Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632
B@hus
Цитата(Pashuta @ Aug 3 2012, 01:56) *
Ну или углекислотой его потравить? Короче, где бензобак можно заварить?
Наверное в любом сервисе где сварщик есть. Единственно, что времени много занимает. Когда мне на иж комби варили (на ТТЗ-2 сейчас этот сервис снесли), процедура была следующая:
- сняли бак;
- слили бензин;
- вставил шланг с водой (промывали минут 30);
- заварили бак;
- к бензонасосу присоединили баклажку с бензином;
- горловину бака насадили на глушак, завели двигатель и выпаривали бензин на холостом ходу пока 1,5 литров бензина не закончилось (время не помню, но ждать устал).
Цитата(TOUAREG @ Aug 2 2012, 23:19) *
мля...почему тема Фиолетовых закрыта? где вопросы задавать??
Файз, чтото я не пойму...при каком балансе отключается связь?
Отключается при нуле, а вот включается... Это смотря какая система, если постппейд то включается когда на счету + 2 у.е. если препейд то хоть 20 центов...
Цитата(gluckboy @ Aug 2 2012, 23:20) *
просто кто то говорил что на распарке вообще не цепляется. а тут 4 метра вроде не плохо. но на 5 уже не завязывается. а на паре рядом завязывалось на 12 но не стабильно. 6 - железно. но тут стойка хухель, а там стойка (где 4 и вероятно распарка) алкатель. или стойки разницы не имеют? на зукселе до стойки пинг 40 до алкателя 2-5мс.
цепляется на распарке , зависит от ее длины ясен фиг если распарка на магистрали будет то там не поднимется ничего а на распределении работают
Валер, я заметил в последнее время, что связь начинает "отключаться" (пропадает инет, смс могут не отправляться и т.д.) уже при 5-15 центах. Не знаю так ли это, но думаю связано с наличием абон.платы.
Pashuta
Reza, Touareg, к дну бака нужно трубу из нержи приварить. Паять и подобное - не то, мех. прочность не та.
Просто так варить тоже не вариант, были случаи баки разрывало. Москвичевский бак вариться, видел на фото, но для этого нужно его предварительно подготовить - "потравить" (не придумал как иначе обозвать сей процесс) пары бенза.
у меня проблема возникла при балансе чуть менее бакса. ну да ладно, вопрос решен уже) Файзу спасибо- разжевал, подсобил drinks.gif
к стальному баку приварить нерж?? ну ну...удачи)
можно только припаять, твердым припоем(латунь). или, механически закрепить(заклепки).
впервые слышу про "протравливание паров бензина". имхо, бред какойто))) всю мою сознательную жизнь сей процесс(ремонт) проводился при заполнении бака водой и последующей тщательной сушкой(либо сжатым воздухом, либо отработавшими газами).
Pashuta
- сняли бак;
- слили бензин;
- заварили бак;
О, ценная инфа! Благодарю за ответ)
В любом сервисе у мну не получается, они как Москвич увидят - сразу шарахаются, а тут еще и долго, и чем дольше, тем лучше)
Единственное не понял, почему пункт "заварили бак" идет перед пунктом, когда горловину бака на глушат сажали? Этот пункт (заварки) вроде должен быть последним.
На всякий, может известно куда те мастера переехали?
Pashuta
Аргонной не вариант?
Достойная ли при твердом припое будет обеспечена прочность и как герметизировать механически закрепленную деталь?
Про травлю, повторюсь, мож не правильно объяснил, но что именно от паров избавиться надо - это точно.
Заполнить бак водой - не проблема, спрашивал где его от паров избавить.
думаю, что не вариант.
вполне достойная. конкретных цифр не помню...погуглить можно)...но как пример несущей прочности: большинство рам советских велосипедов были собраны именно на твердый припой(ХВЗ и прочие...). знаю, что сейчас полетят помидоры в мой огород и текст типа "те рамы...", поэтому опережая события скажу сразу- да, те рамы ломались. но, в ОКОЛОшовной зоне. и обусловлены эти поломки несколько иными факторами, нежели чем применение твердого припоя.
