Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
drden
Можно скачать бесплатную утилита для лечения компьютера от вирусов и других угроз, Kaspersky Virus Removal Tool. Прогнать комп сначало ей, в 8 случаях из 10 помагает, а потом уж думать дальше. http://www.kaspersky.ru/virus-scanner
Elias_More
Цитата(dimanich77 @ Nov 27 2014, 11:07) *
Вот сам использую не первый год. Но первое обновление антивирусных баз будет "жирным", потом по чуть чуть.
Спасибо. На сколько жирное будет первое обновление? Не больше 500 мб?
И да, будьте добры, скиньте торрент-фаил - регистрация отключена.
Don
Цитата(Павел Тю @ Nov 26 2014, 11:40) *
Кто эксплуатирует обогрев боковых зеркал?
сколько стоит ? тяжело ли установить и цена установки
в инете написано что даже в дождь помогает, капельки не собираются, а стекают.
авто Лось
Тоже пользуюсь такими зеркалами на лосе. Установил их 2 года назад. Заменил только заводские зеркальные элементы на зеркала с голубым оттенком, корейские. Брал за 10 у.е. Установил у электрика за 10 тыс.
Включаю в снег или дождь.
IRON
Гдето около 60мб
где можно купить качественный ремень кожаный за вменяемую стоимость?
зашел в пойтахт, с цен ощущение что ремни делались вручную пандами из шкур кенгуру
Левайс
Цитата(TOUAREG @ Nov 26 2014, 20:05) *
ну так на "ней" обогрев включен всегда, как мне объяснили тут как то БМВводы smile.gif
в любое время года и суток) даже летом(может поэтому летом жарко?))))
Должен признать, что я был не прав. Оказывается зеркала и в самом деле обогреваются постоянно, сегодня по приезду на работу потрогал их, оказались теплые, хотя в машине работала только печка, обогрев стекла не включал good.gif
INTELigent
Недавно где-то читал, что на мерсах в цепи обогрева зеркал стоит некий термодатчик, который активирует цепь обогрева только при достижении определенной низкой температуры. Т.е. цепь обогрева активна постоянна, но включается только после того, как температура упадет до заданного уровня. Полагаю, что в БМВ аналогично построено. rolleyes.gif
Nikifan
Даже на старушке bmw е34 была такая система. На ней в частности на сам зеркальный элемент всегда при зажигании подавалось +12, а в зеркало был встроен этот термодатчик с несколькими ступенями нагрева.
Мне кажется не термо датчик, а скорее всего они начинают обогреватся вместе с запуском дворников, просто сегодня когда ехал, забортом было +12 и дождь. Хотя нужно будет проверить без дворников
Никифан прав, на Е30, 34, 36, 39, 38 так, далее не в курсе.
arthur87
От падения треснул монитор на ноутбуке, посоветуйте что делать и сколько будет стоить ремонт?
Tae
Тут только замена дисплея под конкретно вашу модель. + работа мастера.
кстати есть Форумчанин ремонтом занимается. VoV если не ошибаюс
VoV
Ответ дал правильно Tae.
Скажите, пожалуйста, модель Acer'a, можно в ЛС.
Совершенно верно.
VoV а как подключить доп. реле чтобы кнопка не плавилась? (Чтобы провод не грелся) Провода там многожильные, добротные.
peterpen
Попробуите в начале Карасарайской,где поворот от Чорсу в сторону Хастимама,по правой стороне будет бутик Бренд стар,та торгуйтесь лично я там уже штук десять взял и себе и сыну,по 50 тык отдают,кожанные турецкие,ктати терминал тоже есть!
Stoneface
Раскрывающийся спойлер
«Прятки»
Часто бывает так, что инспектор ГИББД и его машина появляются будто из ниоткуда, останавливают проезжающие мимо автомобили и штрафуют водителей за превышение скорости. Знай, это - незаконно. Да, 1 сентября 2009 года появился регламент, который разрешал «при осуществлении контроля за дорожным движением с применением технических средств фиксации нарушений правил дорожного движения использовать естественные и искусственные укрытия», но вскоре он был отменен с учетом закона «О противодействии коррупции», в котором говорится, что представители органов власти должны работать «публично и открыто». Так что, если тебя остановили при подобных обстоятельствах - сразу же говори, что ты знаешь, что это незаконно, и что ты будешь писать жалобы в соответствующие инстанции.
Взято из NNM uz. А у нас в РУз. есть такой закон?
INTELigent
Никто сеня-завтра с Алматы в Ташкент не летит? Захватить кое-что надо, ессно не за спасибо...
VoV
моник 15.6 матрицы взаимозаменяемы у всех производителей почти сам лично снимал с НР и ставил на асуса с китая заказать около 2000 рублей встало летом. сделать можно и самому ничего сложного нет я управился за час снял с одного ноута одну матрицу в него поставил новую а снятую запихнул в другой. в нете видео по замене полно
http://ru.aliexpress.com/item/Free-shippin...1106484074.html
вот такая матрица
arthur87
Спасибо за ответы.
fonvizin
«Прятки»
В России есть 100%,про нас слышал,но не практиковал))
Tae
Цитата(Smiler @ Nov 28 2014, 19:27) *
вот такая матрица
Я бы поспорил, что не все матрицы взаимозаменяемы, если бы все так было просто, то давно можно было в самый паршивый ноутбук, запихнуть IPS.
