Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Nikifan
99 % файлов можно восстановить при Shift+delete только при условии что после удаление не было никаких операций записи и, разумеется, дефрагментации. R-studio неплохо восстанавливает, последнее время им пользуюсь. Если Вы еще на юнусобаде живете, вечером во двор выходите - сделаем.
Что касается файловых систем. В принципе для обычного юзера без разницы ранее было FAT или NTFS, но с каждым годом объемы растут и тут уже начинаются ограничения ФС, в частности FAT32 не поддерживает большие файлы, около 4 гб там предел - точно не помню. Тоесть в нынешнее время ФС устарела уже.
Файз я же Вам как раз и говорил про файловую систему, просто флэшку любую найдите - киньте на нее клип там или еще что нибудь и посмотрите будет ли она работать на тюнере, затем отформатируйте ее в NTFS (т.к флэшки чаще всего FAT32) и проверьте заного. Так-же помимо питания бывает ограничение по объему. Такое еще на старых материнках было, которые "не понимали" большие объемы хардов. Т.е в теории и такое может быть, но это решаемо - можно разбить хард на сколько угодно разделов.
В общем нужно тестировать и смотреть в чем именно причина.
К стати достаточно простая идея по организации доп питания - купить 2 юсб удлинителя, один разрезать и подпаять ко второму только 2 провода питания. Получится удлинитель с двумя "папами" и одной "мамой". На подобие родных от хардов. И потом один конец (который с датой) вставить в тюнер, второй конец вставить к примеру в зарядку от айфона. Единственное что там наверно диоды еще нужно будет впаять, чтоб не пальнуть тюнер и зарядку.
Lawyer
Вот еще информативная статейка по восстановлению данных - http://www.babyblog.ru/community/post/computer/172056
Нужен токарь, чтобы с максимальной точностью изготовить вот такие детали,
из такого же металла. Из какого они сделаны, не знаю. Где есть такие?
небольшой коммент - брелок наверное сюда не входит?!
Lawyer
Брелок - актуально )) с металлическими кнопками ))
screwjack2007
Никто случаем не знает сколько стоит билет на концерт Эннио Мариконе а Ташкенте?
Брелок отображен для более верного восприятия размеров изделий.
Лучше металлический брелок.
Саня, у Славика есть кент - который якобы Славкин препод или наставник (как он грил) - вобщем у него есть компьютерный резак CNC...
Не помню какой у него ник тут был на форуме, ну вобщем через славку к нему выйдешь. Помоему Павел зовут его.
Pirate Silver. Завтра поинтересуюсь. Но цены у них гуманностью не отличаются.
Цитата(Alexan_Der @ Sep 20 2011, 20:52) *
... Но цены у них гуманностью не отличаются.
да, но возможности rolleyes.gif ....
зы. тебе нужен просто нормальный токарь...без СNC всяких...
Ага. Есть такой? И есть способ определить металл, из которого шайбы изготовлены?
ну на самом деле те лазерные резаки, режут конечно. я знаю 4ре места где это можно сделать.
Но рез не идеальный.
В ДГ вроде самые гуманные цены.
у токаря будет без лишних телодвижений в виде доп мех обработки. имхо
не совсем понимаю...ты сталь\чугун от латуни\бронзы отличить не можешь? ну или там...титан от люминя)))))
скорее всего тебе надо определить твердость?
что это вообще такое... таинственное?
Ну да, скорее твердость. Это детали масляного клапана, системы изменения фаз газораспределения.
Похоже на сталь. Возможно нержавейка.
магнит тебе в помощь)))
Осталось найти токаря))
Йос
У Сан Саныча токарь нормальный, Николаем кличут.
Он там же у Саныча и токарит?
Йос
Да, поворот на Куйлюк по трамваю, дверь посреди стены рядом с останановкой, сам там небыл, точне не подскажу.
Я там был, не знал, что там есть токарь...
Пасиб!
