Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(Limitless @ Mar 12 2012, 13:45) *
...если можно найти ту )
Можно ли? Если найдете в Ташкенте, да еще по цене дешевле чем "оттуда" - вы исключительно везучий человек. wink.gif
Цитата(akrom @ Mar 12 2012, 12:15) *
где можна найти такой переходник?
нужно подключить 2 датчик на давление масла
Цитата(Andrew @ Mar 12 2012, 12:30) *
Лучше, выточить у токаря из шестигранного стержня. Можете заказать на ибее, но, цена будет не гуманной из-за стоимости доставки.
чем классический не устраивает? всего то на два датчика!? в свободной продаже имеется, в комплекте с медными шайбами. центральную футорку, если не устраивает по резьбе, переточить можно. тем более, как понимаю, один из датчиков будет как на картинке, классический pardon.gif
Цитата(Andrew @ Mar 11 2012, 23:35) *
Я до сих пор ее не нашел. Про то, что найду в Ташкенте, я перестал мечтать в первые же пару дней поиска. wink.gif
Я купил такую смазку от Hi-Gear на Фархадском базаре в магазине " AGA"
так и написанно " Тефлоновая смазка "
Стоит в районе 24-28 тысяч сум.
Позже могу скинуть фотку и состав данной банки.
Мне не "написано" нужно, а содержимое. А Хайгир не отличается особой щепетильностью в отношении написанного на их продукции.
Shavkatov
Где в ташкенте купить книжки на английском? Чтобы не ждать доставки. Цум и книжный мир смотрел. Интересуют David Nicholls - One Day, и Ден Браун - Ангелы и Демоны.
Цитата(BadVik @ Mar 12 2012, 10:34) *
Парни, я как-то разладился с физикой, кто сможет посчитать две веши:
1. Сколько воздуха в литрах или м3 находится в емкости, под давлением 6 бар, температуре 115 градусов? Внутренний объем емкости 6,4 м3
2. Сколько воздуха находится в ресивере, объемом 430 литров (0,43 м3) под давлением 9 бар?
Чет я поподнимал в памяти формулы Бойля-Менделеева-Мариотта, но как-то не про меня это уже, знания совсем никудышные... Буду признателен!!!
Парни, неужто все двоешники как и я ))
на днях брал такой. стоит 8500
shumbola
Я троечник, и поэтому скажу :-)
1. 6.4 м3
2. 430л.
Или вопрос был другой, а именно, сколько литров воздуха в нормальных условиях, можно закачать в эти емкости? ;-)
мне тоже нужен. один штук) каждый раз, как приезжаю на базар, забываю прикупить rolleyes.gif
1. 6.4 м3
2. 430л.
Чет я не понял - объем я и сам выше написал! Речь о том, сколько в этих объемах вбудет воздуха под давлением. В одном (430 л.) просто под давлением 9 бар, а в другом (6400 литров) под давлением 6 бар, но еще и при температуре 115 градусов...
Тут же карта России нужна! (Цитата одного юмориста). Иными словами надо уметь считать зависимость объема от давления и температуры.
shumbola
Мне кажется, вы вопрос не правильно ставите.
Конечно, нужно знать законы идеального (хотя бы) газа и условия задачи. ;-)
azet
У меня такая проблема На пороге кухни отвалился кафель!! Начал приделывать цементом Он не держал и выпирал после этого!!!
Чем посоветуете Приделать? ?????
6.4x6+((6.4x6x(115-20)/273))=51.8 м3.
Если температура +20C, то 0.43x9=3.87 m3
не нужно приделывать!
лучше приклеить. любым спиртовым клеем. если такого нет в наличии, что вероятнее всего, подойдет ПВА. выпирать не будет. в течении пары суток желательно оставить в зафиксированном виде(скотчем).
ищется такой адаптер под датчик (размер- под патрубок радиатора, надо уточнять). на сергилях никому на глаз не попадалось?
azet
+1 Спасибо!!!!
Ну вот, оказывается все вот как просто )) Спасибо! Правда я бы никогда не подумал, что при норм. тепературе объем можно просто умножать на давление... Спасибо!!
п.с. Дополнено: Хотя... отчего то мне кажется, что при увеличении температуры, увеличивается и давление воздуха, а следовательно, его нужно меньше, чем это было бы при, например, норм. тепературе и давлении 6 бар - т.е. 6,4*6= 38,4 бар - или я не прав? Хм, отя плотность его конечно уменьшается. Блин, где зерно рациональности?
Shavkatov
Цитата(Shavkatov @ Mar 13 2012, 02:40) *
Может в McMillan Bookshop? Раньше они сидели на алайском, рядом с МТС. Сейчас не знаю точно куда переехали (точнее видел где-то вывеску, но не помню где).
JaZ722
Кто может помочь в настройке вай-фай модема/рутера в режим ретрансляции? Модем tp-link TD-W8901G
ferteeee
Имеется вот такой маленький домашний кинотеатр, как его нужно правельно подключить к телевизору.
Кто знает какие кабеля нужны?
shuguroff
Помогу. На каком шаге встал процесс?
Диаметр 38мм?
Напротив гост Чор-Су, со стороны базара, там где проход на базар. Первое же здание слева - там был некий международный языковой центр, у меня друг приезжал преподавать в нем... Так вот, в нем была шикарнейшая библиотека (печатные и аудио/видео материалы). Если этот центр еще жив, можно посмотреть там.