впрочем, мы отошли от сути вопроса))
прокладки и\или герметики. другого способа не вижу...
"избавить от паров" для сварки? правильно понял? тогда еще раз...промываем водой...затем заполняем водой полностью, оставляя небольшую полость в районе сварки\пайки...затем начинаем процесс нагрева. скорее всего будет небольшой " хлопок", из оставшегося объема воздуха...поэтому он должен быть минимален по объему\размерам.
все, собственно...
гораздо сложнее будет нормально просушить бак после всех танцев с бубном. тут в помощь, как я уже сказал выше, сжатый воздух или отраб.газы. я бы предпочел воздух...
B@hus
Да Вы правы, сушили два раза, первый раз после промывки, перед сваркой, затем снова залили воду в бак проверяли на протечку и второй раз после всего выпаривали остатки воды с бака до суха.
Куда переехали не знаю,было это более 7-ти лет назад.
Вам в принципе только сварщик нужен, точнее его работа и наличие водопровода по близости, остальное можно сделать самому, не напрягая сервисмена и не оплачивая его трудочасы.
Если есть возможность можно уже подготовленный (промытый и просушенный бак) привести на другом авто к сварщику.
Koshak
Цитата(REDLINE @ Aug 3 2012, 01:04) *
спасибо за ответ! а что нибудь по конкретней? ну типо прайсы и так далее
Дешевле 5-6 штук более-менее приличное не купить.
Кому там Би полярные кондеры 2,2 100в? на чипонате есть
У меня с мобильного на Билайне ,не заходит в интернет уже при 40-60 центах.
DenDiesel
Мне на Баварце 735 -м варили бак. Правда было это несколько лет назад smile.gif Если ехать со стороны академии милиции в сторону ТАПОиЧ по бетонке надо свернуть на второстепенную дорогу, которая к колхозному ГАИ выходит... Где то в метрах 100 после ГАИ будет располагаться сервис... Там рядом какая-то автобаза есть... Прокладки раньше под иномарочные ГБЦ изготавливали на заказ...
Подскажите сервис, где ремонтируют монохромные (вроде так называются) дисплеи. Читалку нужно починить.
Куда перенесли ГАИ с Собир Рахимова? Права надо забрать, а там, оказывается, только номера и тех.осмотр остался..
Район Яккасарай.
screwjack2007
Район Яккасарай.
На Узбекфильме, где 3 дивизион. Очереди никакой, красота!
Спасибо большое, а где именно?
screwjack2007
Если ехать на хамзу по мукимий, на светофоре недоезжая хамзы повернете направо,едете до конца, на изгибе дороги будет вулканизация, перед ней повернете в махаллю, через 50 метров справа будут ворота,это и есть то что вам надо.
А что случилось с ним, Шукур?
если экран разбился то транда - заказывай из хитоя. или новый покупай. этот вроде 89 баксов стоит.
drinks.gif Вах спасибо!! Мне ))) а я уже обычных накупил по 100 сум. полярных ))) по 10 мкв 25V. Хотел минусами спаять 2 шт и попробовать так заменить
А теперь можно подробнее где там именно на Чопоноте...
Может все таки на Мукими, где перекресток (клуб Фламинго и т.д.)
Вы до этого давали телефон ведь этого магазина???...
man_in_white
Владельцы телефонов Uzmobile, отзовитесь.
Кто может помочь в небольшом roadtest?
Нужно проверить будет ли телефон работать в одном месте.
Буквально пару часов туда сюда смотаться.
вот адрес чипонаты - Чиланзар 14ый квартал, дом 10. Телефон: 275-04-61
их сайт electron.uz
не реагирует ни на что, еще на экране характерный след, как будто продавили его. Пользуется мама, вот она меня этим и удивила smile.gif
any ideas, кому показать на диагностику можно?
