Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
так грузинский дворик само по себе далеко не дешевое заведение.
Koshak
Там просто элитные тараканы ползают) одного из них лично на стенке меню прихлопнул)
_HaMMeR_
Подскажите хорошего мастера па плазменным тв, желательно с возможностью вызова на дом.
Цитата(alex-gee @ May 11 2013, 14:13) *
Ясно, отстал я от светской жизни. ))
Где в Ташкенте можно заказать готового молочного поросенка? Ресторан или частники с доставкой. Поделитесь контактами.
Ресторан "Вечiр" на Новомосковской, где бывшая площадь Куйбышева.
Цитата(cduz @ May 11 2013, 20:13) *
http://e-orders.uz/gruzinskiy-dvorik/menu/
В "Грузинском дворике". Предварительный заказ. Оплата курьеру. 490 тыс, имхо, дороговато.
Спасибо, нашел в Bier Regen. 50 тысяч/кг, около 300 тысяч выйдет целый. К тому же дисконт мой там действует.
Strelok
Как или кто может помочь привезти с Москвы спортивный обвес, два ковша и спорт руль на мазду 3, 2009 года.
Спасибо
cduz
Lacetti 1.8l F18D3, уже месяц есть вопросы к холостому ходу. Редко-редко, раз в несколько дней, обороты ХХ перестает держать, проваливаются до 200, без подгазовки глохнет, причем проваливается моментально, если отцепить колеса от двигателя и бросить газ (а не плавно, как происходит обычно). Если несколько раз выключить-включить двигатель, глюк пропадает и двигатель работает без нареканий. Еще иногда при пуске (особенно если стоял не на горизонтальной поверхности) холостые взлетают не как обычно до 2000, а до 3000-4000, двигатель взревывает и потом обороты медленно падают до нормы. В дальнейшем все работает без нареканий.
Подскажите, какой узел может отвечать за такую работу и почему проблема сама собой пропадает?
на Нексие 1,6 это уже задобская проблема. Сказали лечится заменой проводки. Я тоже такое имею.
Первое, что приходит в голову непрофессионалу - датчик ХХ, потому что проблема, судя по вашему описанию, только в ХХ. Обратитесь в сервис, там быстро выявят проблему.
думаю, бензин. у меня нечто похожее с оборотами. ничего делать не хочу, пока не дожгу текущий бак горючки. погляжу, что будет после следующей заправки...
DenDiesel
Датчик положения дроссельной заслонки надо тоже посмотреть...
Alex_K
Вопрос к знатокам, сколько реально на сегодняшний день можно просить и получить за нексию 2009 года, сонс, GLE с кондерем, цвет 95U, не битая, реальный пробег 30тыщ? перекупы дают 12200
Просите 13. Отдавайте за 12,5-12,7.
cduz
Склоняюсь к клапану регулятора холостого хода (т.н. "датчик холостого хода") по итогам анализа симптомов.
1) Не поднимает обороты, когда надо - застрял в закрытом положении и не хочет трогаться с места.
2) Не опускает обороты иногда при пуске - также, открылся и не хочет двигаться назад.
Нифигасе цены сейчас!!!
DenDiesel
В случае с дефектом ДПДЗ, если ЭБУ видит открытие ДЗ по датчику в то время, когда на самом деле она закрыта, РХХ будет закрыт и как следствие - пропадёт холостой ход...
Неделю мучает холостой ход ((( обороты плавают с 800 на 500 потом 1000 ((( датчик хх чист(((
_HaMMeR_
UP
Scarlett
Есть отзывы по детским офтальмологам? Кроме Писаревского никого не знаю...
C детства меня лечила Бабаян Анжелла. Место нахождение тут. 1 этаж Астигматический центр.
мы у него курс лечения получали :rolley
правда давно это было...более 10 лет уже прошло...
Такой вот вопрос. По работе нуждаемся в рациях. Какие рации можно использовать у нас без регистрации и разрешений. Если можно ткните в документ. В данный момент присмотрел 2 варианта с доставкой из китая. Рабочий диапазон у обоих 400-470 MHz.
