Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
PLADOS
Цитата(Scarlett @ Jun 27 2011, 16:55) *
А я как раз-таки около года исключительно на кровати пользовалась...
Советую приобрести охлаждающую подставку под ноутбук,тогда и на кровати не опасно пользоваться.
Покупал себе ]/view-photo.html?good_id=80232&pid=2245" target="_blank"> такую ,отличный девайс.
На работе такие тонькие клиенты.
OS Windows Server 2003 R2 контроль администратором.
Вопрос: при просмотре фильмов, роликов из youtube, rutube... итд идут задержки голоса на 2-3 сек.
Как исправить?
Как исправить?
это косяк службы терминалов от MS win 2003 поможет переход на MS win 2008 R2
Помогите кто связан с этим! Нужна простая до безобразия камера наблюдения для кабинета в ночное время! Требования: Простой инсталл,подключение напрямую через юсб, минимальные знания компьютера, ночной режим съемки!
По поводу подставок для ноутбуков! Есть в наличие SPIRE цена 20 енотов!
Ха, ха Файз чтоб мог смотреть фильмы без косяков обязует руководство перевестись на новый ОС ))))))) хотяяяяя, Ю-селл - ожидай большего !!
Как исправить?
Через такой комп - ты грузишь ОС через Сервак, т.е. харда на этом девайсе нет.
Соответсвенно если сервак загружен такими машинами - оттуда и задержка.. ИМХО.
Как исправить?
Задержки - это всё минусы протокола RDP.
Поищите веб-камеру с инфракрасными излучателями. Поставите софт на компьютер (WebCamXP например). Если найдете камеру со встроенными излучателями, можете купить в магазине охранных систем инфракрасный прожектор.
Цитата(RED BULL @ Jun 28 2011, 12:30) *
1.Через такой комп - ты грузишь ОС через Сервак, т.е. харда на этом девайсе нет.
2.Соответсвенно если сервак загружен такими машинами - оттуда и задержка.. ИМХО.
1. Верно
2. Не Верно. (просмотр через WEB)
Какойто доп. софт поможет? (онлайн просмотр)
даже если повесить все патчи служба терминалов на 2003м не будет работать по RDP ver. 7.1
qwerpo
Я так понял, что подставка универсальна и подходит к любому ноутбуку (нетбуку)?
Посоветуйте антену для местного ТВ. От дома до телевишки 10-13км.
Установленные на крыше антенна "Камаляк", "Ласточка", "30 Канал" показывает с помехами на 32" Samsunge.
http://www.lifesat.ru/index.php?page=4&cat=16
Цитата(Powerman @ Jun 28 2011, 01:03) *
Обратите внимание на диаметр шкифа на генераторе! Скорее всего он у вас не раскручивается. На Ш-ниве Шкиф на коленвале больше чем на классике. Выход один уменьшить диаметр шкифа на генераторе.
небольшой уточнение- у меня стоит ДПКВ, соответственно передняя крышка с приливом под этот датчик. насколько помню, маркируется эта крышка 2123...
соответственно шкив на КВ под этот датчик, с отличием Шнивы только по типу ремня(у меня под клин). диаметр шкива КВ, как понимаю (именно изза крышки и прилива), должен быть аналогичным с Шнивой.
Цитата(FAYZ @ Jun 28 2011, 12:46) *
1. Верно
2. Все верно. Браузер загружен на сервере и использует его память и процессоры. На клиентской стороне только показывает картинку.
я бы посоветовал UZDTV
Я бы посоветовал спутниковую антенну. Без помех совершенно и выбор каналов много больше чем UZDTV. wink.gif
Файз для местного тв спрашивает)))
Упс! Не обратил внимания.
PS. Зашел на сайт UZDTV. Дурят по полной.
DVB-T характеризуется высоким разрешением в 625 строк, использует чересстрочную развертку, при этом частота полукадров составляет 50 Гц.
И что? У аналогового Секама те же характеристики.
Исходя из них, вот это:
DVB-T в состоянии обеспечить удвоенное (по сравнению с базовым) разрешение по горизонтали и вертикали, а также может передавать изображение c соотношением сторон 16:9
Может ошибаюсь но на LCD 32" Samsung, они так и будут плохо показывать, как и обычное аналоговое кабельное... это ведь не цифра...
Со спутника будет все в идеале или UZDTV и т.д.
Так что дело тут не в антенне... а в сигнале... (имхо)...
Выход один поднимать антенну выше , на сколько я помню у вас же частный сектор . У меня на 3м этаже несколько местных каналов ловит просто на кусок кабеля от бывшего централизованного ТВ качество картинки отличное ,во всяком случае помех нет .
