Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Nikifan
del.
Цитата(Nikifan @ Oct 14 2011, 23:44) *
В общем в ответ всем кто там был уверен что на нексии нельзя добиться отсутствия люфта руля на скорости.
Сегодня решил заняться. Заехал на сервис, послушали - посмотрели, чуть чуть подтянули рейку, затем сделал подкаткую балансировку. Офигеть разница оказывается между обычной балансировкой и такой. Я честно говоря никогда не верил в нее (как вариант конечно милого балансировали - утверждать не могу)
А я всегда в нее верил , но меня каждый раз переубеждали друзья,знакомые ,мастера ... Терь поеду и сделаю , а где такая балансировка и сколько стоит ?
Немец
Цитата(Stiklish @ Oct 14 2011, 10:13) *
Скулл, сам глушители не варит. В уздеу сервисе на учкахрамоне есть сварщик дядя Марат кореец, уже стопицот лет варит глушители.
Был сегодня у него, у дяди Марата имеется ввиду, он почесал лоб и сказал во вторник подьезжать.
Мож у кого альтернатива есть?
Зы: спасибо товарищу Alex_K за совет!
Nikifan
Делал в автосервисе МКАД, это если ехать со стороны вокзала в сторону аэропорта, недоезжая моста ведущего в аэропорт будет справа за рельсами сервис, там еще кастрол чего-то такое понаписано. Стоимость демократичная - 12к для штамповок и 24к дня литья. Там еще гарантию дают, скидки какие-то - надо будет почитать флаер, который они дают после обслуживания. Однако это при условии что диски ровные, у меня, как оказалось это было не совсем так и мне их сначала больше часа кувалдой выравнивали.
Зато сам сидишь и чувствуешь как процесс идет. Сначала он раскручивает колесо до 80 км/ч (водитель то в машине сидит, т.к нужно тормозить колеса по мере необходимости) и смотрит насколько сильное биение, потом снимает все существующие грузики на колесах и так колбасить начинает аж мозг чешется, потом постепенно он грузики вешает и становится все меньше меньше и в итоге практически не заметные колзабавния остаются. Так все 4 колеса и балансируются.
Единственное я не совсем понял как он определяет куда грузик вешать, на стенде то ему показывается, а тут всего лишь самодельная машина для раскрутки колеса и все...
Мне кажется на угад это делаться просто не может.
Еще + такой балансировки то что балансируется вся система , опорный диск ступица/полуось и прочее ,а не просто само колесо.
Nikifan
Это да, единственное что остается это колпак. Он сказал они иногда бывают настолько разбалансированные, что этого хватает чтоб всю машину трясло, но у меня вроде все ок.
Немец
Тоже делал эту самую балансировку на юнусабаде. Мне не понравилось. Не смогли сделать. Все равно после 100 бил руль!
B@hus
Господа, я на ebay.com, присмотрел разные приблуды для авто. Как с этого сайта можно что то приобрести? Вроде в Ташкенте какая то компания-посредник есть? Где можно узнать подробности (по английски не рублю).?
Спасибо,
Спасибо,
ТУТ Либо к форумчанину Solnze возможно он сможет помочь
B@hus
Большое спасибо, сначала попытаюсь самостоятельно через atlantic. Если не получится буду обращаться Solnze.
CatScratch
Я заказываю у Солнца. Доволен.
Nikifan
+1, проблем не возникало.
B@hus
Какие у него условия и проценты? Мне было бы удобно налом.
Tuzuk-Bek
Есть профессиональный мастер по сварке зовут его Ортик ака, контактный номер 3355068, автосервис находиться внутри стоянки гувд, ориентир близко к тапоичу, так вот Он мне убитый глушак восстановил спокойно и не дорого...good.gif
Nikifan
Зависит от размера, веса и т.д. Думаю к нему обратиться за всей доп информацией можно - человек отзывчивый.
Цитата(Немец @ Oct 14 2011, 10:02) *
Народ подскажите в где есть сварщик который шарит в глушителях. Купил коллектор от сиело, надо его доделать
обратимся к Жахону (ака Ёжик) турбо Москвич. Сделает.
На МКАДЕ 4 раза делали, так и не смогли сделать, они на угат делают и по ценам зажрались.
