Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Олеся Сергеевна
Цитата(Олеся Сергеевна @ Jun 21 2016, 12:14) *
Футбол наверное.
Ураза началась
Becho
Всем добрый день. Подскажите какие модели магнитол 2din поддерживают штатный пульт на Lacetti? Кроме заводских конечно же.
Никакие. Для всех нужно что-то переделывать. Либо покупать отдельно адаптер для связки конкретной модели авто и определенной маркой магнитолы.
sparkv
Подскажите, к кому обратиться с "закусыванием" передачи при переходе с первой на вторую скорость на спарке. Читал, что это "семейное" у спарков.
В моей магнитоле два вхола на пульт, один из них позволяет обучить голову. Вход работает с пультами на руле резистивными если правильно слово помню. Т.е, те, у которых сопротивления внутри.
sparkv
Хде мона купить диод вот такой
Маркировка SR 260 M.I(или 1)C
Да в Регалисе, если он еще жив. Скажите - диод SR260. Либо его найдут, либо аналог.
sparkv
Спасибо!
А енто где?
krokus
Цитата(sparkv @ Jun 29 2016, 18:46) *
Спасибо!
А енто где?
Слева от Чиланзарского торгового центра, напротив чиланзарского ОВИРа.
В гугле есть координаты и номер телефона.
sparkv
Не у кого не было прикола, что магнитола от лося новая которая, мигает сикьюрити а мафон сам не фурычит, предохранитель целый.
Ребят ни у кого нет бу харда на нетбук асер , пофиг какой обьем , куплю, человеку одному помочь хочу, на новый у него денег нема.
джентра не экспортная? иммобилайзера нет?
krokus
Может код какой надо ввести? На первых нексиях, на магнитофонах "танк" была такая фигня, если питание временно пропадало..
может здесь есть ответ? http://lacetti.com.ua/ipb/index.php?s=&...st&p=313809
IRON
Код вроде был, 12 что ли.. В книжке должно быть написано.
Alex_K
Народ, такой вопрос: нужно выехать в казахстан на машине, оформленной на фирму, что нужно иметь с собой, что бы наша таможня оформила временный вывоз и выпустила? доверенность, путевой лист или что то еще?
dyo999
есть 320 гиговый нетбучный хард.
Dr.Akula
AkaBob
У нас это делается так:
1) Письмо-приглашение от принимающей стороны.
2) Приказ о командировании, ссылающийся на письмо-приглашение + цели и задачи командировки. Для водителя - с указанием машины.
3) Командировочное удостоверение для каждого командированного с отметками: убыл из, прибыл в, убыл из, прибыл в.
4) Через бухгалтерию надо оформить официальные командировочные расходы
5) С собой желательно иметь удостоверение личности сотрудника фирмы с печатью и подписью директора
6) По возвращении обратно командированные должны написать отчет о результатах комадировки. Может понадобится для бухгалтерии, чтобы закрыть расходы.
И для водителя как обычно: доверенность, путевой лист и т.п.
Лось обычный, последний сборки. Имо и прочего нет. Мастер говорит не оживить его sad.gif
Он не подает признаков жизни, только диод красный на нем моргает, сикьюрити написано
IRON
Его уже вытаскивали проверяли? Может там просто тот провод что питание даёт, когда ключ поворачиваешь, оторван?
контейнеры с запчастями от нашемарок на машинном базаре в Сергили по будням работают?
IRON
Знаю многие пользуются или пользовались датчиком Altonika VG-64
Такой вопрос, его обязательно ставить между сидений и только лёжа или можно и боком или немного сдвинув под одно сиденье?
Смело езжайте работают окромя сегодня
еще вопросик нарисовался по ходу дела.
где поближе к центру можно ГУ поставить какчественно и недорого?)
сам бы поставил, но чет со временем завал, а шарманка валяется зазря, жалко)
AkaBob
Качественно и не дорого ставят водители на свои авто. Остальные - либо дорого, либо на скрутках.
Наши мастера даже об обжиме проводов имеют смутное представление. Ну а пайка - это космические технологии. smile.gif
так это ж вобще бесплатно)))
я к тому, чтобы плата за установку была разумной, а не как за инсталл для шоукара)
вариант сергили-стоянка на скрутках вобще не катит..)
Продаются же переходники. Для ласети и кобальта точно есть, возможно и на нексию тоже. И никаких скруток и прочего колхоза.
какая цена по вашему разумна? если в пределах 100 килосум - дам контакт на пионерской.
AkaBob
Это не бесплатно. Инструмент, расходники и время.
Зато в плюс идет личный опыт.
Уже два года бывший "Пионер" у меня в сервисе находится.
Также как и раньше устанавливают акустику и сигналки.
+998 98 I28I279 Улугбек
Надувная кровать односпалка, кто знает где и почем продаются? Насос у них в комплекте идет?
Или может кто в аренду дать на след неделю?
Цитата(TOUAREG @ Jul 7 2016, 20:50) *
Каремат, как и палатка и рюкзак, у самого есть,тут для культур мультур надо, дети спать будут на даче.
детей с детства надо приучать правильно спать)) а правильно(не дома)- это на каремате))
а матрас...это такая какаха...как вспомню, так вздрогну...впрочем, детЯм обычно нра))
Поддерживаю на все 100, но жен не переубедишь.
Нужно переставить и заправить кондер бк фрионом, подскажите мастера пожалуйста
Sony PS4, XBox 360, Nintendo - что лучше для мальчишеских игр (до 6 лет) и с точки зрения наличия периферии?
PS4. Только игры покупать придется.
Friday
Столешница на кухню - акрил или кварц?
Посчитали, что кварц на 80% (почти в 2 раза) дороже
Кварц базара нет красиво добротно
Акрил вот уже как 2 года режем кладем с плиты хоть бы хрен
рад что не переплачивал имхо
Enigma
С учетом того, что это в БКК и плюс мальчик до 6 лет, то лучше Wii или Xbox с кинектом. Хоть активность будет, а не геймпад только. Только у Wii графика так себе, зато цена очень дешевая уже.
Friday
Странно. Вроде акрил должен царапаться и оставлять следы от горячего. Может у вас кварц?wink.gif
Edgar
Берите акрил, все равно вечно не будете пользоваться. У меня 8 лет стоит дсп ламинированный (старые технологии), там тут взбухдо уже, на рабочих зонах протерся, но он и не дорого стоит, еще через годика 2, добьем и поменяю столешницу, Что то новенькое и свежее, одно и тоже надоедает ведь...
да не, акрил вроде , хотя встала она мне (весь кухонный гарнитур) по цене почти как машина 2108 laugh.gif
в итоге не найдя готового - купил разъем на сергилях и сам сваял переходник за 15 минут.
в сумме заняло 40 минут времени и по деньгам 10 тыс, из них 2 - за стоянку)
всем спасибо.