Тарелка стоит 3шт. Даже Шаринг. Родным национальное подовай (как они могут смотреть?). Там ахборот или концерт причем всегда так!
Антенну поднял до 20 метров. Больше уже сорри smile.gif. UZDTV не хочу. Зачем еще один по счёту 5ый пульт.
Может изменится качество заменой антенны? Всеже ласточка со време СССР.
Если у тебя на тарелке есть ОРТ (снг), то ты запросто можешь ещё настроить 2 Уз_канала для роднЫх.
на параболе вечно пропадают российские каналы.
это от настройки или нужно менять головки )*?!
стоят 3 штуки(на российские каналы)
тюнер дреамскай 300
ОРТ нет у меня. Есть "первый канал" на Шаринге. Можно настроить?
+1 недавно пропали : 1 канал СНГ, стс +0 , стс +2 и еще какие-то
У меня дома кабельный и то некогда смотреть ))) Смотрю только Дискавери и НатГеографик, самые зачетные каналы smile.gif
Подскажите пожалуйста! Где можно купить дешевле чем на рынке запчасти на Лося!? Новые! Спасибо!
от ю-а универсама в сторону уч-кахрамона после первого светофора еше метров 100 с права будет в доме магазин черно красный !
P.s - на сергели решетка на епику 270 стоит у них же 200
11 квартал Юнусабада ( напротив 8 квартала )
Где находится посольство Египта? Ориентир рядом мож какой?
раньше египетское посольство было на ул. Чиланзарская, почти напротив бывшего американского посольства.
Однако интернет говорит что они переехали за ТРЦ "Континент". карта проезда там же)
Посольство Египта
ул. Чиланзарская, 53а
тел.: (+998 71) 120 60 21, 120 50 08
факс: (+998 71) 120 64 52
ПРимерно напротив бывшего американского посольства
Поворачиваешь в махаллю (бывш. Баранова) за супермаркетом Континент, смотришь направо, на воротах табличка, рядом постовой. По соседству с российским торгпредством.
Всем спасибо, надо теперь до них доехать, до консульского отдела фиг дозвонишься.
Кто нибудь может порекомендовать клинику + опытного врача стоматолога-ортопеда с реальными ценами, нужно установить имплантант ( не хочется обтачивать и уж тем более депульпировать здоровые зубы).
с другой стороны "сервиса СКУЛЛ". Щас дам в гугле.
Кто знает, можно ли получить выездную визу (ОВИР) будучи военнообязанным? Оплатил за МПР, но никак не найду времени съездить.
Можно. Моему младшему брату поставили.
Прикол в том, что если не оплатить - печать с военкомата не поставят.
Если оплачено - то ставят без проблем.
А съездить на МПР можно в любое время до 27лет.
Сам недавно был в военкомате, оттуда и инфа.
AndreVla
А лучше сходить и отслужить месяц... ещё никто от этого не умирал... если конечно здоровье позволяет служить!
Конечно лучше, никто не спорит. Только надо как-то еще выкроить это время на работе.
AndreVla
Форумчане... нужен Ваш совет или рекомендации.
Решил ездить на тренировку не велосипеде.
Пункт отправления: Базар Катартал
Пункт назначения: Корзинка "Аэропорт"
Дома есть старый велик на подобии такого:
Хотелось бы узнать мнения как относятся в вечернее время к велосипедистам на дороге и именно на дороге, т.к. по тротуару особо не поездишь не заработав "восьмёрку" на колеса.
Стоит ли мне ставить габаритные огни спереди и сзади, учитывая что возвращаться буду я после 23:00?
90% водителей у нас не считают велосипедиста за полноправного участника дорожного движения. Поэтому огни лучше поставить везде где возможно.
Нужно "выгрузить" большую сумму из UzKart. Если кто знает вариант, пишите в личку пожалуйста.
А еще лучше жилетку светоотражающую!
AndreVla
Так, огни габаритные куплю, сделаю.
Жилетку... сложнее наверное на сумку или на портфель нашивки из светоотражающей ткани придётся сделать!
И как правильней себя вести, показывать жестами, если я хочу повернуть или тупо посмотреть нет ли кого и морду тапочкой и перестраиваться без соблюдения правил?
Я предполагаю, что у нас 90% водителей даже не знают жесты, которые используют велосипедисты, мотоциклисты во время езды!
DenDiesel
и жилетку надо и габаритки стоит поставить... В целях собственной безопасности.
