Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Цитата(Lexville @ Mar 17 2011, 09:07) *
в принципе у каждого свои причины наверное, но у меня по свечам виден был явный перелив на 2 форсах из четырех (по цвету нагара), тупила машинка при разгоне, нестабильные холостые и набор оборотов. Как то так....
мне действительно интересно))) часто слышу, а сам еще не чистил ни разу)))) на БК интересно это както можно увидеть? длительность впрыска теоретически должна подняться?
На БК не будет видно. Например, засрется одна форсунка, будет лить 75% на ХХ, так лямбда заставит все форсы увеличить производительность на 7%. Т.е. если раньше была длительность 1mS, станет 1.1mS В пределах погрешности БК и в пределах погрешности по бензину с разных АЗС.
А тому цилиндру, на котором форс меньше льет, может прийти белый пушистый зверек.
Кроме этого, засратые форсы:
- Могут по-разному меньше лить на разных режимах.
- Не распылять топливо
- Пропускать топливо в закрытом состоянии
И как здесь определить?
хорошо...какие то методики определения состояния форсунок существуют? не снимая. какой регламент обслуживания у них вообще?
ferteeee
у меня машина начала троить или пропускать зажигание на ХХ.
поменял все свечи, провода, фильтра, ставил новый модуль зажигания - эффекта ноль.
пробег 52 тысячи, думаю форсы. больше нечему.
У меня, по регламенту, только снимая рейку в сборе, проверка штатным давлением бензонасоса.
PS. Кстати, вижу, требуемый разброс - не более 5%. Протечка в закрытом состоянии - не более 1 капли в минуту.
yan
Кстати, тоже наболевший вопрос... пропуски зажигания и небольшое "троение" движка на ХХ. Также поменял уже провода свечи почистили мне дроссельную заслонку - эффекта нет. Прыгают обороты, иногда зависая на 1 300- 1 500 оборотов. Не знаю чего дальше предпринять sad.gif
Я сегодня пешком, с утра сцепуха провалилась :))) хорошо что не на дороге, а на стоянке. Пол бачка жидкости вытекло, и течет дальше... при этом педаль качается но на 4-5 качок опять проваливается и остается.... течет не в салон, а на улицу. Вот думаю скорее манжеты, чем циллиндр, как бы еще до мастера добраться :)... хотя без педали ГАЗа добирался.... :P
ТИМУР_
У меня такаяже фигня
По степени вероятности проверяется "от и до" пока не устранится проблема: система зажигания (свечи, провода, распределитель и катушка), система подачи воздуха (флюр, каналы (целостность гофры и т.д.), ДПДЗ), система подачи топлива (давление в рейке, форсы). Вот на давление в рейке низкое очень даже можно грешить )))
mishan78
Приветствую всех!Такой вопрос,где можно посылку в США отправить?
Слева от северного вокзала, между китайским рестораном и зданием таможни, есть закуток, в котором кучкуются почтовые службы: Узбекистон Почтаси, EMS, Арамех, UPS(?) и DHL. Все они могут отправить вашу посылку в США. C разной скоростью доставки и за разные суммы денег.
mishan78
понятно спасибо!а в субботу работают?
Можете вызвать курьера.
В субботу у многих компаний короткий день типа с 9 до 12.
Самый дешевый выйдет EMS www.ems.uz
Самый дешевый - Узбекистон почтаси
И тот и другой - местные службы. Цены за доставку и время работы указаны на сайтах.
mishan78
по слухам фархадку ломают, а магазин Тимур там остался еще? на выходных собирался поехать закупится немного.
sad.gif(( Эх как назло надо завтра с утра было за запчастями ехать......
Актуально составить список магазинов которые в городе функционируют....
Ага, с их контрольным сроком доставки от 30 до 60 дней. Офигительная почта )))
Где 30 дней эта посылка пролежит на складе в Ташкенте, а потом улетит ))) поездом )))
EMS - дешевле выходит по отношению к другим курьерским службам. И скажу вам по секрету - все компании в Узбекистане - такие как DHL, FedEx и прочие - доставляют свои посылки по Узбекистану именно через EMS!
Азиз, я не спорю, что EMS оптимален по цене/качеству. Я просто тупо ответил на вопрос, что дешевле.
А у служб экспресс доставки - DHL, FedEx, UPS есть свои терминалы и таможенные склады. Они не через EMS работают, точно. Прилетает их самолет, разгружается на их склад, они оформляют и сами же доставляют. Но, дорого.
сергели цветет. сегодня был там))
The Pirate Silver
Солнышко, вот и цветёт...
Это понятно... просто не верится что все снесут на Фархадке, там же их много, по разным сторонам дороги, тот же Манчестер ?.... или вот все подряд?...