Сегодня пока был в сервисе возле ТАПОИЧа (заправка Мустанг) решил сделать поткатную баланстровку у них, так вот оооочень хорошо сделали и аппарат у них с датчиком, сразу показывает куда груз вешать, на каждое колесо не больше 5 минут (на МКАДЕ 15-29 минут уходило), цена за литьё 18 тыщ за 4 колеса
На эту территорию не каждый заедет, и работают они в основном по ночам. А так дядя ара не плохо варит, даже пауки. good.gif
Через "АТЛАНТИК" сам намучаешься, ну чуть чуть сэкономишь, лучше сразу в личку к SOLNZE отписаться. good.gif
B@hus
ОКи, уже сам понял что с атлантиком я попал, он полюбому на англоязычные сайты выкидывает...
кто знает точный ответ? можно ли гражданам РУз покупать наши машины не в Узбекистане - например в России и завезти их сюда - сколько обойдется оформление доков?
Ты имеешь ввиду, машина с узб номерами которая находится за пределами Узбекистана? Оформляется через нотариуса в той стране где авто.
Только не нарвись на лохотрон, который так популярен в инете.. там предлогают авто с малым пробегом и ляляля..
Tuzuk-Bek
Dominic
Это же помойму то место, где Игорь Газянц работает, "полигон" команды azia racing team
Неа, не полигон, отстойник/гараж МВД. ИгорЬ там работает. rolleyes.gif
Немец
Точно. У Игоря ходовку делал
нет я имею ввиду новую УзДэу если там (в России) на себя купить - во сколько встанет оформить ее здесь? нужна ли растаможка итд?
Спасибо,
А тут еще и дешевле чем в атлантике...
Цитата(SKULL @ Oct 15 2011, 11:19) *
Реимпорт это.
Тоже там делал. Остался доволен.
вопрос...
отсутсвовал некоторое время на форуме. как просмотреть хотябы отдельные темы сразу с момента моего последнего посещения? не отматывая...
Цитата(T3571 @ Oct 16 2011, 00:09) *
вопрос...
По моему, только "новые сообщения" рядом с ЛС.
Сколько стоит лист орг. стекла и какого он размера? (5мм-7мм).
Думаю закрыть лимон не с полиэтиленом, а им.
ну открыл я 6стр "новых сообщений", и что? в каждой теме n-количество страниц на крайние 10 суток. как начать читать именно с момента последнего посещения????
обычно с тойже страницы и показывает. Где ты был в последний раз.
Подписывайтесь на темы, тогда на мыло придет сообщение и пройдя по ссылке вы попадете на страницу которую в последний раз читали.
CatScratch
С левой стороны от названия темы есть желтый квадратик. Нажми на него.
nea.gif не выход. я много тем читаю, мыло зас##тся)))
зы. только он у меня не желтый, а оранжевый. впрочем, неважно))
CatScratch
Точно - оранжевый)
Эт точно)) у меня в день с АЦ по 30 писем приходит ))
+1 Кошаку за подсказку )
CatScratch
+ надо не мне, а Райдеру. Он мне паказал эту фишку.
shumbola
У кого есть Микрософт офис 2011 для Mac OS X? Дайте переписать, качать с инета долго. ;-)
Немец
Это на айфоне так.
JaZ722
Это веЗде так :-)
ну 3мм стоит 35 у.е. 122Х244
есть 122Х184, чёт честно запамятовал, не уверен про 184.
и такая ситуация в городе, что с материалами подобного рода проблема.
возьми поликарбонат. 210Х600 и 210Х1200.
лексан или полигаль. размеры в см.
цены вроде если память не подводит 55000 за кв м была.
на лист 5 мм толщины
Спасибо. Советуешь применить подобное на мини теплицу? Крепление на болтах и труба.
Однако дорогое удоволствие. С учетом 11квм.
Нужно купить ноутбук. Бюджет 500-700 у.е. Смотрел на торге, куча вариантов. Может кто в ближайщее время что то покупал?
Кто что посоветует?
Как вариант мне понравился. В одной компании, официально завезенные Самсунги, с гарантией и русификацией.
Требования:
Для учебы, и возможно просмотр фильмов и немного игры.
Tuzuk-Bek
Уважаемые что скажите такой вопрос - нужно-ли менять масло если машина простояла 1год+2месяцев в гараже ? Машина лачети 2009г, заводили почти 2-3 раза в месяц и было залито кастрол едж 5/40, но пробег на этой масле всего 1800км...
Артур
Однозначно нужно. Не реже чем 1 раз в год. Либо по пробегу. Кажись у всех моторных масел так.
Кто что посоветует?
Требования:
Самсунги не советую... В Ташкенте есть Asus и Acer с русификацией.
