Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
на переднем приводе другие подшипники. на классике нельзя тянуть. есть правила.
А так либо шплинт но больше край гайки загибается.
Вова если колесо вывесить да крутить ручками, то думаю по гулу и подклинивания можно почувствовать. потом решить он нет.
Да вроде разобрался, Файз был прав, там буртик гайки в двух местах должен быть вмятый. Непомню чтобы мастера на районе мне это гайку подбивали, кроме как закручивали.
Колесо болтается даже если его не вывесить smile.gif.
беги от таких рукожо пофф коих в сервисах полно. норм таз о ремонт ника подсказать? никогда не заряжает добросовестно крутит что нужно без лишних ака мака)
Гонщик, да кто бы мог подумать, мне то всего то надо было гайку закрутить, сам бы затянул если бы было чем. Контакты мастера давай в личку smile.gif.
p.s. Кто в курсе сегодня сергели автобазар работает?
Елы-палы...на ступичной гайке даже следы от фиксации есть с завода. Если подшипник не помер то делов (затяжка без фанатизма и фиксация тупым зубилом) там не много. Вы к каким мастерам обращаетесь? Что ишак арбу чинят? Обалдел, прочитав выше.....
увы... таких становится всё больше и больше. я в пятницу искал мастера кто смог бы с калины снять гену и поставить его - полдня.. штук 20 боксов - и никто не знает как это сделать. все кто были мастера - сваили кто в россию кто в корею.. эх.
В личку кинул тел мастера.
надо только помнить что гайка всегда новая. либо допускается с другого авто. загибать уже не чего будет.
Немного не согласен. На Волге не раз проделывал так:
1. Поднять на домкрат (вывестть колесо)
2. Обеими руками взявшись за колесо проверял горизонтальный и вертикальный люфт
3. Выкручиваю резьбовой колпак ступицы
4. Откручиваю гайку ступицы
5. Тряпкой удаляю старую смазку
6. Набиваю новую
7. Затягиваю гайку покручивая колесо рукой чтоб не перетянуть
8. Подбиваю фиксаторы в пазах (не обязательно новая гайка, если жива рабочая)
9. Закручиваю резьбовой колпак ступицы.
Знатоки поправят где что не так.
кому как. я обычно меняю подшипник. динамо ключом кручу.
Через какой пробег меняете? И сколько протяжек делаете между заменами?
не обслуживаю. не знаю. гудеть начинает меняю.
INTELigent
Цитата(LLIaMaH @ Aug 29 2014, 15:34) *
2 INTELigent
будет поворот малой кольцевой, чем-то похожий на Лакокраску, т.е. малая кольцевая поворачивает без перекрестка. Вот там на углу кинотеатр Нукус (бывший), до него слева по дороге Туринский политехнический университет. А так да после Малики (если считать что Малика это перекресток рабочего городка), следующий светофор трамвайные линии и сразу еще один перекресток со светофором, потом перекресток Алмазарский военкомат, затем Карасарай, потом Сагбан и потом поворот малой кольцевой, где на углу кинотеатр Нукус (бывший)
СПасибо, вот теперь сориентировался...))))
khurshid.hy
есть качки?)))
порекомендуйте протеин, какой взять?)))
130$ 5,4kg.
TATARIN
Плиз,дайте совет, какой фирмы лучше USB Хард?
Трансенд все еще хорош?
Tae
WD май паспорт.
Но далеко не бюджетные.
имхо
Пользуюсь Silicon Power, брал у форумчанина Про ск, не жалуюсь.
khurshid.hy
Цитата(FAYZ @ Aug 31 2014, 13:47) *
130$ 5,4kg.
это на сколько лет то хватит? biggrin.gif ппц вес))))
На пару месяцев
Tae
Насколько мне известно, не так уж и много это, на пару месяцев хватит, там же надо черпаками употреблять его.
screwjack2007
Цитата(khurshid.hy @ Aug 31 2014, 13:23) *
есть качки?)))
http://www.bodybuilding.com/store/opt/whey.html
самый лучший сывороточный протеин.
130$ 5,4kg.
это гейнер. для набора веса.
