Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
такой вопрос. что то я уж от жизни отстал, давно в россыпи ничего не покупал. хочу собрать файлсервер с торентом. задача: как можно тише. по производительности хотяб кор-и3, 4 гига памяти и 2+2тб винты. в идеале что-нить в миникейсе и без кулера на проце. кто что посоветует?
man_in_white
Цитата(FAYZ @ Mar 19 2012, 13:27) *
Такой вопрос:
Посередини дома на 2ом этаже возле окна установлен WiFi Rouer. Раздача сигнала чтото снизилась.
Хочу поставить усилительную антенну не направленного действие.
Я бы сначала проверил причину снижения сигнала. Как вариант, может сосед со своей точкой wifi сидит на этом же канале и глушит твой.
Правильное радиочастотное планирование - 80% успеха.
Возьми программу InSSIDer и посмотри, что у тебя в эфире творится. Сигнал твоей сети должен быть самым сильным для нормальной работы.
Может просто надо поменять канал приема-передачи в ручном режиме и все заработает.
У твоего модема 2 антенны по 3 dbi, а не по 6. Но их можно поменять на более мощные.
man_in_white
Для таких целей i3 и 4 Гига памяти как из пушки по воробьям.
Торрент клиенты уже есть почти во всех домашних сетевых устройствах.
Можно взять сетевой диск на 2 Тб и пусть он качает, к его usb порту подключить еще один диск на 2Тб.
Можно также взять готовые двух дисковые или четырех дисковые массивы от Synology, Qnap и др.
Появится куча других приятных услуг, типа UPnP, FTP и проч.
Да еще и возможность устанавливать другие программы.
Так чуть не понял а именно как может сосед сидеть на моем закрытом доступе?
Канал приема и передачи это из настройки модема?
Изменил параметр с "mix 11bgn" на "only 11n".
Chenel Width стоит auto. Есть еще 20/40Mhz
man_in_white
Запросто.
Обычно при настройке модема новички не меняют настройки по умолчанию, тем самым выбирают 5 или 6 канал WiFi.
Диапазон частот WiFi (2,4 и 5ГГц) является нелицензируемым до мощности 100 мВатт.
Это означает что любой человек может свободно пользоваться обоими WiFi диапазонами и всеми каналами.
Вот и получается, на 5 канале светят 10 разных сетей, а остальной диапазон свободен.
man_in_white
А зачем?
У тебя все устройства только n?
20 Mhz - это 150 Мб/с
40Mhz - это 300 Мб/с
Количество каналов 2шт. В настройках ничего сверхестественного не нашел. Попробуем установить антену побольше.
Вы какую посоветуете активную с усилителем или обычную размером побольше.
Цитата(man_in_white @ Mar 19 2012, 22:36) *
А зачем?
Устройство только iPhone.
Цитата(gluckboy @ Mar 19 2012, 18:29) *
ну когда в первый раз запускаешь 1с клиента он просит ввести ключ 7ми значный кажется и выдает завпрсную часть ввиде пятизначного цифрового ключа. как я понимаю есть генератор который по этому коду дает ответную часть.
Это походу ваши 1С-кодеры наколдовали)) у 1С 7.7 используется аппаратный ключ (aladin). А тут судя по всему типа защиты конфигурации.
Man in white дал дельный совет.
Но если всё же надумаешь собирать машину, смотри в сторону Mini-ITX. Плата размером с тетрадку, корпусы тоже небольшие, энергопотребление минимально.
man_in_white
Смотря на сколько надо усиливать сигнал.
Для небольшого усиления подойлет обычная, для большого усиления нужен дополнительный усилитель.
Думаю с 6% в одной комнате на 25%.
нее, 1с унисетап 7.7 кажется ты и давал. раньше был аппаратный хасп ключ и все к нему цепляться должны были по-идее, но он был настолько глючный и кривой, что на него забили и перешли на юнисетап, который к никаким ключам не привязан (аллилуя!) за исключением первого запуска новой инсталяции )) вот там и есть - выдается ключик циферный, который присылается мне, а мной он отправляется "кодерам", они присылают ответную часть, она забивается человеческим клиентом в поп-ап окошко програмного клиента и всё работает. просто лень с ними связываться каждый раз, насколько я понял у них там простой генератор и всё. гдеб его раздобыть smile.gif
Так я об этом и говорю, что это они накодили в своей (вашей) конфигурации. Алгоритм известен только им (и ктулху). Можно при помощи другого программиста выковырять эту каку из конфига.
Где качественно расточить блок?