Я не помню какой сайт, но есть такой сайт, где под каждую модель ноутбука, показана инфа насчет матриц, вплоть до кода матрицы.
там есть как бы тип. одного типа матрицы стоят много в каких ноутах. главное чтоб он совпадал. кстати на хабре один перец выкладывал туториал как в какой то асус засунул айпиэс.
У кого есть акк на tforum. Узнайте пожалуйста контакты этого пользователя. Нужен 3d print.
http://www.tforum.uz/user/6814-how-eee/
krokus
3d принтер был у The Pirate Silver тут, и Павлуха там, но он в России сейчас..
Могу этому человеку в личку написать..
З.Ы. Написал, попросил номер.. Будет ответ-скину в личку..
Файз не думаю что твоя деталь будет работать печатаная на принтере. см3 200 сум был.
+998951946915 вот у меня в контактах есть. 3д печать.
Emil тоесть не будет работать?
Есть готовый файл на autoCad.
ну то что нагрузки скорее всего не будет держать. так как возможно просто будет рыхлая деталь. получишь модель детали с плохой связью между молекулами. имхо. так понятней?
хочу своей мамке сделать доверенности на продажу авто и на операции с банковскими счетами - никто не скажет какие доки для этого надо и сколько это вообще стоить будет?
forzeц
Оба паспорта и твое свидетельство о рождении. Простся доверенность для близких по первой линии 1 мрзп + накидка жадности нотариуса. Остальное вроде еще дешевле
krokus
Смотри в личке..
Redji
Народ, а кто в курсе, где можно купить в розницу пропиленгликоль ?
Tae
Кто-нибудь заказывал айфон из США лично без посредников?
Главный вопрос волнует насчет таможни, говорят что мозги будут крутить и просто так не отдадут, хоть даже если в таможенный лимит уложусь.
forzeц
Купи на али и не парься http://www.aliexpress.com/wholesale?catId=...al+Apple+iphone
Tae
wink.gif да, нее, спасибо))
Андроида сейчас наелся, теперь вот хочу обратно на родину яблонь))
Просто пугают что без завязки на таможне не получишь его, хоть и входит в лимит.
Enigma
Не покупал, но друг отправил для своей сестры но на мое имя Iphone 5c. На таможне сразу же сказали идти брать какой то сертификат радиочастотный. Ну минут десять разговоров о том, что это подарок убедили таможенника отдать телефон, с ремаркой что если вдруг кто спросит чтобы сказал что телефон б/у.
Tae
ого, это что за приколы еще?
мне одному таможенники напоминают гаишников?
просто айфон с доставкой в лимит вмещается, я могу же с инвойсом им свои права качать? что с какой стати они требуют с меня что-то?
Или у нас такое не проканывает? хочешь телефон, плати...
sparkv
простой простой вопросец:
для чего когда ставят двухтоновые дудки, на спарк, например, подключают их через реле?
ведь в схеме штатное реле уже есть.
что, если просто к штатноому разъему подключить раздвоенный провод в двум дуделкам?
штатные реле на какой ток? дуделки на какой ток?
forzeц
Открою тебе секрет, папа может и американец, но роддом точно китае, в шанхае
И они не фейковые, реальные смарты. Но я яблоко всё равно не хочу андроид гораздо интереснее, хоть гемморнее порой
http://m.aliexpress.com/item/32224597956.h...obilesitedetail
http://m.aliexpress.com/item/2032035069.ht...obilesitedetail
Я покупал, доставили через Атлантик. Таможенники остановили. Пришлось ехать к ним. Спросили "себе?,-да! вот с но кичей хожу, -все ок забирай!"
насчет моей коробки, сняли и отвезли аргоншику, все сделали и одели обратно. Славу Богу все держится надеюсь еще раз не отвалится
Цитата(Becho @ Nov 20 2014, 10:03) *
У кого нибудь из форумчан есть в использовании дрон квадрокоптер? Если есть дайте отзыв и какая модель пожалуйста.
Использование беспилотников запретили
В Узбекистане с 1 января 2015 года вводится запрет на ввоз, реализацию и использование беспилотных летательных аппаратов (код ТН ВЭД 8802 20 000 0 — самолеты и прочие летательные аппараты, с массой пустого снаряженного аппарата не более 2000 кг).
Цитата(Hobbit @ Dec 1 2014, 10:39) *
sad.gif sad.gif sad.gif....ну запретили бы с камерами, определенным весом и габаритами..., а игрушки то пошто?
dimoon
Да потому-что наш народ начинает всю эту херь запускать там, где нельзя. Если лазер купил, то в самолёт светить, дронов и прочую лабуду в секторах захода и взлёта будут запускать вот вам и результат.
Becho
Цитата(Hobbit @ Dec 1 2014, 09:39) *
Пляя....Я уже заказал себе((((
Скорее всего изза AirDrone такое сделали.
VoV
вот такая матрица
Не согласен с выделенным.
Цитата(arthur87 @ Nov 28 2014, 19:47) *
Спасибо за ответы.
Ответил в личке.
Правильно!
Редкие случаи, но бывают.
