Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
сколько будет идти посылка с москвы если отправить почтой россии?
Morpheus
где то 3 (+/- 1) недели
Если отправлять сейчас, или отправили недавно - скорей всего будет идти дольше чем обычно, т.к. из за праздников почты перегружены.
METALLIK
Приветствую форумчане. Подскажите где в Ташкенте можно приобрести подарок для солидного человека. Интересуют мечи и сабли. Как на картинке например.
99% мечей и сабель/шмабель - китойский ширпотреб. Купите лучше хороший нож. Например Российский. На шахристанской в охотмагазине есть отменные экземпляры около ляма ценой.
METALLIK
Где этот китайский ширпотреб посматреть можно, есть магаз может какойнить
некоторое время назад видел всякие сувенирные сабли/мечи в цуме, а так же, как вариант, позвоните(чтоб зря не кататься) в Арт хаус, возможно у них есть что-то по вашему запросу.
В свою очередь спрошу. Где можно посмотреть нормальную мужскую кожаную одежду? Ценник не главное-нужен хороший выбор моделей. Ипподром не поеду....
Гляньте в Mexx.
Урикзор, блок над стройматериалами, кажется 3й, 2 этаж, есть всякие япономечи сувенирные
Авто шевролет матиз, 3 цилиндровый, простушка 2015 года выпуска, пробег 70000, расход 8 литров из за каких причин может быть такой перерасход? тянет отлично нечего не троит, бензин 80, пробавал залит 91, расход наобород увеличивается, клапан регилировку делал 0.15 .Инжектор чистил, бензонасос менял стоит от некси какой -то там с обраткой, оригинал свечи менял пробег на нем примерно 15000км. свечные провода родные, в воздушном бачке огранечител не убирал но Допалнительный бачок установил
AkaBob
Пока электрику зажигания в порядок не приведете - все прочее бесполезно. А вдруг у вас пробита крышка трамблера или там контакты все в окислах? А вдруг клеммы на АКБ или масса на двиге заросла окислами? Все проверьте (катушку, в/в провода, свечи, бегунок, крышку трамблера, окислы на всех высоковольтных контактах...), почистите и смажьте силиконовой смазкой. Поставьте свечи не абы какие, а которые положены по каталогу производителя. А вот если не поможет, тогда будем искать дальше.
На улице май месяц?
Проводка вся новая, авто ведь новое. Кроме сигнализации, магнитолы и туманок ни чего не трогали. Трамблера нету, АКБ новый. заводской АКБ мусор - умер. Спасибо за помощь
Цитата(SKULL @ Dec 22 2016, 12:43) *
На улице май месяц?
Ок, я Вас понял. Огромное спасибо за помощь
Воздух фильтр что?
Ты точно понял, что щас холодно и расход возрастает из-за этого.
Поступает холодный воздух в цилиндры и поэтому впрыскивается более богатая смесь.
Мне нужно здесь оплатить счет в РФ в рублях, в банке я могу оплатить суммами? Или мне нужно переводить в рубли/доллары? Или как выгодней? Подскажите пжлста, а то я с этим не сталкивался.
AkaBob
В банках вы можете оплатить в долларах или евро через международный денежный перевод типа "Золотая корона" или "Unipay". Также вы можете открыть валютную карту типа Visa и платить с нее. Если у вас нет иностранной валюты, то как вы собираетесь платить? Сумы пока не конвертируются без особой на то причины.
Admiral
Где можно купить чернильное перо?нужны наконечники.ручка - не вариант
А как же закон сохранения энергии? Больше энергии сгорания - меньше жмем тапку. Я думаю зимой повышенный расход топлива только изза прогревов, стоянки с работающим двигателем и пробуесовок в гололед. ИМХО.
При +30 и больше двигатель быстрей прогреется и выйдет на рабочую температуру, чем при минусовой или 0+.
Когда двиг стоит прогревается и работает на холостых, тратиться на много меньше топлива, чем ты на холодный двиг будешь давить тапку и крутить его.
По себе знаю, короткие поездки = повышенный расход.
Двигатель не успевает выйти на рабочую температуру и происходит усиленная топливо подача.
Пример Captiva: до +94 считается прогревочным режимом, как только переваливает эту отметку, в 2 раза впрыск уменьшается.
Цитата(emil @ Dec 23 2016, 10:18) *
Воздух фильтр что?
Вот этот бачок установлен. А с завода вместо него стоит гофра и рядом в бачке стоит какой то воздушный ограничитель. Так он там сейчас стоит. Я его не убирал
Да. Я вас точно понял. И за подробное объяснение огромное спасибо
AkaBob
Есть ровно противоположное мнение. Имеет смысл прогревать двиг до +30 (стрелка ОЖ поднялась до первой отметки) и ехать. Потому что под нагрузкой двиг быстрее нагреется + вы уже проедите какое-то количество км. После +30 масло вполне работоспособно.