не пойдет. эти штуки не знают и не могут знать что такое лдап и актив директори. а мне надо чтоб там сервер2008 крутился. просто задач у него лишь файловая помойка с ограниченным доступом на раид-1 и всё, ну может еще пару служб для избыточности, а торент это побочка. обычно для этих целей заказывается что-нить из линейки эйчпи но это долго и дорого. а надо быстро и здесь. что мне конкретно надо, какую материнку лучше взять (ну типа бренд, понадежней) какой проц лучше воткнуть, какой кейс найти. и реально ли обойтись без кулера? просто уже несколько лет вообще не притрагивался ни к чем самосборному и понятия не имею что шас хорошо а что плохо. помню раньше элитгруп и асус были типа круто ) а томато и меркури атстой )
Цитата(FAYZ @ Mar 19 2012, 17:10) *
Талгат а вот 2ой вариант в мойм посте выше?
Щас 6Дб стоит 2шт. Думаешь обычные помогут? без питание
Файз, я на малике купил 8дб антенну, их по 15тыс сум продают.
TP-Link Называется, на коробке написано 8dB.
Большой толк от нее не заметил.
Ты не понял. он имеет ввиду что ты сидишь например на 10-ом канале и твой сосед на 10м канале, поэтому у вас могут быть помехи.
Врубаешь прогу и смотришь на каких каналах есть сигналы вай-фай, выбираешь тот на котором нет никого и всё.
Канал меняется там где у тебя: AUTO стоит. Там выбери от 1 до 11канала.
Оставь MIX 11bgn.
Channel выбери в ручную
man_in_white
Во-первых, этого не было в начальном сообщении.
Во-вторых, эти железки уже во всю поддерживают Ldap и AD, так как расчитаны на рынок SMB
Alex_K
Автобаза горгаза 1868835 д.Сергей, товарищ много раз растачивал, вроде нареканий нет...
спасибо за информацию, я всё понимаю, но эти железки тут явно искать надо, и всё же комп сам по себе более флексибелен изначально. кроме того товарищи купили по ошибке лицензию на в08срв_стд и им ее куда-то надо срочно применить. вопрос всё же открыт. на какого бренда плат и бп вообще стоит смотреть а кого обходить?
Я долго не мучился с домашним сервером - собрал обычный комп в наименьшем корпусе, который нашел здесь. С вентиляторами, но они управляемые. Процессорный, стоит на своих 600 оборотах и ему этого хватает. Блок прицеплен к UPS и Ethernet, стоит далеко в углу без монитора и клавы. Не видно и не слышно, уже года три.
Правда, у меня там Линукс.
PS. Никаких особых брендов не придерживался. Два харда SATA 500GB в софтовом RAID-1, мамка самая простая со встроенной видяхой и сетевухой 1000 BASE-TX. Проц, 4-ядерник - 8200. ОЗУ, 8 гигов, еще DDR2. Блок питания, тот же что шел с корпусом.
Сколько там в квартал можно было отправить одному человеку? 5000$ или 2500у.е.
Вот хорошая мама для этих целей:
http://www.amazon.com/Intel-Executive-Gene...5009&sr=1-3
Имеет возможность удаленного управления (типа i-Lo на серверах HP).
mazy330
Сань, на автозаводской есть инфа, что пороли. Так что думаю не стоит.
На 8-ом квартале есть Леха, но тебе полюбому ехать надо чтобы за допуски поговорить. А ещё есть НПО Технолог, координаты могут дать на автозаводской. Знаю что к ним возят то, что другие сделать не могут и парк станков там неслабый.
Шерзод
станки там действительно очень хорошие, да и мастера неплохие.
Где в Ташкенте можно купить хорошее масло для заливки в компрессор автокондиционера? Прислали новый компрессор, не заправленный маслом.
10000 в год, 5000 в день, от одного человека кому угодно.
Ладно, раз пошла такая пьянка, может и мне подскажите:
Sharkstream, в идеале 512 кб внешка, 2 мб внутри сети, реально около 300 и до 1 мб соответственно.
Модем Dlink dsl-2640U, линия по меди 0,75 прямо от щитка без сплитера.
3-4 года полет был нормальный, но ввели 2 мб внутри сети и с тех пор начались проблемы: пол дня все хорошо, но как вечер (16 - 17 00), так сразу линк падает, нудно и долго поднимается, после чего скорость не более 6-7 кб и на внешку и на внутренние ресурсы, хуже диалапа, и так каждый день, после 1-2 ночи все опять нормально. Монтеры были раза 3-4, тупили в щит, денег давал, чего то там делали, заявку прову оставлял неоднократно, толку нет.
shuguroff
Скорость просто падает, или появляются потери пакетов? Скажем если выполнить ping www.ru -t какие потери будут во нормальное время и вечером?
