Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(man_in_white @ Nov 5 2012, 21:09) *
Геливые совсем дорого.
Емкость и долговечность, будут использоваться внутри помещения.
Какое количество требуется? Отец завозит гелевые, но такой емкости только под заказ, зато перечислением по белой схеме.
Так так, я так понимаю, что для ИБП высокой мощности... Я прав?
Да, обращайтесь если надо. В наличии есть ИБП от 600VA до 3000VA. Под заказ до 200kVA.
Ну, такие ИБП для меня - не серьезно. Начиная с 30 кВА (20 кВт), скажем ))). А вот аккумуляторы 40Ah и выше - это уже актуальная тема перечислением.
где находится республиканская урологический центр?
ni1812
Новый ТашМИ.
man_in_white
Телефон папы дай пожалуйста.
Нет, не прав.
Мне нужна емкость, а не мощность.
INTELigent
Подскажите кто в курсе, где на Ю-А находится 7-ая горбольница (бывшая 17-ая), и как туду с Кадышева лучше проехать?
Спасибо
krokus
Спасибо
После телевышки на Шахристанской повернуть налево-дорога сама выведет к ней.
Или от Мегапленета поднимаетесь на мост, после него до большого перекрестка(где направо на амеровское посольство, и где прадо на нексию приземлилась). После перекрестка метров 100-справа заправка УГО(бывшая Дипсервисовская), а слева через дорогу эта больница. На машине придётся далеко ехать на разворот.
Спасибо
удалил. Выше написан более близкий маршрут.
Точно. А то я маршрут такой далекий описал)))
У кого-нибудь есть полная действующая тарифная сетка на коммунальные услуги? Или ссылку дайте, пожалуйста.
addanif
где есть выбор хороших кожаных курток? желательно большого размера?
krokus
Кто сталкивался с маркировкой продуктов? Нужны что-то типа стикеров, где их взять? Заказать в полиграфии или есть бумага такая наклеечная, на которой можно распечатать перевод на узб.язык и сразу наклеить?
Если большое количество то лучше в полиграфии. А если не очень много то можно поискать бумагу и печатать на принтере (самую тонкую надо брать), только не знаю в лазернике можно или нет печатать (мало ли что с клеем произойдет при нагреве в печке), наверное лучше на струйнике или матричном.
помню, гдето у китайцев встречал небольшие принтеры, для ценников и этикеток rolleyes.gif если память не изменяет, это были струйники...
krokus
В принципе большое..
Да там просто текст напечатать, вот как на российском пиве, например..
Есть бумага, можно на струйнике отпечатать smile.gif особенно если размер мелкий... то самое то. Просто полиграфия опять же скорее цифровая печать, так как для офсета тираж надо очень большой таких наклеек.
krokus
надо 30.000 штук размером 5х5 см.
Это чуть другое, принтер для ценников, в штатах заказывали, там сразу автоматом можно с программы впечатывать артикул, цену, наименование и т.д. (лазерный кстати)
Однозначно офсет )) 625 А3 или 1250 А2. листов... в 5 раз дешевле чем цифра или струйник)).
187 58 26 (Сергей)..
krokus
Спасибо! drinks.gif Позвонил, жду когда посчитает.
Всегда пожалуйста, торгуйтесь )) обычно немного скидывает... скажите что дешевле есть варианты ))). Но чем у него хорошо, качество всегда супер и точно в срок.
есть еще контора Al-Vair находится между Бешагачем и парком Бабура в здании Ташгенплана. У них оффсетка очень дешевая, года 3 назад печатался там, было на 30% дешевле чем везде по городу и в 2 раза дешевле чем в Силмеге.
krokus
Завтра съезжу! Он спрашивал кто номер дал-я как мог объяснил, пришлось вспомнить про место дислокации.. rolleyes.gif
В принципе устраивает цена у Сергея, в Силмеге по телефону девушка сказала что на оракале напечатают-цена почти в 6 раз выше получилась.
drinks.gif Ну и правильно. Так лучше.
мне нужна консультация и цены если можно - ИБП для 3-х комнатной квартиры - жду ответа в личке и зараннее благодарю drinks.gif
Для начала тебе неплохо было бы узнать величину потребляемого тока в твоей квартире... Если дома кондиционер и холодильник, 1 комп + всяка разна техника, то мощность ИБП необходимая может быть около 5 кВт (около 6,5 кВА). Как-то посмотреть бы на твои глаза, когда ты узнаешь стоимость такого девайса rolleyes.gif
kama
курс подыматься собирается?
