Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(Dam @ Jan 13 2016, 23:32) *
Валера, горчичная паста имелось ввиду цвет (темно желтой)). Эта банка у меня до сих пор жива, но паста стала светложелтой и засохла.
laugh.gif блин, я уж думал, что горчичный порошок стал обладать абразивными свойствами. весь мозг сломал)
дис.водички налей в банку...и выдержи пару суток...оживет паста...
sabka
Так она для полировки стекол? А я ею всю машину натирал...
У меня больше ничего под рукой не было...но за@еб еще тот))
Цитата(ferteeee @ Jan 13 2016, 10:19) *
у меня одно боковое надо показать так же. имеются царапины от открывания и закрывания окна, но я чета сомневаюсь, что у нас есть мастера которые это делают.
ну и конечно же же царапины разные бывают, если будут совсем глубокие то ничего кроме, как замены стекла не поможет
Так стекла не дорогие же. доплати и поменяй боковые.
Так же и лоб лучше сменить. полировку у нас вряд ли сделают ж-руки.
ferteeee
боковое поменяю, а вот лобовое не хочется, корейское стоит еще.
Цитата(TOUAREG @ Jan 13 2016, 21:01) *
снизойдешь до Нивы, обращайся. больше 130ти я обычно не езжу biggrin.gif (шутю, если что)
Валера с тобой хоть на УАЗике хоть на таблетке smile.gif если сам один еду, но блин семейство моё, особенно вторая половина комфорт ценит, мой ТАЗ их не устраивает smile.gif
QUOTE (dimanich77 @ Jan 11 2016, 10:00) *
Нафига ему там этот Самсунг ???
Почему нет? Именно Самсон и взял. 9000 серии. Вполне уважаемая здесь марка. А учитывая что большинство производителей местные, включая Самсон, Шиваки, Тосиба, Панасоник (разве кроме Филипса, китайца) - особой разницы между марками не вижу.
В общем, спасибо, натолкнули на мысль искать по Аква-технологии.
shumbola
Пусть служит вам столько, пока не надоесть. :-)
Потому-что наши не понимают всю крутость Самсунга.
в Чимган, зимой, на пузотерке комфортнее чем на Ниве? ну вы и гурманы biggrin.gif
Капу тогда заказывай...раз супруга капризная))
зы. забыл сказать вчера...горячий чай у меня всегда есть...бонусом...
Решил поставить ссд и новый хард.
По ходу ещё решил почистить и кулер поставить новый.
Все разобрал, почистил, собрал вроде также.
Не запускается биос, блин.
Все кулера крутятся, диск шуршит, а монитор не оживает.
Уже сто раз перебрал все, батарейку вытаскивает на 30 сек чтобы обнулить биос, но нихера не помогает.
Советы?
Решил вытащить второй комп.
Переставил все кишки во второй, запустилось.
Вернул обратно, не запускается.
Самое интересное, когда во втором все подключил - он падла тоже не запускается, симптомы те же.
Теперь вместо жёсткого диска с бэдами имеем два нерабочих компа. Гадство.
Вот думаю, ноут достать что ли, раздолбать уже все до конца и лечь спать...
самый банальный вариант - отключить один из хардов. может питания не хватает?
Все отрубал.
Даже юсб и аудио повыдергивал с МП.
Потом выдернул лед хдд, подсветку кнопки и резет.
Все также.
Что убивает - один раз запустился, даже драйверы часть установил....
Потом резетнулся и все..
а кулер какой меняли? между радиком процессора и самим процем просвета нет? бывает что радиатор неплотно прилегает ( у меня даже как то было что радик до проца вовсе не дотягивался, и комп после юольшого перерыва запускался, но ненадолго.)
если проц перегревается, то он не даст запуститься пока не остынет. потрогайте радиатор(или жаже сам процессор), если печка, то вероятно запустится когда остынет.
Поставил башенного типа, который в сторону дует.
Радиатор его холодный.
Дело не в нём, после установки сразу не врубился.
Да и на втором системнике я проц не трогал вообще.
Дело где то в МП и этих переключениях.
Цитата(RED BULL @ Jan 15 2016, 03:02) *
Там 2 планки, одна на 4, вторая на 2 Гб.
Попеременно вытаскивал, протер контакты.
Что еще делать хз.
С утра еще раз перемкнул джампер обнуления БИОСа, один комп завелся.
Сбросил настройки на дефолтные, вроде запускается.
Второй молчит. Буду дальше ковыряться...
Nikifan
Что еще делать хз.
проц из сокета не вытаскивали?
Блин очень сложно так не видя проблемы понять в чем причина. Видяха есть внешняя? Есть есть попробуйте и без нее запустить.
расскажу вот что , есть комп на работе серерон е1400 вроде как на 2000 мегагерц, на нем нельзя было даже в контр страйк играть тупил безбожно грелся чуть ли не до 100 градусов хотя кулер стоял, а по факту не был при жат вообще, к резетам это не приведет комп будет просто такты пропускать чтобы не сгореть и все, потом поставили другой проц, разогнали в полтора раза и кулер поставили как надо, все забегало. сейчас еще планку китайской ддр2 на 2 гига поставили, правда видится всего гиг
Советы?
контакты. я тут делл прокачивал проц поменял на е7600, так эта шняга брендовая как не выделывался прежде чем запустился
Цитата(RED BULL @ Dec 28 2015, 17:05) *
Какой штраф за перевозку детей на переднем сидении???
Не смог найти коап и штраф
Оплатил 65,200сум.
Цитата(Hobbit @ Dec 28 2015, 17:22) *
в явном виде нет, но влегкую можно притянуть
1 Минималка сейчас ЕМНИП 130 тыс
dyo999
Блок питания пробовали менять?