не так давно в "главной дороге" вроде проверяли расход и время прогрева до рабочей температуры . сравнивали прогрев на месте, недолгий прогрев и движение с малой нагрузкой и начало движения сразу, без прогрева. ЕМНИП предпочтительней 1й вариант оказался.
ЗЫ
Простенький вопрос - где есть ровнорукий мастер? нужно колесным болтам-секреткам 2-4 мм спилить/сточить не испортив остальную резьбу и головку.
методы большинства "усто" да и отсутствие кривизны рук вызывают большие сомнения.
В каком банке лучше всего открыть счет для того чтобы на него постоянно поступали деньги ? Деньги будут поступать от продажи вещей
Цитата(Hobbit @ Dec 26 2016, 14:52) *
......методы большинства "усто" да и отсутствие кривизны рук вызывают большие сомнения.
Может наличие кривизны и отсутствие инструменто-навыка)))?
Если честно не понял всей сути поставленной задачи. Раньше бы я сделал примерно так-закрутил болт в тиски, навернул на него гайку, отпилил лишнее, скрутил гайку, чтоб выровнять резьбу. Сейчас видать так не по феншую?wink.gif
AkaBob
Ну и что? После выпуска этой "Главной дороги" вся Сеть кипела возмущенными постами мотористов и карбюраторщиков. И дело тут вот в чем:
1) Из вузовских учебников давно известны фазы прогрева двигателя, которые прямо зависят от температуры масла и прогрева смеси в коллекторе. После прогрева до +10-30 градусов (зависит от допуска масла) вязкость масла практически никак не влияет на работу двига. Другое дело, что у разных двигателей разное устройство водяных и масляных каналов. Поэтому один двиг вполне может ехать при прогреве ОЖ до +20 градусов , а другой должен прогреться до 50. Иначе масло не успеет согреться. В любом случае фаза прогрева двига завершается, когда у вас падают ускоренные прогревочные обороты.
2) При прогреве на ХХ двиг в любом случае тратит много бензина. И при этом машина не едет. После прогрева на ХХ все равно надо будет потратить бензин на езду. Получается формула: расход = бензин для прогрева + бензин на езду на прогретом двиге. А если вы едите на полупрогретом двиге то формула будет такой: расход = бензин для минимального прогрева + бензин на езду в режиме прогрева + бензин на езду на прогретом двиге. При езде/нагрузке двиг прогревается гораздо быстрее.
Так что авторы "Главной дороги" попросту наврали.
VoV
Я поступаю также, т.е. завожу машину, обороты примерно 1200-1300
Жду несколько минут, пока обороты не упадут до 1000
Начинаю движение в спокойной манере (до 2000-2500 оборотов), пока температура двигателя не придёт в "норму".
Далее уже движение зависит от обстоятельств вокруг машины, либо продолжаю в спокойной манере, либо позволяю двигателю раскрутится более 3 000 оборотов biggrin.gif
Поступаю так независимо от времени года на улице, т.к. время года само влияет на время ожидания падения оборотов до 1000, т.е. от 1-2 минут летом, до 5-10 минут зимой. wink.gif
ЗЫ
могу на токарном станке сделать. в личку.
sparkv
Здравствуйте!
Подскажите, какие нонче тормозные колодки на спарк вперед кашственные.?
Цитата(sparkv @ Dec 28 2016, 01:33) *
Здравствуйте!
GM
sparkv
Цитата(Талгат @ Dec 28 2016, 09:24) *
GM
Спасибо. А примерные расценки не подскажите?
На холодный двигатель не много ли оборотов, на холодный мотор обороты должны быть минимальны
Здравствуйте!
На счет GM незнаю, но колодки super q удивило. Подделок на базаре навалом. Продают оригинал под ориганал. И китайский супер o - их тоже два вида
AkaBob
Здрасте! Пока масло не прогреется до +10-30 градусов двиг физически не может нормально работать на обычных/пониженных оборотах ХХ, поскольку мало гуще нормы. А кроме того, двиг должен генерировать оптимальное количество тепла для достаточно быстрого прогрева.
Строго по учебникам оптимальными прогревочными оборотами считаются обороты, в 2 раза превышающие стандартные. Т.е. если у вас нормальный ХХ 650 об/мин, то прогревочные будут около 1300 об/мин. А если у вас нормальный ХХ 950 об/мин, то прогревочные обороты будут 1700 об/мин.
На старых карбюраторных Pajero 2.6 в мануале указаны прогревочные обороты аж 2350 об/мин. Не верите? Вот ссылка: http://autoremka.ru/carburetor-adj/regulir...pajero-2-6.html
А вот вам вопрос на засыпку: При каких оборотах прогретого поршневого ДВС происходит минимальный износ пар трения? Понятно, что все двиги разные, но можно сказать примерно.
