Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Valerka
Цитата(shumbola @ Dec 20 2012, 17:02) *
Со скольки работает посольство Южной Кореи и до скольки принимают документы?
Имеет ли смысль подойти по-раньше, ну там очереди т.д. могут быть?
Иногда прохожу мимо в 8-00 утра. Больших очередей не видел (человек может до 10). Вроде ежедневно стояли...
Цитата(gluckboy @ Dec 20 2012, 22:27) *
кто делал насколько длинный езернет и были ли проблемы? узонлайн оптика кинул витуху ютипи5е, длина кабеля 101 метр, по дому по карнизу. зараза, потери пакетов 15%!!! пинг хотя единица.
на Cat5е смело кидаю 110-120 метров, кабель АМР или хороший китаец. есть в наличии
Цитата(puzo @ Dec 20 2012, 23:00) *
Если линия эзернет более 50 метров в помещении и более 25 метров вне помещения, насколько я знаю, надо применять кабели 6 категории, с жестким сердечником, и с более толстой изоляцией.
немного ошибаешься
Цитата(gluckboy @ Dec 20 2012, 23:28) *
экранированный по ходу хуже неэкранированного. особенно если не заземленный. заземленный по характеристикам близится к неэкранированному ) кабель наш местный кспп кажется ) с черной изоляцией. вроде медный. видел залипушный кабель - но этот чисто визуально на залипуху не похож. кстати, если на 10 мегабит переводить - то потери тоже исчезают. думаю вот мот кабель в свич а свич в комп? smile.gif в смысле комповая сетевуха возможно не тянет? в принципе, 100 м это в пределах стандарта.
экранированный тебе не к чему. наш кабель не медный, там только оболочка медная и сечение у него не 0,52.
Обращайся в личку помогу с кабелем и 5 категорией и 6-ой кабель проверенный уже не первый год кидаем только его.
прокидывал 150м принудительно ставил 10мбит потери практически 0 кабель весь был на крыше
ps качество кабеля было хорошее (сечение и качество плетения)
man_in_white
Правильно сделали, скорее всего не качественно обжали :-)
Нет, 6 категория не пойдет. Точнее говоря результат может быть и обратным. 5e вполне достаточно, если хороший кабель.
Цитата(Lexville @ Dec 20 2012, 20:42) *
да ладно. Вот облом, надо производителям сказать.
Надо ВСЮ сеть (разъемы и свичи) делать экранированную, тогда есть эффект.
А если брать ТОЛЬКО экранированный кабель, то экран работает как антенна и ухудшает работу кабеля, особенно на больших расстояниях.
скорее всего кабель не качественный.
наш кабель вообще не использую его только под телефонию кидать можно.
Расскажите пожалуйста почему 6 категория не пойдёт и почему результат может быть обратным очень интересно.
Не вижу смысла дома делать ему экранированную сеть, там шумов и наводок у него нету.
вот к примеру тест на кабель 5е длина 91,6м
man_in_white
6 категория используется для линков на 10Гб/с (полоса пропускания 250 МHz). В связи с этим, кабель имеет имеет более сложную структуру (более частые витки) и он более чувствителен к изгибам. По этому его делают искуственно более жестким (пластик внутри).
При некачественной установке на большие расстояния 6 категория МОЖЕТ (но не обязательно) выдавать худшие характристики по сравнению с 5e категорией, которая спокойно работает на 1Гб/с, чего вполне достаточно для домашнего использования.
Да и стоимость 6 категории выше 5e + не надо покупать коннекторы для 6 категории.
про 6 категорию тоже интересно
behruz
простенький вопрос: я поменял аву, а она осталась прежней, захожу в настройки там висит новая, отправляю сообщения на форуме - отображается старая... это заговор?
Wuv
behruz
Цитата(Wuv @ Dec 21 2012, 12:16) *
аааааа спасибо! получилось! ))
согласен, что шаг скрутки другой, синхронизатор внутри кабеля для того чтобы не нарушилось витение пар.
там и сечение 0,54
это всё теория, но практика есть практика не всегда всё так как в книжке написано.
всё прекрасно работает и показывает отличные характеристики.
стоимость выше согласен, а по поводу коннекторов...вы не поверите, но и в коннекторе 5 категории кабель 6 кат. чувствует себя прекрасно, опять же практика, могу вас окончательно убить))))) однажды сделали даже скрутку было это в бизнес центре Пойтахт, и тест прошёл, если интересно то могу поковыряться и найти его))))
блин, уже кинули. поздно.. жаль раньше не знал. знал бы купил бы у тебя к тому же нигде найти не мог. кстати, жилы всё же медные. как покрытые медью выглядят я знаю ) - если жилу перекусываешь то внутри белый металл а тут желтый.