Уважаемый Dam , был бы я в курсе про эту гайку, я бы наверное сделал сам или проследил за мастерами, кто же знал что так всё запущено. smile.gif Сегодня с утра скинул этот колпачок, а там гайка не битая гайка, хотя в одном месте как бы чуток подогнуто, но совсем чуток. Видимо всё таки стучали, поехал в ближайший сервисис, по соседству с тем куда ездил, там затянули гайку и при мне сами зубилом с двух сторон простучали, теперь думаю точно не открутится, поездил, ниаких стуков, так что думаю все ок с подшипником. Всем спасибо.
drinks.gif чем смогу-помогу (хотя я очень далек от настоящего мастерства авторемонта))) подшипник смазкой был набит?
Я хочу купить двигатель от нивы шевроле если он еще не продан
Хочу сделать сыну подарок (часы Casio G-Shock). На форуме часами никто не занимается чтоб на подделку не нарваться?
а где двиг шевроле продавали?
Оташ почем кричали за него?
Stoneface
Добрый день! Уважаемые замутил такой бампер. Теперь не могу найти сетку на радиаторную решетку. У кого был опыт или знает где можно и что можно подобрать подскажите?
в хозяйственный магазин зайди
IRON
На Куйлюке, на строй базаре выбор большой.
Stoneface
Спасибо Мужики!
Видя фотку форумчанина ему именно гейнер был нужен как и мне.
Koshak
В цуме оригиналы. Но лучше закажи с ебэй. И выбор намного больше и дешевле выйдет. Все свои часы, в т ч и джи шоки , беру на ебэй.
Кто в змеях разбирается?
Вот эту у тещи дома (на участке) поймал кот, прокусил и т.д.
Теща в Ташкенте живет на Генерала Узакова... Хочется понять ядовитая или нет, во дворе всё таки дети гуляют и играют...
красава))) на торге есть тема, полистай. там и найдешь ответ...
IRON
По-моему это желтопузик, ловил такого на даче.
нет.
Не знаю какой там сейчас оригинал, когда я хотел там купить радо и спросил у них, будет ли мне предоставлен сертификат, на что они посмотрели так, как будто я у них часы в подарок просил, вобщем не слышали они о нем никогда, так что терзают меня мутные сомнения, что там действительно оригинал, в прочем как и на ибее в 80% случаев pardon.gif
Lancevo
Похож на узорчатого полоза.
Для того, чтобы покупать часы в цуме я не слишком богат...вопрос решен (куплены Casio AQ-S810W-2AV). Пацан доволен как слон)). Заказывать не было времени-подарок нужен был к 1му дню учебы в лицее.
Да точно, похож...
кобра очковая )))
хз но когда в аэропорту сергелях работал учили так если глаза круглые просто кусаецца ежели овальные лучше не трогай
змей там до жо пы
со скорпионами на полях с антенами за которыми следили. конеш там не было временв глаза заглядывать обычно с лопатой ходил от гонял))
Dronyk
змей там до жо пы
Да что в НАКе что на САРе змей полно.Про глаза змейные что то подобное вроде там слышал.
Tae
Доброе утро всем! Кто может подсказать какие условия нужны для того чтобы покататься верхом на лошадке?
Вроде бы Жоккей есть клуб недалеко от Куйлюк массива.
И почем стоит такое удовольствие разовое?
такой же гад прожил у меня дома полгода (кенты притаранили с предгорий). Кормил новорожденными мышами(брал в зоо). Маленько кусается если разозлить, но не очень больно, зубки мелкие и частые. Вердикт чела с зоопарка - полоз. Для содержания нужен нормальный аквариум с песком и корягой и крышкой, свет, плавание в ванной)). Питается раз в 2-3 недели. Самая большая засада была, когда эта падла чухнула и залезла в пружины дивана(( пришлось распарывать пол дивана и выковыривать этого друга (вот тогда кусался не слабо)
Отпустил по весне короче...
DenDiesel
Водяной полоз... Кусаецца, но не ядовит... Однако может какую - нибудь заразу занести...
Да уж понятно, спасибо за инфу. Будем знать. Теща конечно в полном трансе была и после того как кот своё дело сделал, добила его кирпичом sad.gif . Уверена была что ядовитая и что уйдет в огород и детей покусает.
Темур
Супчик надо было с него сварить
VoV
Кто подскажет что это за птица?
За качество фото извиняюсь.
Темур
Ястреб не?
