Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(Maksim @ Dec 1 2012, 23:53) *
НЕКСИЯводы! К вам вопрос: У вас на расширительном бачке стоит такая же пробка: Пробка Нексии. Получается она и на ВАЗ 2115 подходит?
по виду не определишь, но по цвету другая.
на базаре трудно найти оригинальную крышку, цена ее около 20тыс за оригинал, китай 10.
Rascal
Себе ставил расширительный с нексии и вот такую крышку http://www.sk-motors.org/product/Kryshka-n...elnyy-bachok-GM, подрезая пружину.
Вот ее обратная сторона:
А зачем пружину подрезали? Не соответствовало параметрам, или в Нексии давление, по умолчанию больше? И чем желтая от черной отличается?
ARI100KRAT
у меня тоже стоит желтая (по заводу)
один в один по фото.
отличаются только цветом ИМХО...
вопрос! :В данное время на ТПСе неизрасходованный трафик переходит на след месяц лишь в тарифах FTTB?
ferteeee
на сайте ТПСа глянь, в тариффах. Все написано. Какой трафик на каких тарифных планах переходят на след месяц..
Кто знает телефон автомагазина "АНТЕЙ"?
296-91-91 это телефон строительного магазина "АНТЕЙ".
И работает ли автомагазин "АНТЕЙ" по понедельникам? И во сколько начинают работать?
Rascal
Да, больше, чем нужно на узам
DenDiesel
Подскажите плиз рабочую температуру охлаждающей жидкости в двигателе DAEWOO NEXIA... Еще интересует температура включения и выключения вентилятора...
ее вроде любую можно поставить. во всяком случае у себя я могу поставить любой порог включения rolleyes.gif
вероятно, сток интересует?
Подскажите плиз рабочую температуру охлаждающей жидкости в двигателе DAEWOO SEXIA...
80-110 (от термостата зависит)
включение есть от 90 до 110, выключение от 80 до 98.
ps: всё на личном опыте
каким образом зависит температура включения карлосона от термостата? unsure.gif чего я не понимаю?
Цитата(TOUAREG @ Nov 30 2012, 21:03) *
ищется вот такой блок управления, но с циферькой "3" вместо "7". обошел сегодня весь "стройгород", в наличии только "семерки" sad.gif
Видел сегодня в магазине на паркентском, только там был y-7f по-моему!
Открывается термостат, идёт ОЖ на радиатор, после него сразу же на датчик включения "карлосона", он включается и охлаждает радиатор и жидкость проходящую через него, как тока до датчика доходит ОЖ с пониженной температурой, он выключает "карлосон".
то, что я вижу на картинке(Таз), это карбомотор. но эту схему установки датчика включения карлосона уже давно признали неудачной. установка датчика в верхнем патрубке радиатора(подача от двигателя) более удачна, и снижает тепловую нагрузку системы в целом за счет более своевременного включения карлосона.
вот так:
на впрысковых вариантах датчик температуры установлен уже в стоке на входе в верхний патрубок.
я чтото не совсем понимаю...датчик включения вентилятора у меня отстутсвует. есть датчик температуры, по показаниям которого ЭБУ управляет карлосоном. верно?
на Ксю стоит датчик включения вентилятора???биметаллический, как на старых тазах??
DenDiesel
угу, сток...
Да, действительно, та схема про которую вы говорите - дерьмовая... пока сработает вентилятор, мотор уже перегреется smile.gif
У меня ЭБУ "Январь"... Им можно управлять температурой включения - выключения вентилятором...
Просто хотел узнать сколько по нормам там градусов (в системе) должно быть smile.gif
Valeriy
У меня вентилятор включается ровно на 97 гр. цельсия, выключается на 93 в любое время года. Показания вижу по бортовому компу Multitroniks, который считывает показания из ЭБУ. Рабочую температуру точно не знаю, думаю, что где-то в районе 90 гр.
От термостата зависит, на какой температуре подключается и закрывается большой контур. Температура включения вентилятора прошита в ЭБУ, теоретически вероятно можно перепрошить.
Такой же. Даже подходит по размеру и резьбе к вазам (их всего несколько стандартов). Российские даже точнее чем корейские "оригинал". Штук 5 наверно поменял и все от фонаря работают.
DenDiesel
shumbola
Кто может помочь с доставкой вот такого чехла?
P.S. Не обязательно с aliexpress
Marat
Цитата(gluckboy @ Nov 30 2012, 22:34) *
никто не знает телефон стп бузтона? их номер 1400222 - фигня какая то гооврят для оператора нажмите 0, жмешь ноль а оно опять говорит для оператора нажмите ноль. прикалываются чтоли
зайдите на http://0611.beeline.uz/ и открывайте чат с поддержкой - быстрее чем звонить и по результату всегда есть лог общения.
