Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Dan_19
Цитата(TOUAREG @ Sep 15 2012, 22:48) *
а что, промежуточные реле отменили?
а можно подробнее? честно я не очень то и разбираюсь в этом. но сделать этот стенд поэтребованиям все таки придется....
А данном случае реле и что либо на контактах не пойдет. т.к. нужно не включить двигатель а управлять им (по моему это разные веши)
нужно будет на семисторах изготовить модуль к этому устройству. И практически у вас будет привод на 2.5 кВт.
з.ы.
Кстати двиг постоянного или переменного тока?
з.ы.2
Если не секрет где Вы учитесь?
з.ы.
з.ы.2
разве "включить" не есть "управлять"? rolleyes.gif ок, я понял, о чем вы. просто глядя на картинку, я увидел*380в*, и сразу подумалось о трехфазном асинхроннике. ну а там уже все просто: модуль управления на 2А-промежутка-пускатель.
зы. чем проще управление, тем надежнее система. имхо.
Ну в любом случае подождем ответа автора. А там дальше видно будет. Что ему нужно и как это можно реализовать...
Dan_19
з.ы.
з.ы.2
постонка тип 2нп-112 ухл1, 2,2 кВт, кпд76, 1500/4000 об/мин.
и генератор асинхронный типа и41 у4, 3,2 кВт, кпд76, 1500 об/мин.
p.s. учусь в политехе, факультет энергетики, кафедра электротехники, электромеханики, электротехнологии
скажу так сначала надо запустить стенд чтобы он работал в нормальном режиме, то бишь запускался и происходило регулирование сокрости в ручную исполнительными механизмами, потом надо сесть подумать и решить каким образом делать регулирование, на своем стенде я мечтал о сифу а у тебя оно тут есть, и еще обязательно спросят про защиту от перегрузок попробуй и ее реализовать
dimoon
Собственно есть бытовой прибор (кофе машина) на 110В (подарили из Штатов) хочется подключить в нашу электросеть. Какие есть варианты?
Dan_19
ок спасибо!!! для начало этим и займусь!
p.s. спасибо всем!!! а то как ежик в тумане )))
приборка от нексии2 N150 одинакова для всех моделей двигателя сонс донс разницы нет ?
Имеется ввиду не внешний вид а подключение . и каталожные номера .
нет, разницы нет!
Приборки разные, но можно ставить от СОНС на ДОНС. тут в давно заброшенной теме я тоже интересовался приборкой
то есть , у нексии 2 хоть приборка на вид одна и таже все равно есть различия ?
ViktorCH
Есть спец.переходники. У меня вот такой.
DenDiesel
У нексии 1- Спидометр подключается с помощью троссика.
А у нексии 2- электронный. Причем на первой также есть выход для электронного спидометра. Надо знать где он находится.
I'm_Joker
Цитата(DenDiesel @ Sep 16 2012, 17:31) *
У нексии 1- Тахометр подключается с помощью троссика.
А у нексии 2- электронный. Причем на первой также есть выход для электронного тахометра. Надо знать где он находится.
Поправка спидометра.
Штекера идентичны, но есть разница между жонс и сонс тахометром. Разница решаеться припайкой 5w лампочки на тах в нагрузку smile.gif
dimoon
У меня такой тоже есть, но он на 50w, а кофеварка на 1100w.
у меня на работе гдето валяются адаптеры. типа как на лептопах. только с 220 на 110, если я правильно понял. гляну если не забуду. они ли.
dimoon
Буду признателен, только он должен поддерживать нагрузку 1100w
INTELigent
Встанут ли эсперовские сидушки в матизку, ну хотя бы передние rolleyes.gif ?
ARI100KRAT
при желании...... biggrin.gifb:
FARA BLACK
Нужен комп по перечеслению.Есть на форуме кто занимается этим?
Акмаль (Pro_SK) вроде занимается.
unknw.gif в каталоге на Н150 посмотрел даже, похоже различий нет. Возможно на второй нексии что то поменяли
DenDiesel
видел такие приборки на некси 1 также и на райсере
Артему обратитесь Strelok
INTELigent
Никто не знает, полики НЕ комплектом где продают? Ищу водительский на матизку. спасибо
Strelok
tashboss
нужно из Турции (Анкара) отправить в Ташкент посылку весом примерно + - 200 кг, кто знает как это можно сделать? Нужен не дорогой вариант, узнавал карго слишком дорого.
Попробуйте Pilot Air
У меня с ними получалось неплохо. Проавда, из США. Есть представительство в Узбекистане.
ViktorCH
ну не знаю, у меня все эл.приборы из штатов через него работают)))
На сереглинском базаре б/у коврики валом валяютса кто покупает новый и они постоянно выбрасывают
tashboss
спасибо
помогите соориентироваться в цене...
ВАЗ 2106, 87г.в.
моторчег-03, свежеоткапитален...
ВАЗ 2106, 87г.в.
2400-2800 : )
Если за дешево отдашь Шеф, Оташ заберет : )
Дешево это штука : )
адаптер такой. на 100 ватт
это инвертер. на частоту посмотри)))
что не правильно делаю?
старенький хард аташный. на работе воткнул в комп. там он сразу определился. все нормально.
дома не могу на сата его поставить. в свободный разъем ата шлейф втыкаю. его к харду, питание. перемычка стоит на 3-4.
моя система ошибку выдает "NTLDR is missing"
+ еще один хард саташный. он то определяется то нет. но он сам по себе битый. как с него инфу вытащить?
комп ее видит на этом харде, но копировать отказывается. машина висит...
Походу на этом харде есть системный раздел и комп пытается загрузиться с него, но не находит системных файлов. Поменяйте приоритет загрузки в БИОС либо переставьте джамперы в положение "SLAVE".
ВАЗ 2106, 87г.в.
Каждый воскресения выхожу на базар цены от 3000$ до 4000$ если кузов в отличном состояние
сколка километров надо обкатать двигатель?
kama
после мойки на ходу стекла сами подыматься стали. опускаю, через минуту опять подымаются и так все дорогу? что за чудо, кто знает?
ARI100KRAT
воды залили скорее всего, лучше к электрику и побыстрее а то коротнет еще...
если Маджик стоит 1 и 4 вместе нажмите на 1 сек!
dyo999
Сколько стоит руль от ласети 1-позиция ?
INTELigent
На фархадском, если не ошибаюсь, в районе 220 тыщ за подобные рули просят...
dyo999
спасибо за ответ
талгат спасибо!
Кто-нибудь связан с МИДом? Хочу подать официальную жалобу на одно из наших посольств. Обратная связь на www.mfa.uz выдает ошибку.
не хорошийи пля...
не хорошийи пля...
Надо вам написать жалобу в 2 экземплярах. Отнести в канцелярский отдел. Одну копию сдать. А на второй пусть распишутся о получении. В течении 10 дней ждем ответа.
А что случилось то?
krokus
Кто знает, в какое время обычно поезда и электрички проходят через переезд на Сельхозе? Или точного графика нет?
В ближайшее время надо будет быстро до Кадышева добраться с ЮА. Засекал время днём-через Паркентский 25 минут, а по бетонке 15 минут. Но по бетонке есть две помехи-переезд и кортеж. Если на них попадаю-теряется много времени.