вы же юрик? купите перечесом, нормальные рации, с официальной регистрацией\разрешением ЦЭМС. куда обратиться по вопросу приобретения, могу подсказать...
сам юзаю рации LPD диапазона. разрешение, насколько знаю, не нужно.
Цитата(_HaMMeR_ @ May 13 2013, 16:08) *
UP
Ремонт ТВ, Владимир (98) 1275133, я его нашел на торге. Пришел на дом, осмотрел LG 42", вылетели динамики, микруху ПЗУ пришлось перепрошивать. обошлось тогда около 85 тык. Правда изза прошивки пришлось везти телик в мастерскую..
ATb
Был такой ништяковый - Княжев фамилия. Давно было, в диагностическом центре принимал.
_HaMMeR_
СПС, но почитав разные форумы по ремонту плазм, пришел к выводу, что самому экрану (панели) трындец, т.ч. завтра в оф.сервис. sad.gif
без разрешения только сиби 27 мгц (антенна 2 метра) если профессиональные, рекомендую фирму icom чистая япония. А какие нужны, ручные или в машину?
+1
ATb
Без разрешения ldp диапазон. 433.075-434.775 МГц. На нашем сайте с законами находил + чтот там про радиомодели и 27 мгц было. Но там 10 мВт ограничение. Которое кстати интересно обходят..
У самого мидленды 500е, которые по книжке 10 мвт, но если прочесть получше инструкцию на пике до 5 ватт выдают. (10 км+ по прямой долбят - проверенно)
http://gkrch.uz/www_data/articles/admin/file/SRD256.doc ссылка на документ, все частоты и устройства расписаны.
10 мвт без разрешения это да, но свыше надо разрешение. Лдп на 10 мвт хорош на отрытой местности как вы подметили или в здание. если ручные делать в городе то надо делать 5 вт + репитер.
ATb
В городе они 1.5 - 2 км макс. бьют. Смотря для каких целей их использовать конешн.. В одном здании или для работ каких локальных - самое то.
Я для гор брал. Очень доволен ими.
з.ы. А если антенну получше навернуть .. то и в городе дальность хорошую можно поднять. rolleyes.gif
согласен! Ждемс Зевса) чтоб узнать для каких целей нужны радиостанции)
получше это подлиннее? если антенну делать длиннее, то антенна будет не согласована и связь будет хуже.
Я Азизбеку привез несколько комплектов раций Midland
Качество отличное... в комплекте зарядка.
Китайские, они быстро ломаются... и батарейки быстро садятся.
До этого я юзал two-way рации Motorola... Тоже бат быстро садилась.. один раз уронил, радиоблок накрылся...
Мы с автоцентром когда в горы ездили, 4 рации были на связи по дороге на бочки )) Ден привет ))
DenDiesel
Цитата(RED BULL @ May 14 2013, 03:51) *
Ден привет ))
Привет ))
ATb
Не, разумеется под эту частоту. Читал гдет, ребята заморачивались на эту тему и дальность оч хорошую поднимали.
На моих, аккумуляторов родных на пару дней хаватало, когда новые были. К качеству пока претензий не было, хотя тоже китай.
По моему на них тоже подделки бывают.
Strelok
Спасибо
АП.. кто может помочь с привозом?
Хотел но цена пугает! За китайскую рацию которая на ebay 20$ просят 100. Я все понимаю но не в 5 раз дороже же.
И ручные и в машину. Кстати ICOM рассматриваю как вариант. Одна из рации ICOM. Частота 400-470; 130-173.
Цели: Организация туристического маршрута для туристов в количестве свыше 100 чел.
8. 433,050-434,790 МГц Радиостанции с выходной мощностью не более 10 мВт.
Или вот из торга. 85 за штуку просят. Реальная цена 40 на ибай. С доставкой вроде так же выйдет 80-85.
Дополнительная информация:
Описание:
Li-Ion аккумулятор 1800 mAh;
Мощность 4 /1W;
Хорошая модуляция (качественный звук)
Большой радиус действия (3-5км);
Функция "Два канала"
Отображение 2-х частот на дисплее.