Цитата(LADA-FAVORIT @ Nov 30 2012, 22:06) *
А в чем разница?
я себе такой на лампочку поставил,удобно,вставать с постели не надо чтоб вкл/выкл освещение. Один пульт на 3 лампочки можно подключить. Говорят берёт со 100 м(не проверял). Только мой с др. надписью "TOMATO"..
А разница у них в том что 7-ки, если выключат подачу электрорснабжения дома,то как "свет придёт" лампочка останется включенной. 3-ка останется выключеной. Это своими словами,не электрик я))
Valerka
Фото с пространства нета или собственноручно сделанное? Вопросик по 2х катушечному зажиганию появился...
man_in_white
Я вот таким пользовался
http://www.noo.com.by/products/index.php?id=10
отличная штука. Срабатывает от любого пульта.
Цитата(DenDiesel @ Dec 3 2012, 09:39) *
эх, забыл фото сделать...у меня врезан ксюшный датчик в верхний патрубок rolleyes.gif
dyo999
Друзья подскажите, до скольки лет нужно прописать ребенка по месту прописки родителей?
Заранее спасибо за ответы.
Вписывать можно до того момента, когда Вам его прописка где нибудь понадобится. Например в садик или в школу. Только учтите, если например пропишете когда ребенку будет 6 лет, то и коммунальные услуги возьмут тоже сразу за шесть лет. То есть с рождения до момента прописки, и все разом.
Кто знает турецкая фура(13,6м) за примерно сколько бабок привезёт товар по маршруту Станбул-Ташкент?
apachi
в районе 10 К$ только будет узбекская фура
Valerka
Цитата(TOUAREG @ Dec 3 2012, 20:15) *
Значит конструкция вместо модуля зажигания? Хотел поинтересоваться по живой схеме реализации (какие коммутаторы, схема проводки) и как ощущения.
11 000$
Узбекских фур которые так возят товары очень мало...
vladno
Интересно у наших туроператоров бывают горячие путевки
Бывают! Но редко. У нас в основном идет индивидуальные заказы. И редко какие тур фирмы покупают блоки мест.
Morozzz
Посоветуйте пожалуйста продавца аккумуляторов, нужно купить новый аккум, может просто у кого есть доверенные продавцы, у которых стоит приобрести товар?
Scarlett
Вроде у Файза отец занимается аккумуляторами (если я не совсем отстала от жизниsmile.gif)
Morozzz
Я тоже вроде помню, что занимается. Вот сейчас и подскажет где его найти)))
slako
вот его тема
Morozzz
Цитата(slako @ Dec 4 2012, 14:37) *
вот его тема
Упс... спасибо!!! Проглядел!
Фура со Стамбула неделю назад стоила 10 штук
А обратно за сколько они обычно ездят? Если загрузить чем-нибудь.
AndreVla
Это ещё найти нужно клиента... а это гораздо сложнее =) (из личного опыта)
ЗЫ Кстати, тут писали, что фура будет наша. Тоже так думал, но с сентября пришло уже 2 фуры турецкие и водители турки.
shumbola
Подскажите о процедуре продажи машины. Это у меня намечается в первый раз. ;-)
ARI100KRAT
в первую очередь находите клиента, далее дорога ведет в ГАИ стоите в очереди и ставите в Тех.Паспорт печать "Агрегат" после чего едите в район Максима Горького гостиница Саёхат там есть нотариус который выдает справку что машина не в угоне и не под залогом после сбора всех документов едите в нотариус платятся деньги ВУАЛЯ машина переоформлена!!! в принципе все! pardon.gif
Справку о том что нет запрета на продажу делают почти везде .
shumbola
Спасибо. Хочу уточнить:
-в ГАИ для печати "Агрегат" нужно ехать на продаваемой машине или на любой?
-"после сбора всех документов" - какие документы имеются в виду?
Почти везде - имеется в виду почти в любом нотариусе?
Да , по крайне мере я был в 3х и во всех они предоставляли такую услугу .
На своей. Будут смотреть и сверять ваш номер двигателя и кузова. Почти тоже самое, что и техосмотр. Получите печать в техпаспорт на 10 дней.
В любом нотариусе прибивку на "угон" делают.
И ещё, главное, при оформлении документов у нотариуса, обязательно должна быть ваша супруга.
Она там будет давать разрешение на продажу авто и что не против его продажи. Без жены, нотариус не оформляет документы.
упс. сори)) нов провайдер. у меня. тройной постинг получился
