Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
помоему Anedrew, решил аккуратно укрепить машинку.
так время то сейчас какое... без крепкой защиты и "инструмента" ни куда.. )))))
JaZ722
Цитата(mj-ko @ Aug 25 2010, 18:03) *
я вот для таких как вы специально противотуманки вверх направил и на отдельную кнопку подключил, чтоб в ответ слепить.
ну ващпе то он и не светит толком так что и слепить не может я же написал покрыл чёрным лаком не полировал оставил как матовый выглядит как будто нету туманок но с ксенонами горят чуток ярче габариток сам хотел оставить галогенки но они слабенькие sad.gif а ксенон ток жрёт dry.gif а туманок хочеться
будет у вас ронированная машина походу да))))))
ferteeee
Кто нибудь знает есть ли ПДУ на магнитолу Кларион (Та что на вторых ксю с завода)?
Нету. Сам искал но там даже приёмника ИК нету на самой магнитоле pardon.gif а так было бы айс.
Прбовал кларионовский руль с первых ДОНС не подоходит.... не принимает сигнал да и собсвтенно горя НЕЧЕМ принимать!
сегодня полез менять термостат. скинул старый, помыл и...а@@ел немного. маркировка на нем стоит- 21073. никогда в жизни не видел такой маркировки на термостатах. полез в сеть- толком никакой информации( может плохо искал?). единственное характерное отличие, на которое обращают внимание, это
21073 - по температуре тот же, расположение патрубков как 2101 но! у него уменьшено сечение верхнего патрубка, что существенно уменьшает время прогрева
да, действительно несколько меньше. на глаз даже видно.
итак, суть думаю ясна. несколько вопросов)))
1. кто нить из классиководов уже сталкивался с таким термостатом)?
2. чисто теоретически- некоторое уменьшение\увеличение сечения одного из патрубков насколько критично влияет на время прогрева?
Сколько такое чудо в Ташкенте стоит? Ответ нужен срочно-сегодня.
ответил в личку
Цитата(T3571 @ Aug 31 2010, 12:33) *
ответил в личку
Ильич
Цитата(SKULL @ Aug 31 2010, 15:01) *
У кого есть программа или ссылка на счетчик интернет трафика? Русскоязычного, взломанного, чтоб в зависимости от времени суток считал разный тариф. Скачал AVS-iTimer 5, а он регистрацию требует. Может у кого крэк есть на него?
подскадите плз, как можно определить установлен ли на машине GPS передатчик?
Артур
GPS передатчики устанавливаются только на спутники.
В машине может стоять ГПС приемник.
Если имеется ввиду GSM сигнализация с ГПС приемником, то определить практически невозможно, смотря как замаскированно.
Теоретически можно запеленговать GSM сигнал, но не факт, что он именно от сигнализации, может хозяин в бардачке сотку оставил.
Последнее время моя магнитолла PIONEER CD/MP3 стала глючить, почти все диски прыгают и т.д. думал что качество дисков плохое, записал на хороший тоже самое..... Что делать в таких случаях? Разбирать и чистить головку? или уже все совсем старый стал?
Скорее всего второе, лазер подсел. Можно попробовать поменять головкую
А в среднем сколько лет живет лазер?
опрделяется количесвтом пыли и количеством дисков
По разному бывает. Где-то было лет 8 прожил, а где-то год... Для начала, можно найти чистящий CD и прогнать его. Не поможет - думать о замене.
Все это имхо. А зачем нужно???
Хочу проверить есть ли приёмник у меня в машине..... как то же он должен питаться или что лишние провода место скрытой установки где его искать примерно?
насколько я понял ты ищешь GPS трэкер??? надо всю машину перелопатить. pardon.gif. прикрепить его можно куда угодно, ему лишь нужно питание. Размеры примерно как пачка сигарет)))) (некоторые работают вовсе от своих батарей)
Я не думаю что в нашей компании ставили GPS трэкер.
GPS трекер следует искать по его антенне, которая не может быть спрятана под металлическим листом. Т.е. отпадает все, что под капотом, крышей и багажником. Остаются передний и задний бамперы, торпеда и полка под задним стеклом.