зы
проверил на циске. один конец от прова воткнул в свичмодуль, второй конец воткнул туда же от компа. первый порт 10-ка второй 100-ка -- потерь нету. меняем местами (с провом линк на 100 мб завязывается) -- опять потери. мот обжали всё-таки неправильно?
Цитата(V@ldemario @ Dec 19 2012, 17:12) *
smile.gif))) ОТАШ ну не на 3-й же подыматься или не на 4-й?))) Или ты с разгона хочешь))???? Поднимаешься также как и в городе 1,2-ая... )))
Цитата(Valerka @ Dec 19 2012, 17:36) *
Сегодня супруга ездила до Солнца. Основная трасса нормальная (на зимней), но по махаллям или съезды с дорог - только цепи. + еще смотря по какой дороге в красногорск ехать. Если с ахангаранской дороги - то проще, если через Паркент-Чанги - думаю на цепях.
Цитата(Шерзод @ Dec 19 2012, 19:19) *
с ахангаранской дороги ехать не советую, разбита напрочь. самый оптимальный вариант барданкуль-дустлик-джумабазар-джамбул-кизил ембек-красногорск. езжу по нему как минимум раз в неделю на ниве с прицепом весом 1000 кг. в прошлое воскресенье ехал во время снегопада, проблем не было. по дороге подъемы не крутые и не длинные, асфальт почти идеальный. для грамотного и опытного водителя маршрут не сложный.
Цитата(TOUAREG @ Dec 19 2012, 19:26) *
честно скажу...такими своими вопросами ты меня в тупик поставил. стебаться не хочется, а как ответить...не знаю. передачу выбираю интуитивно, не очкую когда лезу на гору. здравый смысл- прежде всего. не зная броду- не суйся в воду. как то так...
Спасибо за отклик очканулса так и не поехал) Славу Богу все растаило тепер можно сгонять.
Форумчани если вдруг, не дай бог конечно, сгорит бензонасос от нексии, не зачто не став-те китайский, я поставил китайский самый дорогой(самый хорошый) тепер желею вся проводка сгарела(
man_in_white
Это я тоже видел, даже несколько скруток на одном кабеле. Все работало, но нестабильно.
Я придерживаюсь мнения, лучше взять хороший кабель 5e, чем средний 6.
sik
Цитата(DenDiesel @ Dec 17 2012, 19:35) *
Подделки в магазинах встречаются частенько...
Явные подделки (медь вместо золота) Вам не пихнут.
Пихнут и глазом не моргнут! Один очень известный Магазин на Алайском (не буду писать название) жена купила мне в подарок трос, серебро, через два месяца "серебро" почернело, пошли разбираться в магазине сказали следующее:
- Да это не серебро это мельхиор!
- А почему продали как серебро да еще и с пробником?
- Как нам дали так и продали! Нам оставили на реализацию сказали что это серебро, вы не первые уже обращаетесь!
- Верните деньги!
- Чек есть?
- Нету, но вы же помните что мы у вас его брали? Тем более такая цепочка только в вашем магазине была!
- Помним, но без чека денег не вернем!
- Но вы же подделку продали получается?
- А мне по....й идите пишите заявление в милицию я х... поклала! (хозяйка магазина)
Весь диалог изложен без изменений! Так что лучше покупать в проверенных магазинах!
мнэээ могу ошибиться но по-моему серебро как раз и темнеет ) точно не темнеет - платина. )
sik
Есть разница как темнеет серебро и как мельхиор, и с серебра чернота уходит при кипячении на фольге в содовом растворе в течении минуты, а на мельхиор это действует обратным образом. Да и у мельхиора кроме потемнения еще и буро-красные пятна выходят. В общем как в последствии оказалось цепочка была мельхиоровая с серебрянным напылением.
ПыСы: к стати золото тоже темнеет! Но не так как медь!
- Верните деньги!
- Чек есть?
печально, но факт. Друг-ювелир мне показывал несколько подделок, которые продавались как заводское ювелирное изделие у нас (и даже одно из России). На глаз порой нереально отличить. Однако и хозяйка магазина частично (правда не по манере общения) права - без чека Вы не можете доказать ни продавцу, ни кому-либо еще факт покупки данной подделки именно в этом магазине (а так я бы принес 10 одинаковых подделок и сказал продавщице в первом попавшемся ювелирном магазине - верни деньги). Да и при наличие чека тоже не всё так просто...
sik
Ну поэтому подумали, а стоит ли себе портить нервы из-за такого пустяка? Продавщица сама призналась, да я вам пихнула, но ниче возвращать не буду! Бог ей судья!
Да к стати меньший риск купить подделку покупая узбекские изделия, там во первых обязательно должно стоять две пробы и две бирки, одна завода, вторая пробной палаты, да и во вторых как сказал мне один знакомый ювелир, тут у нас никто из-за одного колечка за решетку не горит желанием попасть.