Если не требуется 2мбит внутри сети, попросите технарей провайдера ограничить скорость на порту.
Сначала падает линк, потом долго поднимается (может и до 1 часу), дальше весь вечер скорость не выше 7 кб, если опять падает, то и поднимается опять долго.
Сейчас потерь нет, ср. время в мс - 100, проверю вечером и отпишусь.
Статистика за пол дня:
Требуется.
Я думаю, что уже ограничили, но проблему это не решает.
Требуется.
SNR Margin (dB) - 5.9
Attenuation (dB) - 40.0
Отвратительная линия, надо менять пару.
Допустим, но почему вдруг стало плохо пахать?
Почему зависимость от времени дня?
Где менять?
Как?
подскажите как и где можно заварить корпус карба? отломано ушко для винта крепления верхней крышки. сегодня в 2 местах был и отказались его варить из за того что это силумин. и вообще какие варианты есть чтоб это ушко прилепить? пусть даже не используется по назначению, но чтоб хоть не протекало.
сделай фото.
гнусное это дело- варить силумин. варил пару раз...бррр...впечатления...
Может водой залило, может еще что.
Где менять?
Как?
Монтер должен менять. Пообещайте хорошо заплатить, но только после недели нормальной работы.
Цитата(TOUAREG @ Mar 20 2012, 16:03) *
сделай фото.
нашел старое фото на форуме (оказывается я еще год назад про это спрашивал biggrin.gif ), хорошее фото только вечером смогу скинуть.
думаю докупить к нему верхнюю крышку и по экспериментировать на нем, если что то не получится то все ровно не жалко.
LADA-FAVORIT
Скачиваю драйвер с сайта производителя (диск потерял),файл скачивается в zip архиве.Распаковать не могу,т.к. файл пытается воспроизвести проигрователем.Что не так делаю?
1. Нет архиватора. Решение: скачать WinRAR
2. Неверно настроены ассоциации файлов. Решение: щелчок правой по файлу, открыть с помощью, выбрать программу..., в открывшемся окне выбираете архиватор, и ставите галочку "Использовать для всех файлов этого типа".
гнусное место. стенка тонкая. варить только аргоном...и то, аппарат нужен с нормальной настройкой на малые токи...
у меня такого пока нет...
попробуй пропаять оловом. только учти, что несущим этот элемент уже не сможет быть. или может чЮдесная холодная сварка поможет? сам я никогда ее вруки не брал biggrin.gif
теперь понятно, для чего ты бензостойкий герметик искал biggrin.gifb:
Значит на провайдера можно не косить?
Тогда нужны контакты гл.инженера мирабадской атс smile.gif Хотя я уже и платил и что только не делал, осталось наверное только принудить.
У нас на форуме есть спецы по гидродинамике? Есть один простенький и интересный вопрос.
Через провайдера проще будет решить проблему.
Эпоксидкой не вариант ?
задавайте. за попкорном уже гонца отправил...
как ты себе это представляешь?
Сформировать кубик после застывания придать форму .
почти гарантирую, что долго не продержится. слишком разные тепловые расширения у силумина и эпоксидки. отслоиться, имхо.
имхо там нет таких температур ибо охлаждается бензином .
каких таких? я цЫфр не указал)))
утром какая темп в подкапотном пространстве? днем, в жару, после прогрева по полной программе какая темп? циркулирующий бенз сгладит разницу, но незначительно. теперь прикинь разницу и погугли коэфф теплового расширения для каждого из вышеуказаных материалов.
Nikifan
Но не факт что быстрее.
У меня одно время были проблемы с линией, поехал в АТС привез с собой технаря этого (как там их профессия то называется?) - объяснил проблему, в течении дня он ее решил. Отдал я ему тысяч 20 пару лет назад.
А через провайдера... они конечно отправят заявку на АТС, но когда и кто доберется до абонента остается только гадать...
Где менять?
Как?
линия ужасная а срыв идет когда идет пересинхронизация на более высокую скорость, либо тупо вечером нагрузка на магистраль возрастает и параметры ухудшаются, проверьте с телефоном какие сюда же скопируйте, подскажите примерное расстояние до АТС.
тот параметр что у вас 6,9 должен минимум быть 10 и выше.
я такие проблемы решаю и решал на раз
Предполагаемый диапазон температур в которых будет работать автомобильное устройство смешивания бензина с воздухом легко прогнозируется wink.gif
думаю вот эти вещи успешно справятся с задачей .
1
2