подключился к провайдеру узонлайн,вроде тасикс бесплатен,подскажите наш торрент трекер который входит в тасикс!??
tas-ix.net
torrent.dchub.ws - трекер тпс
так же советую включить IPfilter в настройках торрент клиента, чтобы исключить утечку трафика
Нужно купить относительно недешевый телефон в Ташкенте и передать/довезти до Ургенча - есть кто может помочь?
вернее меня интересует какие телефоны предпочитают наши леди!
Nikifan
Цитата(Hobbit @ Sep 21 2011, 20:07) *
tas-ix.net
storent.org - наиболее богатый торрент в тас иксе. Так-же советую айпифильтр настроить, благо на этом трекере есть тема с указаниями - "как"
lady_in_black
я бы предпочла Соню Арк smile.gif стильно и функционально smile.gif фотокамера тоже отличная! и не дешево! smile.gif
Советую подождать до 15 октября - выход обновленного iPhone.
Цитата(Талгат @ Sep 22 2011, 10:15) *
...выход обновленного iPhone.
Maer
Подскажите, пожалуйста.
Где можно сделать, Sehr Gut good.gif развал?
Заправка на Узбуме
Maer
Цитата(puzo @ Sep 22 2011, 14:36) *
Заправка на Узбуме
lady_in_black
Цитата(Andrew @ Sep 22 2011, 10:24) *
а мне - неть.. unknw.gif cray.gif все время ищу подвох в нем... мне проще со шведами или финнами, они такие открытые... pardon.gif
PilotUTTT
Заправка на Esso(Geksan) .Мастер Дима
Точней презинтация 4го октябра. Продажы с 21 октября.
ссылка
что-то не получается восстановить удаленные файлы
Hetman Uneraser находит какие-то jpeg файлы потом восстанавливает их сохраняя на жестком жиске но когда пытаешься открыть - то они не читаются - в чем может быть проблема? тоже самое и с видео файлами!
man_in_white
Может быть уже никак.
На расширение посмотри. Бывает что нужно только прописать название и расширение. (.jpeg итд)
где прописать - в поиске? так у меня там фоток на 20 Г стерлось ты че?
NTFS - система довольно безопасная. Защищает, в том числе, от попытки восстановления удаленных файлов. Это не FAT, где в начало названия файла ставится спецсимвол и этим он считается удаленным. С NTFS гораздо меньше шансы на восстановление и очень много зависит от того, как именно эти файлы были удалены.
По-моему лучше обратиться к профессионалам.
ладно чере месяц привезу может кто поможет!
Только чур ничего с ним не делать с сегодняшнего дня.
man_in_white
Тогда тебе придется выключить комп и не пользоваться им.
Это точно. Много раз ловил синий экран, и ни разу не потерял файлы на NTFS, чего не скажешь про FAT.
только не кидайтесь камнями - после того как я удалил эти файлы с внешнего харда - я на него кучу фильмов записал - это все ппц значит да?
Цитата(lady_in_black @ Sep 22 2011, 14:42) *
Nokia РУЛЕЗ ))
намного удобней любой другой марки )
ну да, он же записывает на то место которое освободилось
Nikifan
Это уже почти 100% все, особенно если хард под завязку забили.
Лао Цзы
Ну что же ты раньше молчал)))) я завтра с Ургенча утром уже улетаююю
Вопрос скорей всего к Скуллу.
Вот снял где у меня проблема с спутником. Проблема прыгает качество и соответственно не показывает. (Частично так бывает)
Цитата(SKULL @ Sep 18 2011, 00:07) *
1. Проверить LNB (головку)
2. Проверить DiSEqC (переключатель)
3. Проверить кабель и его соединения (возможно где то окисление)
зы: если шару смотришь с НТВ+, то в головке стоит поляризатор, возможно что он не правильно стоит.
Сделал видео проблемы. Теперь этот круг сужается? или?
зы: в головке НТВ+ стоит поляризатор, возможно что он не правильно стоит. (проверь)
psps: Файз, на НТВ+ круговая поляризация (L R), у тя на видео стоит линейная (H V).(попробуй поменять)
из 1 ТВ забито 600Г
