Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Почему в подавляющем большинстве задних диодных фарах поворотники обычные?
Потому что если светодиодов небыло в базе то неизвестно как поведет себя реле ,комп итд оставшись без лампочки ,тк СД кушают намного меньше . Для решения проблемы используют баластные резисторы иметирующие лампочку ... но рецепт для каждого конкретного случая разный поэтому проще сделать обычные поворотники . примерно так .
Почему может не отображаться картинка с кодом-антиботом,
хотя все баннеры и картинки показывает?
(не могу разместить объявление на торге)
У торга модер постоянно в аське, думаю лучше ему вопрос задать. Номер ICQ слева на странице торга.
Спасибо, написал, но видимо все-таки он не постоянно в аське.
и то верно)) ставил диоды себе, и в виду того что надо заморачиваться с релюхой, делать электронную, ну или сопротивления втыкать вместе с диодами, да считать что бы всё это соответствовало сопротивлению лампы.
замарачиваться не стал, оставил в повторителях лампы.
думается мне, что мигалька на пятерке такая же как и на зубле (реле само) купи реле за 5 тыщ новое, то, что мелкое. и будет мигать даже если вообще ничего кроме светиков нету.
насчет обычных ламп накаливания в поворотниках -- светодиоды сильно блекнут при солнечном освещении - это вероятно, и есть причина того, что их не втыкают в поворотники. надо слишком много и определенного спектра, чтоб на солнце не слепли.
на VW пассат в стоке поворотники СД и ничего не слепнет, на счет спектра ... ну он вроде как 1н определенный для всех ,стоп красный поворотник желтый .
Думаю тут дело в унификации современных авто ... блоки управления и вся электроника максимально унифицированы между моделями для снижения себестоимости и производятся по откатаным схемам , ради стиля и разнообразия могут воткнуть СД в габариты и стопы тк переделка минимальна ,но никто не станет городить огород ради СД поворотников и так обойдутся ) пример электропакет в переди и ручки ссзади ... конечно это справедливо для более менее бюджетных авто .
Не согласен. Новые диодные светофоры отлично видно на солнце. А в старые на лампах приходится вглядываться, чтобы понять какой свет горит.
Вот прекрасный пример, машина дорогая, в разработку вложено много средств, стопы на СД, а поворотники обычные...
Светодиоды направленные а лампочки видны в любом ракурсе.
+1 стиль стилем а повротники это в первую очередь безопасность и чем "проще" тем лучше и надёжнее!
Анвар ты не заморачивайся с диодами. хочеш мастера дам победишь быстро сделает и нет проблем.
да нет с оворотниками у меня нет проблем слава богу) да и диоды я особо не люблю) просто +1 к тому что в поворотниках должны быть лампочки))
P.s. нужен совет, где можно сделать "Уколы в коленные суставы" для востановдения жидкости как эт называеться ***хонжроз вобщем нужен хороший специалист
Ну ладно, следующий вопрос, почему когда включаешь горячую воду идет шум в смесителе? При холодной воде такого нет. И еще, может кто-нибудь заодно подскажет как от этого шума избавиться.
Горячая вода с детсва "шумит" rofl.gif rofl.gif rofl.gif дле меня это загадка тоже
Шерзод
9 из 10 что в системе горячего водоснабжения не той стороной установлен совковский вентиль (в смысле вход и выход перепутали).
Ты веть мудрил с освещением салона!
Когда вода в чайнике кипит то некоторая чать переходит в пар! Здесь тоже самое. Твоя система горячей воды сильно горячая.
Ясно, я еще заметил, что при наступлении отопительного сезона шум стал заметнее, температурку подняли видать.
Следующий вопрос, и последний, где шредер купить и какие примерные у нас цены?
А ты про это)) а я с перва и не понел))) а то в трёх разных темах про это ме советуют))
Я думаю просто взять плафончики из багажника (2 шт) и врезать в "бороду" там провести наверх провода и будет гореть))) только нужно чтобы электрик всё соединил а то как замкнёт
Смотря какой уровень секретности нужен. Сам покупал в Туроне (atcturon.uz), 6 уровень. Обошелся около штуки.