их сайт electron.uz
Странно... Так я им звонил вчера и у них не было, поэтому и купил сегодня в их филиале на Ганге обычные полярные, БИ полярных не было smile.gif))
точно продавили или кажется?
в мануале написано: Удерживайте кнопку в течении 15 секунд и потом включите его. Пока кайндл перезагружается, экран может быть пустым в течении 30 сек.
screwjack2007
это ж не тачскрин, что там продавливать на экране, скорее всего тяжелое что-то поставили на него.
ViktorCH
Слышал, что можно по авиабилету купить в банке валюту по гос.курсу. Кто и как это делал, расскажите пожалуйста. Сын улетает в Москву на учебу.
ARI100KRAT
на высоковольтном был банк, вроде кредит стандарт, но сейчас знаю что у него отозвали валютную лицензию, а вообще слышал что любой банк обязан выдать валюту не помню в каком количестве по гос.курсу если предоставишь паспорт билет и еще я бегал за ИНН в налоговую не знаю зачем!
B@hus
Покупка валюты в банках республики
ViktorCH
Вроде слышал, что не все. А в какой срок они выдают?
ViktorCH
Цитата(bahus73 @ Aug 4 2012, 09:02) *
спасибо
ARI100KRAT
срок около 10-15 минут
ViktorCH
Да ладно! А Вы не помните заявление писали? Говорят после заявления 10 дней рассматривают?
ARI100KRAT
это вместе с заявлением, мы с мамой пришли в банк, задали вопрос так же ничего не знаю про эту операцию, может повезло может так и должно быть, нас отправили наверное к менеджеру или кто он там бал??? не знаю он сказал что нужно предоставить билет убывающего его паспорт и ИНН с НИ, и написать заявление, в то время пока моя мама сидела в банке писала 3 заявления, на себя на отца и на племянника которому на тот момент было 6 лет, я поехал в налоговую и понятно каким образом взял ИНН которого не хватало, кода приехал мама ждала меня уже возле кассы, я отдал этому чувачку бумажки и в кассе мы сдали сумы и спокойно получили СКВ! если бы у нас были все бумажки на руках времени соответственно понадобилось бы меньше, от сюда вывод либо как я писал так и должно быть, либо они просто шугнулись нас, а может просто повезло!
ViktorCH
Хорошо, если так...уже радует...буду пробовать. Вот только сын меня огорчил, он уже умудрился с друзьми кому-то на свой паспорт поменять без авиабилетов за 20тыс....квартал не прошел. Могут возникнуть проблемы, как думаете?
ARI100KRAT
не проблема
Ребят подскажите в москоу сити для управления машины нужны международные права?
У меня обычные менять здесь надо ?
нет не надо! сможешь год ездить, потом можешь пересдачу сделать!
наши права везде котируються
менять не надо только помни что в РФ срок действия прав 10 лет и если у тебя в узбекских правах дата выдачи до 2002 года могут быть проблемы(могут но не обязаны у меня гаишник спрашивал когда тормознул есть ли срок действия я ему прямо сказал кому то пишут кому то нет), ездить будешь по ним без проблем, без ограничений по времени пока не получишь гражданство РФ smile.gif когда получишь надо будет поменять на права РФ.
Лева не неси пургу по ним сколько влезет можно ездить
братишка в Калининграде рассказывал что устроился водителем на маршрутку! год ездил на наших правах потом заставили пере экзамен проходить
Возможно для водителей общественного транспорта другие условия?
бред
Pashuta
Ясно, спс)
Цитата(Smiler @ Aug 4 2012, 12:08) *
бред
Freeman
Щас это фантастика по-моему, выдают и то на карточку виза (здесь тратить нельзя только за границей), НБУ банк (районный) и Асака банк, очередь на 8-9 сентября в НБУ, а так процедура таже (Заявление, ИНН, паспорт, билеты).
mplayer
Да,только на визу . Тратить за границей. Снимать по 500 в день.
Меня интересовало,можно ли онлайн что-то покупать?