PS. Рекомендую попробовать именно библиотеки. Где-то была еще при Британском Совете, и т.д.
Нормальные условия для газов - давление 1 бар, температура +20С. С повышение. Температуры на градус объем увеличивается на 1/273. В первой формуле это учтено, т.е. Объем при нормальных условиях плюс поправка на температуру по формуле Шарля. Во втором вопросе про температуру ничего не сказано, поэтому я и написал "если температура +20 по Цельсию.
Этот bookshop, если не ошибаюсь, видел неподалеку от кинотеатра Казахстан. Если ехать в сторону стадиона Старт, следующий перекресток, слева возле магазина Indesit.
Цитата(Andrew @ Mar 13 2012, 10:16) *
Диаметр 38мм?
смерил диаметр патрубка радиатора, у основания- 32мм.
ктати, о сечении...а как правильно диаметр адаптера подобрать? ведь в него будет вернут температурный датчик, который перекроет приличную часть(по сечению). этим можно пренебречь, или лучше поставить адаптер бОльшего диаметра...на 36-38мм?
Да, ну. Там совсем чуть он перекроет. На тех картинках, рассчитано, датчик 1/4 дюйма диаметром на резьбовой части (~5 мм диаметр головки) и высовывается внутрь он на 2-3 мм.
у меня датчик с резьбой М12х1.5
та часть, которая будет в полости адаптера, имеет длину 18мм при диаметре 8.5мм.
размер отверстия под датчик(на адптере) меня интересует меньше всего. лучше, если не будет соотв, чтобы был меньше. перережу без проблем. если больше...сложнее, но решаемо.
Вопрос...
Если хорошенько втопить на 3-й скорости, появляется 1 такой легкий "провал" (слегка дергается).
При обычной езде без таких резких разгонов ни на 2,3,4 никаких провалов нет.
Что курить? Свечи, Карб или зажигание?
Цитата(V@ldemario @ Mar 13 2012, 11:53) *
Вопрос...
я серьезно))
Цитата(TOUAREG @ Mar 13 2012, 11:57) *
я серьезно))
Кстати да... давно его не менял. smile.gif А почему при обычных городских ритмах (т.есть на 3-й 20-50 км/ч ) такого нет? А когда дотягиваешь на 3-й до 70 получается провал? хотя раньше все было ок.
Кстати, а может двиг не прогрелся еще до нужной температуры?.
Цитата(V@ldemario @ Mar 13 2012, 12:08) *
Кстати да... давно его не менял. smile.gif А почему при обычных городских ритмах такого нет? Кстати, а может двиг не прогрелся еще до нужной температуры?.
корпус фильтра прозрачный? посмотри на него, он не должен быть заполнен полностью бензином. если он полный, то он забит.
то, что ты опИсываешь, на 99%- фильтр.
да прозрачный... вроде как раз забит.
сделай как я сказал в аське, и приезжай за фильтром. как на на форсе- фильтр в подарок)))
патамушта кури матчать на низких оборотах нужно меньшее количество топлива а когда требуется большее бенз уходит с поплавкой камеры больше чем туда поступает и как жиклеры оголяются появляется провал потому что топлива нет гореть нечему как еще пачка топлива попадет на них еще поедет. а если еще не прогрелся до рабочей температуре мотор будет тупить на низах на верхах он должен ехать лучше, если этого нет проблема с топливоподачей. либо бензофильтр либо бензонасос
rolleyes.gif Как раз это мне TOUAREG в аське и объяснил ....
bek69
Есть ли положение (указ) как индивидуальный предприниматель может начислять себе заработную плату. И сколько по суме можно начислять.
Был сегодня в банке, там сказали, что индивидуал вообще не ожет получать заработную плату nea.gif
akrom
уже купил такой, будем экспериментировать, бачёнка два посмотрим какой подойдёт
MAGIK
Кто нить подскажет, адрес, где в Ташкенте можно получить международное водительское удостоверение?
Maer
На Глинке… после здания бывшего Гаи.
Над дверью будет висеть вывеска.. не пропустишь.
MAGIK
Глинка, это 1-я нотариальная? если был бы конкретный адрес былоб получше.
а разве наши права не международные? это контора лоховская
+1 костасу
MAGIK
наши права не удовлетворяют приложению №6 Венской конвенции, и в Раше с НГ запрещают работать по этим правам, вот теперь мне нужно моим водилам права сделать международные. Хрен знает что делать.
Костас сам видел такие права. Эта какбы офф перевод на 13 или сколько там языках. Приложение без прав не действительно. Знакомый вообше брал межд. права через интернет в США. Надо у него также спросить.
MAGIK
международные права выданные не в государстве постоянной регистрации и гражданства вообще считаются не действительными
Щас славян напишет что он в Раше и это чушь.
MAGIK
я тоже в Раше
и это не чушь. а главное мои водилы уже с этим столкнулись. я как гражданин узбекистана, не работаю водителем и спокойно езжу с нотариальным переводом, а вот совершать трудовую деятельность водителем без наличия международного ВУ , запрещают сцуки
Именно в раше, после НГ и использовал эти права. А еще в Беларуси, Kz, US, PL, LV и Es. И все в этом году. И ни у кого вопросов не возникало.
PS. Итересно, в какой части они не удовлетворяют "приложению №6"? Что фамилия и имя должны быть указаны латиницей во французкой транскрипции, а не кириллицей? Или из-за отсутствия названия документа на французком? Или, может быть, из-за отсутствия класификации разрешения по категориям A-B-C-D?