Koshak
что лучше взять, playstation или xbox? в приставках не разбираюсь, нужен совет.
Если играть с джойстика - то разницы особо нет. У каждой приставки есть лицензии на определенные игры, тут уже личное предпочтение. Например на Sony мне нравятся Twisted Metal и GranTourismo - их нет для Xbox.
Но у Xbox есть Kinect. Аналоги есть и у Sony и у Wii, но мне кажется у Xbox все же круче.
Если есть дома дети, то XBox с Kinect очевидный выбор. Дети и попрыгать могут, и побегать, и потанцевать...
Я брал для детей, поэтому даже не думал...
Koshak
спасибо! меня интересует новая call of duty, она будет на обеих приставках? помню в школе играли в twisted metal, шикарная игра! а на третью соньку она есть?
если лицензионки будешь играть бери Сони - сам юзаю - но играю только GT - очень доволен
если левые игры то X-Box - на него игры на дисках дешевые и их много
Call of Duty есть и там и там - могу привезти лицензионную - 60 бачей - если хочешь, дай знать - еще какие-то лицензионные стрелялки были - могу посмотреть.
Call of Duty есть и на PC, и на всех консолях.
Twisted Metal есть только на PS3. Я тоже в школе в неё гонял на первом PS... Игра просто супер...
Но все же я рекомендую присмотреться к Xbox Slim 250G with Kinect, c прошивкой Glitch Hack (Free Boot). Эта прошивка позволит запускать игры с жесткого диска, то есть привод для дисков прослужит долго.
Игры есть просто улет, и можно всей компанией засесть... У меня дети дома до того скачут, что полы блин уже скрипят... Зато не сидят, а двигаются...
Я с пацанами как-то сам стал играть в игру, там препятствия летят и надо или нагибаться или прыгать... После часа игры я выдохся как будто кросс пробежал. Рекомендую. Особенно тем, кто много сидит на работе перед компом...
Правда к нему хорошо бы еще и телек как минимум 42"...
Koshak
спасибо! но call of duty нужна русская версия)
двумя руками за xbox
Я так думаю кондиционер и всяка разна техника не являются приоритетными в использовании когда все соседи сидят перед свечкой)) На UPS можно повесить холодильник, всё освещение, компьютер, сетевое оборудование и телевизор. А утюги, кондиционеры, музыкальные центры и прочее использовать только когда есть электричество.
NikAs
Нужно купить компютерный стол и двухспальную кровать.. Думаю что лучше, сделать на заказ или купить готовое?
Позвонил на заказ - стол 200$ , кровать 500у.е. Может кто покупал (делал) подскажите салоны где стоит посмотреть или хороших мастеров по приемлимым ценам. Спасибо.
Вроде среди форумчан есть мебельщики.
ARI100KRAT
ребят вопрос такой, правда ли то что коробка от лося встает один в один на нексию? мне сегодня один усир...я спорил и доказывал что да, прав ли он? и если да то правда что лосю такую нексию теперь не обойти???
правда
Dan_19
на сколько я наслышан, все перекидывали только внутреннисти. а так мне кажется что по параметра коробка от 1.6 и лося одинаковые
ARI100KRAT
хорошо... стоит ее менять или нет? сколько это удовольствие мне обойдется (хотя бы примерно)какие плюсы и минусы?
Игорь зачем тебе заморачиваться! потом пойдёт форс мотора,валы,тюнинги!
будешь как мы ,бабки бездушно вкладывать
ARI100KRAT
А поподробнее?
LADA-FAVORIT
Однозначного ответа нет.
Сам пользуюсь исключительно SPS, сменил все три поколения. Доволен.
Артур
http://fmc.uz/main.php?id=tarif_komm_uslugi
Цитата(ARI100KRAT @ Nov 6 2012, 23:37) *
Цитата(Alexan_Der @ Nov 6 2012, 23:40) *
А поподробнее?
Koshak
они, те самые... рэдлайн лучший!!!
maestro
подскажите кто знает где можно купить пару мешков угля
Dan_19
я нашел на Хасанбае(по бетонке от учкахрамона), тоже долго искал уголь на шашлык)))
еще не доезжая пересечения малой кольцевой дороги когда едите от метро Тинчлик по правую руку дом у дороги после автосервиса(или заправки точно не помню)