Если высокий уровень секретности не нужен, могу продать по сходной цене свой третьего уровня (пользуюсь шестым), все равно стоит без дела. Такой в Туроне стоит около 150 баксов.
6 уровень - уничтожает бумагу практически в труху, то есть режет лист по диагонали на полоски шириной 1 мм и длиной 5 мм.
3 уровень - режет лист вдоль, на полоски шириной 2 мм.
По почте скину номер электрика проверь юселовскую почту.
Статистическое электричество!
Вот что меня достало. Пришло тепло одевается (шерть и итд.). Бёт токол мама не горюй! Может есть такие новые штучки которых можно носит в кормане итд. чтобы они предотвращали.
Купи в магазине антистатик и побрызгай всю одежду после стирки, и сиденья в машине.
Есть в Континенте, называется Лира. Ну или при стирке добавляй кондиционер для белья, он действует как антистатик.
Ничё нету(
впрочем если даже по вашему, будет не шум, а характерный стук.
не нужно никаких штучек. ведь бьет именно при выходе из авто? тогда надо просто научиться правильно выходить...
Не только в машине но и дома, в оффисе итд.
Из машины выхожу строго по правилу.
-Дверь открываю
-Рукой открываю дверь (метал)
-Ногу в асфальт!
Цитата(Davids @ Nov 10 2010, 16:57) *
да, я тоже долго ржал когда мне такое заявили. чес слово. но попробовав нижеописанный простейших действий при выходе из авто, был весьма удивлен. даже несмотря на всю абсурдность)))
заметьте, когда мы выходим- обычно первым делом опускаем ногу на землю. в этот момент рука еще держиться за внутреннюю ручку двери. следующий шаг- это мы встаем и выходим. тут мы отпускаем внутр ручку и беремся за внешнюю или за "рамку" двери. именно в этот момент происходит статический разряд.
так вот чтобы не возникало неприятных ощущений нужно создать условия, чтобы разряд проходил не через руку, а через...ногу))обувь. такой путь разряда неощущаем.
делается это просто- когда дверь уже открыта, надо взяться рукой за рамку, и только потом опустить ногу на землю. pardon.gif
ps. пока писал, Файз опередил с рецептом)))
Еще бьет током когда к другому человеку прикасаешься. Надо учиться правильно прикасаться? wink.gif
Вреда в антистатике никакого нет. Только если обработаешь сиденья в авто, закрой его на полчаса, пока аэрозоль не осядет.
saidjon
Сколько хотите? И какое состояние?
про человеков)- однозачно надо "правильно" прикасаться
Работал пару месяцев время от времени. Хочу баксов 50
Супер секретность не нужна, просто запарился рвать руками ))
Забираю, пришли номер в личку.
T3571: Я так постоянно выхожу, но вчера так шыбануло аш уже достало.
Сегодня в оффисе 4 раза шибанула. Причем так шо 220 фигня.
Что за антистатик аэрозоль?
Цитата(Davids @ Nov 10 2010, 17:45) *
Стул китайский (и поппу не брил =))))
так чо думать попу побрей епта
Lawyer
-Дверь открываю
-Ногу в асфальт!
Спамеры как я =) Давайте ближе к вопросу! Неужели 21век на дворе а разных штучек нету!!
saidjon
Успеваю у Вас его забрать или уже отдали другим?
Шерзод
ну если характерный стук не считается шумом, то я молчу.
подскажите пожалуйста путь, куда сохраняется архив м-агента. именно архив сообщений, а не принятых файлов...
Вроде как в почтовом ящике есть пунктик архив маил агента . а так локально не сохраняет .
сохраняет. но в файле *.dbs и хз чем его открыть.. ни Аксессом, ни Манеджмент студио СКЛ
Цитата(Lexville @ Nov 4 2010, 20:52) *
а чем смазывать то тросик (я так думаю в саму дроссельную лезть не нужно?)? Раньше на мотоциклах я смазывал отработкой, тут так же или чем другим лучше?
графитовой смазкой
По умолчанию тут: C:\Documents and Settings\USERNAME\Application Data\Mra\Base\ (Username поменять на пользователя)
В формате .dbs чем открывать, не знаю, возможно аксессом.
Так где найти аэрозоли антистатик?
