Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
Tae
я так понимаю, значит можно использовать авиационный керосин? он ж вроде хороший по идеи. Бензином вроде тож можно, если не ошибаюсь?
просто уайт спирит не нашел, по крайней мере возле дома в хозтоварах.
кстати, никто не в курсе, если линзы от объектива(оптические) промывать в спирте, то ничего не будет плохого? на некоторых просто есть просветительный слой.
БУДЕТ! и не вздумайте даже!! со стклом ниче не будет а вот именно слой может поехать от этого...
Используйте только мыло с теплой водой для снятия налета жирного, после вытирайть надо тряпочкой особой которая ворса не оставляет (помоему фланелевой или той, что в магазинах оптики продаются для очков).
Я себе для снятия жира от пальцев с объектива (всякое бывает) приобрел когда то спец карандаш там с одной стороны кисточка для снятия выли, а с другой какая то ворсистая поверхность, но объектив после нее остается идально чистым, как с завода (если надо могу дать попользоватся с возвратом).
slako
если не ошибаюсь, объективы обычно моют изопропиловым спиртом, я когда зеркалку брал на B&H, то взял еще "карандаш" (как выше написано, это lens pen) и набор очистки, в составе которого есть пузырек с изопропиловым спиртом.
Tae
да, LensPen я заказал, он едет, в принципе не к спеху, так что могу подождать свой, но за предложение спасибо)
кстати, нашел способо, экстримальный, но дельный, атомарный углерод: свечка + столовая ложка + ватная палочка(либо ватные диски), вот и дешевый вариант ленспэн.
а где изопропиловый спирт то можно достать? я так понимаю вроде его в аптеках не продают.
Enigma
Цитата(FAYZ @ Nov 21 2013, 21:44) *
Решил разделить комплект спутника.
Предложите сами. Также в комплекте есть usb modem.
Без понятия. USB модем не нужен. Я ищу вариант обмена на свой ADSL WiFI Роутер TPLINK 8910G.
Почему при ДТП любой сложности, будь то , просто покоцан бампер, всегда закрывают номер тряпкой? Или скручивают.
Enigma
Цитата(Enigma @ Nov 22 2013, 09:54) *
DenDiesel
Это уже заложено в сознании, также как и оставлять целофан на рычаге включения поворотника и сёдлах )))
п.с.: раньше все пульты от видеомагнитофонов в пакетики заворачивали)))
TATARIN
а я раньше думал -чтоб не было антирекламой ,мол увидят соседи,знакомые .
И когда будет продовать "Краска родная ,не битая ",-скажут нифега я тебя видел на ДТП ))))
просто у меня бурная фантазия ))
а где можно приобрести этот lens pen?
_HaMMeR_
Такой вопрос возник, с какого перепугу нотариусы при оформлении сделки по недвижимости стали требовать ИНН ? Это что после продажи еще надо идти в налоговую и оплатить налоги согласно цене указаной в договоре купли-продажи?
Enigma
Налогов с этого вроде нет, но ЕМНИП если несколько раз за какой то период будешь покупать продавать, могут спросить как за риелтора.
slako
я в кошерном обычно фотопричиндалы брал.
Правда там доставка недешевая, имеет смысл заморачиваться только если попутно брать что-то дорогое.
я брал в москве в эльдорадо.. думаю можно попросить кого нить,там дефицита с этим нет...
LADA-FAVORIT
Думаю, это "традиция" заложенна с советских времен. Так делали водители гос машин определенных служб. А наш народ хлебом не корми, дай выпендрится и приписать себя к таким службам. Вот и прикрывают номера. Как говорят, понты дороже денег.
тоесть сделка по купле продаже недвижимости не входит в категорию доп. доходов?
Helga
Вопрос к знающим. Слышала что в ручной клади при перелете разрешается провозить две бутылки (допустим вина) правда ли это? Или отнимут?
если бутылки не куплены и упакованы в дьюти фри, то отберут. вообще, жидкости больше 100 мл провозятся в багаже.
Enigma
Если продаешь свое имущество - то это отдельным налогом не облагается. Но вот если слишком часто покупаешь продаешь - то значит ты бизнесом занимаешься.
Helga
Понятно. Спасибо
Цитата(Helga @ Nov 22 2013, 13:41) *
Понятно. Спасибо
Кидайте в багаж , предварительно заверните , а то грузчикам пофиг)
Тупанул когда ехал с москвы два пузыря и коньяк изьяли, правда успел немного отпить от жадности коньячку laugh.gif
Сборник
человек развлекался
http://borya-spec.livejournal.com/125532.html
Tae
Цитата(Сборник @ Nov 22 2013, 18:09) *
человек развлекался
да, читал уже, эх, мне бы было жалко(((
SeregaS
Если точнее продажа более 2х квартир в течении года.