В 90% подобных случаев во всей моей 10 летней практике умирали блоки питания.
Becho
Сможет ли поднятся сейчас УАЗ или Нива на гору Кизилджар в Чимгане, где стоят антенны сотовых операторов?
Хорошая идея... Чет не подумал про БП.
shumbola
Подскажите грамотного мастера по ремонту планшета/телефона. Необходимо починить USB порт.
Планшет 8", АСУС, один раз уже делали, рядом с ст.мт. Хамза, отвалился. :-(
Знатоки английского, подскажите пожалуйста. Как на английском обозвать термопленку на лобовое стекло, для обогрева зоны дворников?
Никак на ебае найти не могу.
http://www.ebay.com/sch/i.html?_odkw=therm...de&_sacat=0 оно?
Нее...
Нужно название пленки, которое клеится внутри на зону дворников и нагревается.
shumbola
Цитата(Maksim @ Jan 17 2016, 18:20) *
Нее...
Вот
Ключевые слова: windshield wiper de-ice defrost heater и т.д.
Вот еще
Спасибо всем drinks.gif .
Но все равно не получается на ебае найти вот такое: http://www.solina-avto.ru/nagrevatelnyi-ye...5sm-sht-10.html
давай с солины закажем, там очень адекватный манагер. я ж там зеркала свои брал. на 12ти вольтах тоже есть такая мармелад один вопрос...нафуа оно тебе надо?))
Мне то не надо. Хороший знакомый попросил заказать. А мне что то влом с рос. менегарами переписываться по таким мелочам. Хотел с ибея заказать. Там все автоматом. Тебе на солине надо чего? Тогда можно и с солины.
MachoPichu
Ребят, помогите, пожалуйста, найти песню по видео! Там маленький кусочек, я не уверен, что это узбекский язык, но похоже! Видео смотреть с 7:41
http://topasnew.ru/3225-borodach-1-seriya-...onlayn-tnt.html
ЗАРАНЕЕ ВСЕХ БЛАГОДАРЮ !!!!
cduz
Максим, вот тут есть:
http://www.frostfighter.com/clear-view-fro...-defrosters.htm
Надо нажать Add to cart, чтобы увидеть цену. Цены негуманные. За двойную полоску 97 баксов )))
Спасибо. За такую цену, думаю знакомому не нужно.
Уже заказал и оплатил с Солины. За 2 полоски 4 бакса. Импортозамещение biggrin.gif .
Цитата(alileo @ Jan 13 2016, 21:30) *
Попробуйте найти контакты чимганского Скай Вилладж, на той неделе знакомые ездили туда на заказанных через эту организацию машинах - Ласетти и Кобальт. Одна машина - 300 тыс. туда и обратно. К сожалению, у меня нет этих контактов.
+998901875904 Шахиста. Можешь сказать что от Искандара Ясмина-тур (то есть от меня).
VoV
Скажите, пожалуйста, часто вижу что люди привозят новые смартфоны из-за рубежа и они обходятся дешевле чем купить здесь (на малике).
Кто знает во сколько обойдётся телефон Samsung Galaxy Note 4 (Gold) новый если привезти его сюда? И есть ли какие-нибудь "подводные камни"?
Заранее благодарю за ответы!
А какие могут быть подводные камни? В декабре привозил 2 новых телефона Самсунг Гэлэкси А5. Правда не знаю дороже здесь или нет. Брал в Москве по 20000 рублей.
подниму еще разок тему портативных радиостанций. На днях столкнулся с такой проблемой:
у меня ТЛКР 80 Экстим мотька. У друзей баофенги 888. Попробовал сконнектить по прописанным каналам. Нифига подобного. Сбросил на мотороле субкоды на нули-та же байда.
В прикрепленном файлике сетка поканальной частоты для двух девайсов и по ней видно, что дефолтная заводская сетка идентична с 1 до 7 канала. Объясните мне тупому, почему рацухи не слышат друг друга???
зы. Разбираться по конкретно своему случаю буду с Искандером (Zeus), но хочется послушать мнение др форумчан....
Через комп частоты смотрели?
еще нет, завтра надеюсь глянем. Сам подозреваю-либо бао криво прошили, либо на моте сетка слетела(((
VoV
Цитата(SKULL @ Jan 19 2016, 13:48) *
Андрей, спасибо, на алиэкспрессе видел, цена выходит в районе 450-480 (если брать новый). Здесь на малике выходит почти также ~ 480.
Поэтому и спрашивал где именно люди покупают дешевле и потом продают здесь по цене ниже чем на малике?)
Максим, пока я тоже думаю на счёт привезти из Москвы, так как на одном из интернет магазинов (с учётом нынешнего курса в России) выходит примерно 400.
Поэтому и спросил, возможно люди привозят откуда-то из-за рубежа (ОАЭ или ещё откуда) и хотел сравнить эти цены ("из-за рубежа" vs "из Москвы") biggrin.gif
А еще привозят аппараты похожие на бренды. Внешне - копия Гэлекси или Айфона. Вот они в разы дешевле.
VoV
Я брал Самсунг А 5 в Москве, по одной простой причине. Там официальная поставка таких моделей с 4G и с двумя симками. У нас же официальная поставка с 1 симкой.
Как вариант купить из Кореи или США, минус - скорее всего будет отсутствовать русский язык.
из возможных минусов - есть 1% вероятность того что могут не заработать некоторые функции, как то смс на русском, либо еще что-нибудь, даже после перепрошивки.
особенно если телефон изначально был для "внутреннего рынка" кореи, так что лучше юса)
QUOTE (Талгат @ Jan 19 2016, 21:39) *
А такое разве еще бывает на Андроиде?
Еще как. Русский язык есть на всех последних моделях HTC и LG, а с самсами засада.