Положите в закрытом пространстве, типа тумбочки рядом с золотом ватку смоченную йодом (не ташкентским, а настоящим) и через недельку посмотрите результат. Я свое кольцо еле оттер потом от черноты.
AndreVla
sik
rolleyes.gif Нееее спасибо! К стати драгоценные металлы быстро реагируют если у человека проблемы с сердцем или почками.
shumbola
Цитата(KoSTaS @ Dec 21 2012, 16:41) *
Лучше беспроводная ;-)
хуже.
Dan_19
кто может поделиться номерами "САШКОВ", которые могут качественно прошить ксю, завтра устанавливаю неполнобазные валы и какие нынче расценки?
А к мастерам как Ройс или Скулл не хочется?
Ты бы лучше сказал какого *** я до тебя дозвониться не могу
Цитата(AndreVla @ Dec 21 2012, 18:07) *
Не Андрюх, вот то кольцо как раз было советское "тоза". В то время за подделку золота не сажали. Стреляли, дэ. И бирочки на изделиях не как сейчас просто на бантик завязаны, а опломбированы. И по расположению точек на звездочке клейма пробирной инспекции можно было спокойно определить на каком ювелирном заводе изготовлено изделие.
BUMBOX
Я что то не пойму как он будет синхронизироваться с моим компом?
http://news.olam.uz/it/13665.html
очень нужный сервис при наших околодиалапных скоростях. у нас провы то ссутся свои внутренние ресурсы расшарить на адекватной скорости, а тут целый дропбокс. насмешили.
man_in_white
Цитата(KoSTaS @ Dec 21 2012, 13:41) *
А мне кажется не очень.
Стоит ли устанавливать СКС категории 6, категории 6А, категории 7 и 7А?
еще мысля. я вот думаю сто метров на улице при грозе могут же и проблем понаделать. напрямую втыкать в жезезяку за 1.5 как то стрёмно. но в упсах есть две дырки для типа "защиты сети". вот думаю есть от них толк если упс заземлен? и не мешают ли такие фильтра в принципе?
Кто может обновить прошивку на Huawei U8800 (Idios x5)(оператор Ucell). Также записать игры итд.
Ну ка, соорентируйте почем можно толкнуть 1л. Chivas brothers scotch whisky 21 )
Звони мне
umid1979
Хотим купить такую шнягу АГРОМЕТРдля измерения площади полей в Зангиотинском районе ТАшобласти. Подскажите можно ли залить карты Узбекистана в нее и какова будет погрешность. Хотим использовать оффлайн.
В частности, насчет APC:
Толк есть. При грозе, выгорает УПС, оплавляется кабель, разъемы стекают на пол. Но, подключенные сиськe - живые, без малейшего следа разряда.
PS. Ваааще не мешают. sad.gif Защищают еще и от случайной фазы на проводе.
Пользовательское соглашение:
Вы соглашаетесь не наносить вреда репутации UzDisk любыми действиями или бездействием.
Нафик-нафик. Еще с оружием в руках заставят защищать интересы UzDisk.
Вы соглашаетесь освободить от ответственности, оградить от убытков, связанных с любыми претензиями третьих лиц, включая разумно необходимую оплату юридических услуг, связанных или вызванных загрузкой контента или его доступностью на ресурсе UzDisk, и нарушением каких-либо прав третьих лиц, касающихся контента.
Точно! Все на баррикады. Защищать уздиск!
UzDisk сохраняет за собой право в любое время на свое усмотрение изменять или удалять любую опубликованную информацию или контент, замораживать, прекращать или ограничивать ваш доступ к услугам из-за нарушения этого Пользовательского соглашения; повторного нарушения авторских прав; ущерба, нанесенного сервису UzDisk или по другим причинам, без возмещения любых платежей, с уведомлением или без несения ответственности за ущерб, понесенный вами вследствие таких действий.
За это, отдельное спасибо! Офигенски надежный сервис! Вилами на воде, сохранять информацию надежнее будет. wink.gif
qwerpo
Редкая штука, стоит не менее 130у.е.
На российских сайтах около 200 продают ) мне за 150 продать)
А что? Я не пью! дома пьют чачу или вино (Alexan_der как вино акрыляет?) так что нафик нафик, за то пол базара на эти деньги можно сделать )))
Цитата(SKULL @ Dec 23 2012, 13:16) *
с Амазона нужно покупку сделать. может ктонибудь подсобить?
вроде атлантик?
Артур
Подскажите где можно купить планшетник перечислением? На малике только 1 магазин нашел. Выбора никакого.
Marat
Уточните у производителя
-Карты в каком формате понимает данное устройство и смотрите что есть http://www.extremal.uz/osm/
-Точность тоже лучше уточнить у производителя, бытовые приборв дают +-5 метров
Scarlett
Есть пара-тройка человек, через которых я заказываю. Условия у все разные. Ожидание 3 недели.
Enigma
Вроде Билайн продает планшеты Самсунг.