Tae
никто не знает хорошего врача невролога?
а то уже сколько посетил, что то как то не нравятся(
Ребята вопрос. Машина тяжко заводиться по утрам. Троит. На холодную тянет хорошо. На горячую тяга проподает. В чем может быть причина?
mplayer
Здр. У кого есть знакомые, кто в ближайшие два дня прилетает из Москвы? Нужно одно лекарство привезти. В Москве подвезут туда, куда нужно. За доставку заплачу. Спасибо.
ребята need help... если кто продает достойную машину (Матиз, Спарк) по адекватной цене дайте знать плиз...
Ищу машину для себя для семьи. торг уже заипался смотреть, цены одуреть !
Сагатов в первой городской кафедра неврологии.
Глобал мед систем напротив боткина. Зуфар Ибрагимович. дир клиники. для взрослых людей. не детские.
У меня не очень хорошо заводилась по утрам, работала сначала нестабильно, как бы с прострелами. Как прогревалась, становилось все нормально. Поменял свечи и форсунки. Стало все отлично.
Надо попробовать. Но у меня при горячем вообще все подыхает.
Джон
Было тоже самое прошлой зимой. Почистил инжектора.заменил свечи и вуаля всю зиму не дитонации и завод с пол пинка.
Через OBD2 - проверь работоспособность всех датчиков o2.
addanif
объясните мне пожалуйста, в нексию назад какие динамики ставить, вплане размер 6 х 9 дюймов или 6 х 8 ? хочу заказать с США, вот вопрос и возник.
блины вооще не ставь тем более назад
addanif
почему? мне не нужна навороченная музыка в нексию, просто одна колонка пердит, хочу сменить пару
такой вопрос присмотрел себе на малике телек самсунг 81 см цена 320 уе к сожалению модель не запомнил
хочу использовать его вместо компьютерного монитора! какое разрешение у меня будет на этом телеке? подключение HDMI видеокарта 8800 GT
REDLINE - зря не запомнил модель, дело в том что 32" телики идут с HD разрешением (1080x720) кажется и FULLHD (1920x1080). Зайди на сайт самсунга поищи, может вспомнишь. к компу то он подойдет по любому в качестве монитора, но все же в FULLHD играть приятнее.
как вариант, поставить хорошие круглые 16 см. динамики в родные корпуса. Вид сток, а играют лучше.
друг тоже использует телек самсунг но у него разрешение 1366! т.е мне нужно будет поехать и уточнить есть ли фул хд у того телика?
если есть то супер
если есть то супер
или 1366 я точно просто не помню размер обычно HD формата.. конечно лучше уточни что за телик ты увидал.
Lancevo
если есть то супер
За такую цену только 1366x768. Уверен, что не FullHD.
addanif
я это все понял, спасибо, но меня конкретно интересует скольки дюймовые в нексию садятся?
такие зайдут в нексию на обычный пионер без усилка?
http://www.amazon.com/PLG57-3-5-Inch-7-Inc...s=pyle+speakers
Друг, вот стандартное место:
Вот таки подиумы продают. С ними ничего резать не нужно.
а FullHD не в курсе сколько стоит?
Ребята вопрос. Машина тяжко заводиться по утрам. Троит. На холодную тянет хорошо. На горячую тяга пропадает. В чем может быть причина?
Сделал не помогло
Проверил. Норма.
Сегодня снял шланг после воздушного фильтра и рукой перекрыл кислород подачу двигу. И на удивление он стал работать очень даже стабильно. ровно. ОЧЕНЬ РОВНО. Значит где то сосет воздух. Как найти это место???
Я покупал LG 27" IPS c FULL HD разрешением...
Зерна на экране, глаза режут.
К домашнему телику как то подключал комп... качество полное Г.
Нафига тебе комп с таким экраном?
+1
Тоже так делал.
На заправках, чуваки были в аккуе от звука из "стоковых" деу колонок )))
Колонки были подрублены к усилку и стоял саб )
Тогда снимай дроссельную заслонку и почисти ее - карб клинером.
Так же почисти датчик хх, сухой тряпочкой.
ну и на всякий, проверь все вакуумные шланги.
Азиз за сколько покупал этот телек ?
телек дешевле стоит монитора вот и думаю