Функция "монитор" для прослушивания слабых сигналов.
Режим сохранения энергии.
Звуковой сигнал при нажатии кнопок.
Сканирование каналов.
Возможность общения с обычными канальными станциями;
Возможность подключения гарнитуры;
Подсветка ЖКИ дисплея и клавиатуры;
VOX функция автоматического включения при начале разговора;
FM-радиоприемник
Размеры, мм: 100 х 52 x 32
Вес: 250 гр.
Технические характеристики рации BAOFENG UV-5R:
Диапазон: FM: 65-108 МГц (прием)
VHF: 136-174 МГц (прием/передача)
UHF: 400-480 МГц (прием/передача)
Количество каналов 128
СTCSS коды (возможность совмещения с любой LPD радиостанцией).
DCS коды (расширяют возможносити совмещения с другими радиостанциями).
Шаг частотной сетки, кГц: 2,5/5/6.25/10/12.5/25KHz.
Комплект поставки:
-1 x UV-5R (VHF136-174MHz / UHF400-480Mhz)
- 1x 7,4 В 1800mAh батареи.
- 1 x Антенна
- 1 x клипса.
- 1 x Руководства пользователя (на английском)
- 1 x зарядка
kama
кто подскажет, как определить пора ли менять масло в коробке? когда последний раз менялось я не знаю.
kama
Enigma
Цитата(SKULL @ May 14 2013, 11:58) *
цены на "профессиональные" говорилки несколько отличаются от приведенных. примерно на порядок(на один ноль). но это качество, надежность и сервис в Ташкенте.
от дешОвых говорилок, которые приводили в пример выше, не ждите много wink.gif
удачи в выборе!
удачи в выборе!
Тоже вариант! Не спорю. но за перечуху покупать ICOM за 300$ не хочу. Так как даже заказав из москвы могу привести в 3 раза дешевле. В данный момент у меня думка насчет 2 моделей. ICOM i Kenwood оба 2 частотники. 400-470 и 130-173. Цена в москве от 112у.е (в Ташкенте от 300у.е. и то под заказ)
Цитата(Лёха @ May 10 2013, 14:22) *
Всем привет. У меня такой вопрос, никто не знает откуда наш народ берёт сидения от мерса, и устанавливает в Матизы, Ласети, Нексии? Просто вчера видел матиз с сидухами от мерена, напросился вопрос откуда?!
ТУТ продаются.
Раскрывающийся спойлер
Продаются Кресла Mercedes w123 Mercedes-Benz в отличном состоянии
Цeнa: 250 000 сум Тип предложения: Продам
Регион: Ташкент
Название товара: Кресла Mercedes w123 Mercedes-Benz
Марка: Mercedes-Benz
Тип запчасти: Кузов и отделка
Состояние: отличное
Продаются кресла передние и задние, есть элементы отделки салона. В связи с чудесами мобильной связи можно написать в ящик - проверяю часто.
Автор объявления:Имя: Alisher Tadjiev
Контакты: tadjiev.alisher@mail.ru
телефон: +99894 64I 6I I0
Цитата(dimanich77 @ May 14 2013, 15:24) *
ТУТ продаются.
Регион: Ташкент
Состояние: отличное
Это древние сиденья от 123го мерина, народ ищет сиденья от W203 или W211 кузова)))
вам как я понял нужна связь в калоне? или на весь Ташкент?
берите Icom, не пожалеете, если брать 2 частоты то как вы будите их стыковать?
В Матизку ? rofl.gif Там место вообще останется на заднем сидении после такого инстала ? rolleyes.gif
Связь в колонне в основном. По всему Ташкенту есть другая рация. На мобильниках. Но в них есть проблема задержки. Так что в близком радиусе они бесполезны.
Просто иностранцы которые ко мне приезжают они часто в 130-172 частотах. А все наши 400-470. Этим обоснован мой выбор. Что бы не таскать 2 рации. а переключать режим в зависимости от ситуации.
ясно понятно, если нужно будет установить радиостанции в машину, ремонт или настроить, обращайтесь!