да наврядли все магазины снесут , снесут скорее всего те что внутри ,которые продают Китайское барахло винтики,болтики,гайки, пластмассовое барахло,мелкие зап.части и т.д.
Как раз внутри и было несколько приличных магазинов, там внутри же еще салон Лада....
там 2 магазина было нормальных внутри толковых больших
На одном магазине сверху висел плакат УАЗ патриот черного цвета
а второй магазин - автосалон ( где барахолка)
У меня там был магазин который на протяжении, нескольких лет продавал мне приличные запчасти с гарантией и ценой ниже чем у других smile.gif... на вид он был как самый обычный и ничем не приглядный.
fonvizin
Не знал куда писать,написал сюды))
Уважаемые форумчане,огромная просьба(не по авто теме)ответить на вопрос...
Есть ли определёное название у рычага управления двигателем судна
ПЫСЫ:Смотрите на фото
это хорошо
The Pirate Silver
Вот.
fonvizin
Цитата(The Pirate Silver @ Mar 18 2011, 12:33) *
yan
пысы. "именитые" сервисы, усиленно тут рекламируемые не помогли... только разве что к знаменитому Ачи осталось поехать... но не знаю примет ли он меня с моей "старушкой" 2006 года выпуска.
никаких слухов. токо что оттуда приехал я - ЛОМАЮТ барахолку. видел сам.
ferteeee
Значит все авто магазины (работают) на месте и внутри и снаружи???
yan
Цитата(eclipser @ Mar 18 2011, 15:18) *
Упс! Так все просто?! =))) Будьте добры - где - кто - почем? Поеду, обязательно поеду!
yan
За автозапчасти - ничего сказать не могу, не дошел я сегодня до них. Покупал фрукты\овощи на Фархадке, авто оставил на стоянке (за которую ДО СИХ ПОР!!! дерут кстати 1 500 сум, хотя и запрещено это вроде как) так вот когда подъехал - обратил внимание ВСЕХ ПРОДАВЦОВ НА БАРАХОЛКЕ разогнали и ломают, ломают, ломают...
Дозвонился до продавца авто магазина в котором обычно все покупаю (он внутри базара, рядом с салоном). Сказал что все работает, никаких проблем нет smile.gif Завтра в 9 еду за запчастями.... yahoo.gif
магазин тимур тогда тоже должен остатся на месте. завтра тоже поеду... разведаю
На данный момент в самом начале Фархадского рынка - в так называемых автомобильных рядах мардикеры в ускоренном темпе ломают полтора десятка легких павильонов, где продавались запчасти для автомобилей.
Скорость сноса определяет отношение к сохранности стройматериалов. Вместо того, чтобы демонтировать новенькие пластиковые панели, мардикеры их безжалостно крушат кувалдами.
«Нам сказали, что снос производится в целях пожарной безопасности, - объясняют происходящее продавцы соседних магазинов, - мол, если вдруг возникнет пожар, то павильоны помешают проезду пожарных машин».
ссылок не даю, очевидно сносят незаконные постройки.... так что все в порядке.
Ачи тоже может не помочь
мы ездили и не только к нему , помог сделать только дядь Андрей Skull
стоянка законна если: при въезде вам дали чек ,есть терминал,кассовый аппарат и т.д.
Ну а что на рабочих обижатся ,им дали приказ и его надо выполнять
А там как говорится ...... сами знаете
ARIF
ну да, конечно, куда уж Ачи до Скулла, Скулл форева!!!!
а может вы Ачи не те деньги предлогали? (Лазиз ака привет))))
З.Ы.
Работают. Могу примерную сумму сказать если напишите сколько кг.
Не самый
+1. Верно!
РЕЙС каждый выходной. Сроки доставки с считая от дня рейса 7 дней. (авиа)
Если хочеш трекинг покажу?
Подметим верно все отправляется через EMS. (даже на сайте pochta.uz слелись поиск трекинга по EMS)
Мне в моей старушке кореяшке поменяли "ушки" помоему где заслонка расположена.
З.Ы.
Андрей, я тоже не спорил smile.gif Просто высказал свое имхо.
В EMS - часто вижу - приносят DHL и другие посылки )) чтоб доставить в регионы )) Ведь так дешевле )) Ну и перечесом платят.
З.Ы.
ну а какие еще ему деньги надо было предложить фунты стерлинги,йены rofl.gif
Нужно купить видеокамеру для домашнего пользования. Так как не сталкивался с этим вопросом, решил спросить здесь.
На что обращать внимание? На что не обращать внимание? Ну и какие цены на них?
ARIF
Цитата(SKULL @ Mar 18 2011, 23:34) *
Ну я уже незнаю что ты ему там предлогал, йены или еще какую нибудь Х...... rolleyes.gif
Вспомнил "Чучвара"