А может резак на компе подсел? Попробуйте ну, хотя бы в Нирване диск купить и послушать, хотя мне там тоже однажды брак попался.
Ау, компьютерщики! Помогите рядовому потребителю, плиз!
Да я и на домашнем писал и на рабочем, на работе новый резак. Сегодня из дома возьму фирменные диски просто СD не MP3 проверим. А обязательно искать чистящий диск и т.д. можно ведь просто разобрать и спиртом головку протереть?
BWmeter
BW Meter ,правда без русификатора (кликнуть по ссылке)
Мой старенький пионер легко читает и CD и MP3 не записанные на резаке, а фирменные диски smile.gif причем диски на обороте закоцанные до ужаса... и ничего не прыгает, что сие означает? что резаки на помойку, диски (болванки) или скорость записи уменшить? (всегда писал на 24-32) никаких проблем не было.
на двух машинах уже есть)))) трэкеры закупили уже давно)))
Скорей всего он под торпедкой стоит, если Нексия 2. Там места полно. Я бы поставил за панелью приборов )
Еще вариант - под задней полкой, между ДСП и металлом. Еще можно взять хороший яркий фонарь и ночью осмотреть весь салон. Скорей всего найдешь следы от рук и царапины от отверток, если ставили под торпедку.
Левякничаеш?
Спиртом ни в коем случае,просто ватной палочкой у меня тоже так было! почистили и все читал без проблем!
Спасибо попробуем
Левякничаеш?
нет я это дело я глубоко не уважаю) просто интересно пасут или нет
значит левакничает
Большое спасибо! Попробую.
как всегда не знал куда запостить. решил вот сюда....
итак, возникла проблема. умер последний светодиод подсветки борткомпа. теперь нивиднонифига. кто нибудь может помочь с этим вопросом?
а что за БК?
Как то читал, что на монохромных ЖК , посдветка находится за "стеклом", т.е. если снять бутерброд из стекляшек, под ним могут находиться smd светики, которые можно перепаять.
Цитата(KiMi @ Sep 4 2010, 19:12) *
а что за БК?
GF 511
собственно, монохромный...
Цитата(T3571 @ Sep 4 2010, 19:15) *
GF 511
даже по фото видно, что скорее всего smd-светодиоды. Заменить их вполне реально (сколько раз на сотовых менял), однако знать бы какой вольтаж у них. Если совпадет с вольтажом светодиодов от сотовых - без проблем дам сколько нужно (спаяю с нерабочих соток).
Знакомому на МУЛЬТИТРОНИКСе менял. Там ничего сложного нет. Если доверяете могу поменять.
Есть проблема! Дома лампочки не горят больше месяца, взрываються или перегорают, а люстра с маленькими лампочками, типа диодных, так вообще не горит и недели, кто подскажет хорошего электрика, который сможет замерить напряжение в сети и решить проблему??
я могу замерить особого труда не составит а дальше уже решать что и как, может дело сколько не в напруге а в ее скачках выше нормы?
Взрываются в дребезги?
Странно что при таких скачках осталъная аппаратура несгорает.
Скорее всего просто очень громко хлопают и летят искры, стекло обычно остается на месте.
Наверно чтото с проводкой. У меня в подъезде также.. больше месяца не живут, какую бы не поставил.
В подъезде можно поставитъ диод на лампу ,светитъ станет в 2раза тусклее зато лампа станет практически вечной.
Поставьте энергосбережающие лампы, только не китайские none brand, а типа наши совсместные например Casper или WEGA, они не сгорают и тем более не взрываются, а если вдруг они взрываются smile.gif то это ппц опасно.... там отрава такая просто жуть, но у меня реально хоть бы одна перегорела за 3 года.
Да нет ,вот тут я категорически не согласен.
В корпусе энерго сберегающих ламп естъ электронная плата розжига ,так называемый баласт. Так вот эта платка достаточно чуствителъна к перепадам. Обычный дефект этих ламп,либо некачественная заправка газом (практически все китайцы)либо перегорание транзисторов изза превышения напруги.
По наблюдениям самые лучшие это наши Wеgа.