VoV
Оташ, когда заливал масло Манол, обороты на холодный двиг, вообще были 1400-1500, после перехода на Петронас, стало 1200-1300. biggrin.gif
Так что минимальны (700-800) они когда двиг прогреется до "рабочей" температуры.
Elix
Около 200 000 сум
а кто скажет главную причину перерасхода топлива на непрогретом двигателе? Ну типа вопрос из ряда "возьми с полки пирожок", гугл мало что говорит по этому поводу (проверил, чтобы уравнять шансы). biggrin.gif
Мать моя женщина... Оташ, ты после запуска ДВС при низкой температуре всегда держишь обороты на минимуме (т.е. на уровне ХХ прогретого двигателя)?
Вы еще послушайте новомодный совет "после запуска ДВС в холодное время надо как можно быстрее начинать движение, ведь при нагрузке ДВС прогреется быстрее, а при ХХ он работает наизнос, ведь масляная плёнка со стенок цилиндров смывается бензином" good.gif
chiller
Вопрос скорее к ИТшникам:
Подключил дома безлимитный интернет, родители живут в другом районе и тоже имеют дома интернет, но с лимитом трафика. Можно ли как то связать компьютер дома с компьютером у родителей и чтобы они пользовались моим интернетом?
Помню мне в институте про VPN рассказывали, он мне не поможет? Ведь трафик от родителей до меня будет как tasix.
У меня на всех инжекторных автомобилях при прогреве всегда 1000 оборотов стояло, а как прогреется на 800 оборотов спускалось
Можно. Для этого нужен хотя бы один "белый" IP-адрес.
AkaBob
Тут нет секретов. Причина в испаряемости бензина. Чем он холодней, тем хуже смешивается с воздухом. А чем хуже смешивается, тем хуже горит. Для того чтобы получить то же соотношение 1:14,7 холодной смеси, которое эффективно сгорит, надо обогатить смесь до 1:7 - 1:12 (зависит от температуры пуска двига). Вот вам и расход.
Самое забавное в ДВС - это не холодный запуск, а оптимальная температура прогретого двига. 80-85 градусов считается самой "экологичной" температурой, когда образуется меньше всего NOx. А самой высокоэффективной температурой считается 90-95 градусов, когда горящий бензинчик отдает максимум энергии. Теперь сравните с тем, какой термостат у вас установлен. Небось на 82 градуса....
Ха-ха-ха!!! "Быстрота" нужна при ловле блох. Это самое "холодное время", когда можно без последствий заводить и сразу ехать, ограничивается летним периодом, когда по ночам температура выше +20 градусов. smile.gif
Скорее плохое смешивание - это уже последствие. Вообще есть такая ерунда - бензин в холодном ДВС стремиться оседать на стенках цилиндров, сгорает соответственно плохо и факел неправильный. Сторонники "быстрого старта" (в смысле без прогрева) объясняют свою теорию тем, что ДВС в это время работает без масляной плёнки на стенках цилиндров (типа бензин смывает) и лучше уж быстрее его прогреть под нагрузкой, чем допускать работу в таком режиме, но это не верно, т.к. нагрузки возрастут в разы (следовательно и последствия). Есть и другие причины, с топливом не связанные, но не об этом тут ))).
QUOTE (AkaBob @ Dec 30 2016, 14:58) *
Температура двигателя где? В цилиндре? Или рубашке охлаждения? Или в районе термостата?
Вот, например, у Хонды Прелюд, на двигателе H22, номинальная температура охлаждающей жидкости - 105 градусов. Тупые японцы?
Честно сказать, я очень сомневаюсь, что +/- десяток градусов температуры охлаждающей жидкости могут повлиять на процес сгорания в цилидре, где температура порядка 600 градусов.
В точку. На уазе по бк мгновенный расход встает в нормал при 75 градусах, хотя "идеальная" температура двигла 95.
Что ты тут заливаешь какие нах 1000 оборотов , да никакой современной комп не даст такого сделать, да и древний впрочем тоже. И на горячую про 800 я соневаюсь.
Тазы я грел всегда, матиз не грел часто, после зиму матиз стал подъедать масло, хотя там пробега чуть больше Сотки было. Нексию грею. Да расход увеличивается, Зато мотор себя лучше чувствует.
Я свой аппарат грею пока ворота закрываю, заслонку тяну и ползу потихоньку.
Я для себя сделал вывод что буду греть, причём на месте до подъема стрелки до белой зоны потом на первый передаче не спеша где то 1км до основной дороги еду потом уже начинаю поддавать газу.
Когда ремонт делали двига? Помнишь заводили у меня. Вот только думаю кольца перекинуть.
У кого есть возможность скачать 4,1 Гб?
