кассный (красный),
тут dimanich77 полностью прав, этот "кривой" перевод может быть и способствует тому. что ребенок будет знать несколько слов на английском, но объяснить ему что по русски это совсем не то - довольно таки непросто.
http://www.amazon.com/Retractable-Sunshade...rds=retractable
http://www.amazon.com/Dash-Designs-Origina...554&sr=1-62
http://www.amazon.com/Eclipse-Windshield-S...465&sr=1-38
METALLIK
Такой не вариант
Кто знает почем хром пакет боковых стекол на лося? какие есть +++ ---- (про блеск-колхоз тему опустим)))
80.000 с установкой
Цитата(puzo @ Aug 12 2014, 15:32) *
Спасибо! как раз то что нужно
Цитата(METALLIK @ Aug 12 2014, 15:34) *
Такой не вариант
не совсем то, такие тож видел на али, интересовали именно те что к стойкам крепятся. но все равно, спасибо!
Koshak
они ровно не садятся. из далека норм, а вблизи г0вно полное.
Звоню в ресторан Клан Кастл по телефону 293 00 01. Отчечает, что неправильно набран номер. В справочной тоже только этот телефон. Кто-нибудь знает другой номер. Нужно срочно.
Nikifan
Укроп кто нибудь покупал/продавал сегодня?
угу...по нулям...
На жентрах хром пакет идет в стоке?...возле офиса стоял черный лось не жентра, ухоженный, долго всматривался в стыки/щели/следы наклеивания. Все отменно сидит с зазорами соответствующими. Вышел покурить позже-тачки нет. Вот и спрашиваю...заплатить 50 или 150 уе не вопрос (все зависит от качества и исполнения инсталляции). Хочу идеальные линии/зазоры/стыки.
у кого нибудь есть знакомые на файзабаде чтобы не сдавать вождение?
Koshak
На джентре не сток хром.
Сосед наклеил. Мне не понравилось. Не идеально сидят.
Подойди и договорись. Через знакомых всегда дороже
Точно, ффтопку таких знакомых.
I'm_Joker
Есть родные хром молдинги.
Есть, в смысле в наличии?
Уверень ты не пожалеешь если купишь!
где можно купить фуагра? или обычную гусиную печень
30 на 50
